Yellow triangle question - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 03-03-2012, 12:12 AM   #1
Registered Member
h2point2's Avatar
Trader Rating: (1)
fiapae unforgiviblesin unforgiviblesin
i searched but could not find my answer.
i installed new suspension in my car last night and i guess i cut my driver side rear wheel speed sensor, my abs light vsa light and triangle were on my dash, i got it scanned came home and spliced the wires back together untill i can get my sensor on monday. the abs and vsa light are now off but the yellow triangle remains... do i have to go and get this shut off? cleared? or will it go out when i install my new speed sensor?
h2point2 is offline   Reply With Quote
Old 03-03-2012, 12:15 AM   #2
Bearcat94's Avatar
Trader Rating: (0)
Faceless Not a Twit Un-Linked No Live Box StealMyInfoPls
Push the VSA button - turn VSA back on?
Ehhh, maybe not:
Quote:
When VSA is off, the VSA activation
indicator comes on as a reminder.
VSA is turned on every time you
start the engine, even if you turned it
off the last time you drove the
vehicle. ....
__________________
'07 WDP/Taupe TL-S 5AT
'02 WDP/Parchment TL-S 5AT
Bearcat94 is online now   Reply With Quote
Old 03-03-2012, 12:26 AM   #3
Registered Member
h2point2's Avatar
Trader Rating: (1)
mine stays on at startup now, cant get the light to go out.
Old 03-03-2012, 12:29 AM   #4
Bearcat94's Avatar
Trader Rating: (0)
Quote:
Which indicates (or should indicate) that VSA is off. If that is the case, it's not big deal for a couple of days.
Car drive OK? No surging, momentary loss of throttle, odd brake engagement?
__________________
Old 03-03-2012, 12:47 AM   #5
Registered Member
h2point2's Avatar
Trader Rating: (1)
car drives fine, all is good no surging and brakes fine. like i said all those lights came on, got it scanned, came home took wheel off and found a broken WSS wire, so i cut and mended it. now abs lights and VSA light is off but the triangle is still on.
is this something that needs to be erased because it is storing a malfunction... or maybe the WSS isnt completely mended. it has to be that because it happened after the newer suspension install
Old 03-03-2012, 01:12 AM   #6
Bearcat94's Avatar
Trader Rating: (0)
I think it's the sensor. You were going to replace it, so do that first. If that doesn't clear the light, you've got some other issue.
Just take care if anything feels odd and I'd try tp avoid engaging ABS, TC, etc. until that sensor is replaced.
Edit:
Another thought. Check fuse #17 & #18 in the under-hood box. 18 is the "VSA Fail Safe Relay". Probably not the problem, but if it is, it's an easy fix.
__________________
Old 03-03-2012, 02:51 AM   #7
2004 Acura TL
Sotiris's Avatar
Trader Rating: (0)
From what I remember you have to go to either the dealership or a shop that has an HDS reader to clear the vsa light. The normal code scanners can not reset it. I might be wrong though it's been a while, I screwed up the speed sensor the first time I did my brakes
Sotiris is offline   Reply With Quote
Old 03-03-2012, 03:00 AM   #8
Registered Member
h2point2's Avatar
Trader Rating: (1)
i think i checked both of those vsa underhood fuses, thank you! and about the code reader, its a shops its about 3500 bucks lol it better. it read my codes earlier so we will see what it says tomorrow.
Old 03-06-2012, 09:48 PM   #9
Registered Member
h2point2's Avatar
Trader Rating: (1)
fixed sensor today, and the triangle is still on, and when i start to gain speed the VSA illuminates and does not go out... fml this is irratating
Old 03-06-2012, 11:56 PM   #10
Registered Member
h2point2's Avatar
Trader Rating: (1)
So I reset it by manually jumping 4 and 9
Similar Threads
Thread Thread Starter Forum Replies Last Post
NavTool Video Interfaces for 3rd Gen MDX navtool.com 3G MDX Discussion (2014+) 32 01-20-2016 12:43 PM
NavTool Video Interfaces For TLX navtool.com Audio, Bluetooth, Electronics & Navigation 31 11-16-2015 09:30 PM
Modesta BC-04 on a Maritime Blue - Paint to Sample - Porsche 911 GT3 detailersdomain Wash & Wax 3 10-09-2015 11:13 PM
Odd Wires near Bluetooth HFL??? HELP! SUPRMN84 Audio, Bluetooth, Electronics & Navigation 5 10-07-2015 10:46 PM
Shifting Gears (6MT): Help diagnose the problem SidhuSaaB Problems & Fixes 0 09-22-2015 11:32 AM
Tags
07, 2004, acura, car, fix, light, problem, reset, rl, simple, tl, trangl, trangle, triangle, tsx, yellow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
