Weird noise from serpentine belt !!!!!!!!!!!!!!
Old 09-02-2015, 04:11 PM
Phmbm12
Phambam12's Avatar
Unhappy Weird noise from serpentine belt !!!!!!!!!!!!!!
I just replaced the serpentine belt and everything is running smoothly
Today, i just noticed a strange sound whenever i would turn left or right. even if it was a slight turn.
I'm uploading videos right now.
Someone help?!?
Old 09-02-2015, 04:20 PM
Phmbm12
Phambam12's Avatar
This one is from within the cabin as i am turning my wheel
This one is just from the outside. it doesnt sound normal to be honest
Old 09-02-2015, 04:24 PM
Phmbm12
Phambam12's Avatar
It sounds like a weed wacker.
Old 09-02-2015, 04:45 PM
Will1688's Avatar
Did you change the tensioners aswell?
Old 09-02-2015, 05:16 PM
nvmaddog's Avatar
That sounds like the power steering pump is making some noise when load is applied.
Old 09-02-2015, 05:58 PM
Jeff
Oh Sickest TL's Avatar
man that sucks i don't have the slightest clue but that sounds like a honda lawn mower
Old 09-02-2015, 07:09 PM
polish_pat's Avatar
sound like when my power steering o' ring was bad...
Old 09-03-2015, 09:16 AM
Phmbm12
Phambam12's Avatar
How would i determine if this is the reason that my car is acting like that?
Thank you for any responses
Old 09-03-2015, 03:22 PM
nvmaddog's Avatar
Mostly due to the sound only occurring when you turn the steering wheel.
I would say the power steering pump is either on it's way out, or you have a tensioner/serpentine belt issue.
Old 09-03-2015, 04:18 PM
Phmbm12
Phambam12's Avatar
HOw owuld i know which one of these it is and how would i go about fixing that issue? i am completely noob at this.
Old 09-04-2015, 03:07 PM
quantum7's Avatar
I think that you can look at the Power Steering fluid in the reservoir to see if there are air bubbles to determine if the O ring is shot. Do a search here since there are several threads on repair and some video clips as well I think on YouTube.
Old 09-05-2015, 03:13 AM
eastcoastguy's Avatar
Take a longer thin piece of metal and use it like a stethoscope to see which one is making the noise.
Old 09-05-2015, 07:04 AM
quantum7's Avatar
Here is a video of the O ring problem if that is the issue. Again, see if you have air in the reservoir. As you can see if this is the problem then it is an easy fix.
https://www.youtube.com/watch?v=SM6t...ature=youtu.be
Good luck and let us know.
Old 09-05-2015, 04:10 PM
01acls's Avatar
MrHeeltoe
20
02-23-2023 01:54 PM
08KBP_VA
10-22-2019 01:55 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
xsilverhawkx
10-05-2015 11:00 AM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
Quick Reply: Weird noise from serpentine belt !!!!!!!!!!!!!!
