Windshield washer fluid - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 12-27-2010, 06:28 PM   #1
Registered Member
Trader Rating: (0)
Question Windshield washer fluid
my windshield washer fluid stopped working, wipers go on, but no fluid comes out. Do you think this is a pump problem? Suggestions to what i should look for?
Any help is greatly appreciated.
Thank you!
pyckuu23 is offline   Reply With Quote
Old 12-27-2010, 06:32 PM   #2
Registered Member
Noober's Avatar
Trader Rating: (7)
Nooberr
fill it up.
__________________
2007 Acura TL-S || Factory Setting
Noober is offline   Reply With Quote
Old 12-27-2010, 06:42 PM   #3
Registered Member
apnorm's Avatar
Trader Rating: (3)
you should be able to hear the pump going...if not, check your fuse first and hope it's a quick fix.
If the pump is working and you have fluid in your reservoir, it could be that there's some ice blocking the sprayer.
apnorm is offline   Reply With Quote
Old 12-27-2010, 06:42 PM   #4
Registered Member
Trader Rating: (0)
forgot to mention it is water is filled up
Old 12-27-2010, 06:44 PM   #5
Registered Member
Trader Rating: (0)
@apnorm good call i will check the fuse. I don't recall hearing the pump going ... I will let you know tomorrow. thx
Old 12-27-2010, 07:00 PM   #6
Registered Member
nfnsquared's Avatar
Trader Rating: (0)
Is the green light in your mirror out? If so, it's the fuse...#20. Replace with 10A.
__________________
04 6MT, Navi, WDP, chrome wheels, ASPEC suspension (08W60-SEP-201B), Clifford Matrix 50.7X RS/Alarm, Huper Optik ceramic tints. Original owner....
nfnsquared is offline   Reply With Quote
Old 12-27-2010, 07:04 PM   #7
Registered Member
Trader Rating: (0)
Water? That might be your problem if you live someplace cold.
TKO1 is offline   Reply With Quote
Old 12-27-2010, 07:55 PM   #8
Registered Member
Trader Rating: (0)
TKO1 - sorry its windshield washer fluid rated for -20F
Old 12-27-2010, 07:56 PM   #9
Registered Member
Trader Rating: (0)
nfnsquared - i will check it out thanks for the info
Old 12-29-2010, 11:29 AM   #10
Registered Member
Trader Rating: (0)
thanks for your help guys, it was fuse #20 (7.5 amp)
Old 12-29-2010, 11:35 AM   #11
Registered Member
nfnsquared's Avatar
Trader Rating: (0)
Quote:
You bet...Replace it with a 10A fuse...
And keep a spare fuse or two handy in case it happens again. The fluid froze in the lines for some reason and the pump over amps the circuit when it can't pump fluid...
__________________
Old 12-29-2010, 09:57 PM   #12
Elladas- S/C 6MT TL
04WDPSeDaN's Avatar
Trader Rating: (1)
If you put water in there AND IT'S WINTER outside... that's the wrong move.
Water freezes.. Washer fluid doesn't
Water freezes and jams up the washer motor.
Which blows the fuse...
Put good known washer fluid in, check fuse and proceed to see if washer works. If not and the fuse is good, then remove your bumper and replace the washer located on the right front under the head head assembly.
04WDPSeDaN is offline   Reply With Quote
Old 12-29-2010, 10:48 PM   #13
Registered Member
nfnsquared's Avatar
Trader Rating: (0)
^^^post #8
__________________
Old 03-30-2011, 12:29 PM   #14
2007 TL
tj19855's Avatar
Trader Rating: (0)
Wiper fluid not working all of the sudden
Mine stopped working yesterday, I can hear the pump and wipers come on but no fluid comes out, I filled it up today and still nothing.
__________________
2007 Acura TL Nav, 5% Tint all around, K&N Air Filter, Kumho Ecsta AST, Front signal VLEDs Switchbacks, Rear VLEDs turn signals, Super White Reverse & license plate LEDs, Acura window visors. WINDSHIELD REPAIR & HEADLIGHT RESTORATION CERTIFIED TECH.
tj19855 is offline   Reply With Quote
Old 03-30-2011, 01:41 PM   #15
Registered Member
VQPower37's Avatar
Trader Rating: (0)
is there a large piece of ice at the bottom of ur reservoir? that could be the problem ... even if u filled it, none of that fluid will be able to get to the pump that it needs to get to in order to be sprayed on ur windshield
__________________
2007 CBP TL Type S|18x8 Gunmetal A Spec Wheels|245/40/18 Continental ExtremeContact DWS|R1 Concepts Eline Cross-Drilled & Slotted Rotors|Duralast Gold Cmax Brake Pads|Stage 3 Exhaust - Magnaflow Mid-Muffler|Michelin Stealth Wiper Blades|Rockblocker Headlight and Foglight Protection|15% Solar Gard Window Tint|UA7 SQUAD MEMBER #28|19UUA76587A008153
2012 BRP SHAWD TL Tech
VQPower37 is offline   Reply With Quote
Old 04-01-2011, 03:06 PM   #16
2007 TL
tj19855's Avatar
Trader Rating: (0)
No weather here is 80F, I figured out what the problem was, on the 3rd gen TLs if you take all the plastic covers off the engine on the passenger side, the windshield wiper fluid rubber tube runs near the wiper fluid reservoir up to the windshield next to the fender. The tube was detached so I just put it back on. Now it works again
__________________
Similar Threads
Thread Thread Starter Forum Replies Last Post
Windshield replacement questions TheMuffinMan Fourth Generation TL (2009-2014) 23 01-29-2016 03:29 PM
Modesta BC-04 on a Maritime Blue - Paint to Sample - Porsche 911 GT3 detailersdomain Wash & Wax 3 10-09-2015 11:13 PM
WTB: 4G TL SH-AWD parts needed!! rhdune16 Car Parts for Sale 0 09-28-2015 12:31 PM
Service 6 - DIY Cexarin Fifth Generation TLX (2015+) 4 09-23-2015 08:43 PM
Shifting Gears (6MT): Help diagnose the problem SidhuSaaB Problems & Fixes 0 09-22-2015 11:32 AM
Tags
2004, acura, failure, fliud, fluid, frozen, pump, ratings, tl, tsx, washer, windshield, winshield, wiper, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
