2003 3.2 TL Radio Codes Error Message - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Second Generation TL (1999-2003) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 07-10-2008, 05:19 PM   #1
Registered Member
Trader Rating: (0)
Wha'ts up fellas? I recently got my car back from the dealer after nearly two months. They were repairing my head gaskets and installed a new radiator. When I went to pick up my car, the technician asked if my radio code worked because they kept getting an error message whenever they tried to put it in. Their code matched mine and, I never had a problem with the code before this. They told me there was something wrong internally with the radio and reccommended a new one. Has this happened to anyone here? What can I do to fix this? I dont want to pay for a new radio.
blaknupe is offline   Reply With Quote
Old 07-11-2008, 10:31 AM   #2
Registered Member
Trader Rating: (0)
My radio code wasn't working when I changed my battery a few weeks ago, and I took it to the dealer and they said the same thing -- if the code doesn't work, might need to replace the radio. The tech pulled the main fuse on the car (from the fuse box in the engine compartment) for about 20 seconds and then put it back in, and the radio then took my code. May want to give that shot.
sb65 is offline   Reply With Quote
Old 07-11-2008, 11:14 AM   #3
Registered Member
Trader Rating: (0)
Thanks SB65. I tried that and disconnected the battery again, neither worked. I will try disconnecting the main fuse a second time.
Old 07-11-2008, 03:28 PM   #4
Registered Member
Trader Rating: (0)
Probably doesn't matter, but he didn't touch the battery, since pulling the main fuse would/should cut the power to all/most electical components.
Old 07-12-2008, 09:11 AM   #5
Proud Acura Owner
deepen03's Avatar
Trader Rating: (0)
deepen915
well for me, if the code gets reset, sometimes it doesn't take the code even if i try a few times. So i just wait for like an hour and drive the car and then i try again and it works. so i don't know
deepen03 is offline   Reply With Quote
Old 07-12-2008, 01:28 PM   #6
Registered Member
Trader Rating: (0)
try disconnecting the antenna lead from the radio- i dont recall if you input the code then or plug it back in and then code- so try it and see- but thats a common way- unplug the antenna,-
check drivers side behind the center console- its a normal wire antenna connector plug like every radio made has
01tl4tl is offline   Reply With Quote
Old 07-12-2008, 01:47 PM   #7
Acura Owner Advocate
SERVICEADVISOR's Avatar
Trader Rating: (0)
You Have To De-tatch The Antenna From The Back Of The Stereo Turn Power To The Stereo On Then Enter Code Then The Radio Station Should Come On. Insert Antenna Back Into Rear Of Stereo And Your Done. ACURA HAS A SERVICE BULLETIN FOR THIS SO IF IT STILL DOESN'T WORK ASK THE DEALER FOR GOODWILL CONSIDERATION TO REPALCE THE AUDIO UNIT OR CALL CUSTOMER CARE AT (800) 999-5901
SERVICEADVISOR is offline   Reply With Quote
Old 07-22-2008, 10:22 PM   #8
Registered Member
Bearwolph's Avatar
Trader Rating: (0)
Quote:
Can I get to it from here?
Click the image to open in full size.
Bearwolph is offline   Reply With Quote
Old 07-22-2008, 11:11 PM   #9
Registered Member
acutee's Avatar
Trader Rating: (0)
It's on the left side, pull the side knee panel, and you will see it on the back, on the bottom side of the radio, use a long nose pliers to pull it down, out of the socket. turn on radio, enter code, and you are done.
acutee is offline   Reply With Quote
Old 07-24-2008, 01:30 PM   #10
Trader Rating: (0)
L-shaped Needle Nose Pliers Work Best
Old 07-24-2008, 01:39 PM   #11
fsttyms1's Avatar
Trader Rating: (0)
fsttyms1
fsttyms1 is offline   Reply With Quote
Old 07-27-2008, 10:14 PM   #12
YoungatHeart
kaptainjack's Avatar
Trader Rating: (0)
just wanted to add a THANK YOU to everyone who contributed info about inputing a radio code for an "03 TL-S...just put a new battery in my baby yesterday and was determined to get that darn code to work...tried once before about 2 months ago after some body work and chickened out after taking off some trim and the knee brace section...dealer did it as a goodwill service...this time I didn't stop until I got it done...found that damn antenna wire and plucked that sucker out...code went right in and the radio was set to go...'cept I had to get the antenna wire back in...that's the scary part...fat fingers don't have much room to work...even tore up some skin trying...but the needle nose plier idea worked wonders and before you knew it I was cruisin' to CSN&Y again (that's Crosby, Stills, Nash and Young)...
kaptainjack is offline   Reply With Quote
Old 07-29-2008, 03:43 PM   #13
Registered Member
Trader Rating: (0)
I'm having the same problem the dealership gave me 2 codes and it won't take any off them i try and i try but it just won't take it. and i can't take it to the dealership because the service department is closed at 6 and i get out of work at 5. please can someone tell me how to remote the panel so i can try unplugging the antenna and enter the code... i looked at it and there no exposed screws or anything for me to take out and i don't want to break it...
ontherockx is offline   Reply With Quote
Old 08-26-2008, 01:24 PM   #14
WILL PLAY POOL FOR CASH
Black-Balled's Avatar
Trader Rating: (3)
Quote:
Originally Posted by kaptainjack View Post
just wanted to add a THANK YOU to everyone ...and before you knew it I was cruisin' to CSN&Y again (that's Crosby, Stills, Nash and Young)...
Well, life could be worse!
__________________
07 Accord I-4 Not Rod.
Black-Balled is offline   Reply With Quote
Old 08-26-2008, 02:13 PM   #15
Registered Member
Mista Juice's Avatar
Trader Rating: (7)
i had/have an issue with my damn radio too.. a couple weeks back my cd got stuck mid-eject, threw the ere-1 code and after looking through azine, i fixed it and didnt have any more issues.. then, i also changed my battery yesterday and after putting the code in (it took with no problem) the radio now throws an ere-1 code when i hit the cd button.. then it just kicks it back to the tuner.. so wtf?
__________________
werd.
Mista Juice is offline   Reply With Quote
Old 09-23-2008, 10:46 PM   #16
Registered Member
Bearwolph's Avatar
Trader Rating: (0)
I'm dumb so can some one please point to where I can get to the antenna wire.
Old 10-01-2008, 03:52 PM   #17
New Member
Trader Rating: (0)
2003 TL Radio
I need the security code for my TL radio, the code on the card does not work or seem to correspond to the radio in the car. I bought the car used.
serial number is 30039102
dunbarwally is offline   Reply With Quote
Old 10-01-2008, 07:12 PM   #18
2G wanting 3G
9932's Avatar
Trader Rating: (1)
RaveDojek
turn off the radio. press and hold 1 and 6 preset buttons. with buttons still held turn on radio. the screen should display one number then another. the two combined are your radio code. call dealer with code. thank me later.
__________________
1999 FPR 3.2 TL-P: OEM Ground Effects, 18" Chrome TSX Aspec wheels, Injen CAI, Painted Calipers, Drilled rotors, Black Mesh Grill, 30% tints, 02-03 tail lights, Kaixen 5K's, NGK Iridium's
(Tokico Illumina's and H&R Springs in the trunk waiting for summer)
[waiting to install my led gauges from phee]
9932 is offline   Reply With Quote
Old 10-01-2008, 07:19 PM   #19
New Member
Trader Rating: (0)
if you were replying back to me, I think you may have misunderstood my post. I did the 1 & 6 got the serial number ( which I put in my post) was hoping someone in the online community knew how to access the codes i.e. honda/Acura service tech
My local dealer is very difficult to deal with. (Burrard Acura in Vancouver)
Old 10-01-2008, 10:30 PM   #20
fsttyms1's Avatar
Trader Rating: (0)
fsttyms1
You are going to have to call the dealer to get the code. Did you search thru the car to look for the radio code?
Old 10-01-2008, 10:31 PM   #21
fsttyms1's Avatar
Trader Rating: (0)
fsttyms1
No where in that pic. Its BEHIND the radio.
Old 10-08-2008, 11:46 PM   #22
Registered Member
Gray03's Avatar
Trader Rating: (0)
Quote:
Dunbarwally - once you have the serial no. and VIN you can use
https://radio-navicode.acura.com/ to get the radio code.
Gray03 is offline   Reply With Quote
Old 08-09-2010, 03:14 PM   #23
Registered Member
Trader Rating: (0)
Hey guys/gals... Dealer wanted $110 to input radio code (error) for my 2003 TL-S after a battery change at home.. I found out that our radios are linked to the on-star system, so you need to get away from a radio signal completely.. I went to a lowest level of IKEA double car parking garage.. or you can do this in underground garage. With no radio signal, I was able to input the 5 digit code.. Saved $110.. Try it.
phaight1 is offline   Reply With Quote
Old 10-02-2010, 01:33 PM   #24
Registered Member
Trader Rating: (0)
Took off drivers side armrest molding. Just carfully pull up starting at arm rest and it comes out. Undo four screws holding kick panel. One of the kick panel screws is behind the under steering wheel panel. There are two snap in points on the one under the steering wheel near the kick panel. The other side near door has screw, but that can stay in. Once you pop out the under steering wheel panel on the one side you can get to the last kick panel screw. My antenna plugs right into the back bottom left corner of the radio and I used a needle nose plier to pull out.
staple1 is offline   Reply With Quote
Old 10-30-2010, 12:23 PM   #25
Registered Member
Trader Rating: (0)
Just wanted to say thanks. Used the advice from SERVICEADVISOR and it worked perfect.
I didn't use any pliars and cut up my hands...so I'd recommend using pliars.
Manus99 is offline   Reply With Quote
Old 11-02-2010, 08:32 PM   #26
Registered Member
JakeType-S's Avatar
Trader Rating: (0)
I am glad I came across this issue by reading the forums..
I turned the stereo to AM before I disconnected the battery, but still would not take the code. Got the kick panels off and pulled the antenna out. Turned it on, it took the code, put it back together.
Then I decided to become a member of Acurazine!
JakeType-S is offline   Reply With Quote
Old 11-02-2010, 10:16 PM   #27
Registered Member
Trader Rating: (0)
its worth every penny it cost to join~
This is a great place for real tech help from experienced TL owners, techs, and as you have found - even real acura dealer management helps us out sometimes!
thanks SA~
__________________
at the end of your life,,it was all just stuff, so enjoy great toys!!
you can screw around asking buddies,
or you can believe acurazine- where info is based on thousands of users reports!
Old 03-01-2013, 03:52 PM   #28
New Member
Trader Rating: (0)
(crosspost from http://tl.acurazine.com/forums/showthread.php?t=631083 , as the thread is essentially about the same thing).
Just a quick heads-up (found this thread via Google) - this problem continues unabated, and the solution remains the same:
My 2003 TL-S started rejecting the Radio code in 2009 after a battery change - and the dealership ripped me off to the tune of +$100 to do whatever they had to do to "fix" this. Fast forward to early 2013 : new battery, same thing. Followed the instructions here to take off the kick panel and unplugged the antenna, entered the code, put it all back together, for about a 40-min total, most of which was spent reaching for the most-hidden screw near the steering wheel: pushing down the panel under the steering wheel (only the right side moves) and jamming a small Maglite flashlight into it, and then using a long screw driver forward over the right side gets it. I took some pictures, looking to upload and post them here...
CoreMaimer is offline   Reply With Quote
Old 03-01-2013, 03:59 PM   #29
Registered Member
Trader Rating: (0)
Other option is to find an underground parking garage, and then try the code. I use this option and it works for me. The idea is to isolate the radio from radio signals.
Seabright is offline   Reply With Quote
Old 03-09-2013, 02:02 AM   #30
New Member
Trader Rating: (0)
Easy Fix
Had this same problem on my 03 TL-S when any work was done. Old owner said to simply put in the code in an underground parking garage when the radio presumably loses signal. It worked for me, best of luck.
Pedro Herce is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
2007 audio system issue Tim Giron Audio, Bluetooth, Electronics & Navigation 0 09-21-2015 06:42 PM
P0171 & awd77 heykosal Problems & Fixes 10 09-21-2015 10:41 AM
Sector111: Drakan Spyder News Yumcha Automotive News 1 09-20-2015 08:08 PM
WTB: Power Adders wanted for UA5 2G CL/TL 2G-TL-Type-S-03 Car Parts for Sale 0 09-20-2015 01:48 AM
P0507 code - Big mo Problems & Fixes 3 09-12-2015 08:22 AM
Tags
03, 2000, 2003, 32tl, acura, antenna, code, error, navigation, radio, remove, reset, security, stereo, system, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
