02 memory seat
does your owner book say 02s have memory? iirc 03 has it but cant say on before that
02TL-- register with acura.com owner link and you can read the owner manual there- specific to each year
http://owners.acura.com/registration...erstepone.aspx
also register at 1 800 382 2238x5 need cars vin for both those systems
800 will ck if recalls are completed
ask the parts guy at your local dealer if its possible to interchange that year panel
Did 02-03 non type-s have mem seats or was that only type-s. I dont remember
Bonki' Ehrite!
Mark the date folks! Kris is finally stumped!
And yeah, both the type s and the non type s have memory seats.
And if the car has been wrecked and repaired, I'd venture to say that the shop cheaped out and put older panels in...So all you need is probably the actual buttons, Im sure the seats still have the module in them.
never trust the minimum wage phone answering drone at acura 800
they are looking in a book and have been know to be wrong..
especially when you think its warranty issue~
the Big Book of NO!!!
First take your door panel off and see if the wiring is there. If it is, try to locate a used door panel. It would probably be cheaper and easier.
Yeah the wire is in the when I took off the door panel to connect some plugs that my mechanic unplugged for some odd reason . Do you guys think i can just buy this http://cgi.ebay.com/ebaymotors/2002-...Q5fAccessories
and put it into my current door panel? cause im not sure if the current door handle hole will fit the new one.
I dont know if the door panels are the same or not. I havent seen them side by side.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
