2002 Acura TL Type S P0505 code
Old 05-31-2011, 04:27 PM
sunset_2002tl's Avatar
Exclamation 2002 Acura TL Type S P0505 code
2002 Acura TL Type S P0505 code, I have replaced idle control module and pcv valve and still does the same.
With brake on in drive at a stoplight the idle will go down to about 400 rpms idle rough then VSA and Check eng light come on.....after that the car will shudder and jerk if you let off thottle fast at most speeds.
Old 06-01-2011, 04:58 PM
acutee's Avatar
Check your alternator, if not that, then it is iac valve.
handsom-hustla
11-13-2015 05:04 PM
theinsvnity
09-10-2015 10:22 PM
kuzdu
09-10-2015 08:42 PM
Glorygang600
09-05-2015 01:17 AM
voigt
09-02-2015 10:44 PM
Quick Reply: 2002 Acura TL Type S P0505 code
