VSA and the triangle light along with the brake light just came on
Old 05-18-2011, 01:07 AM
trulegend's Avatar
Exclamation VSA and the triangle light along with the brake light just came on
Hello,
My VSA and the triangle light along with the brake light are on my 2004 TL.
I checked the brake fluid, and the rear brake light to see when i step on the brakes if they light up and they do.
I searched on this issue and the post ended with the poster taking it to Acura for troubleshooting, and other said master cylinder need to be replaced etc..
i ave 2004 TL with 90k miles out of warranty and the dealer is my last resort.
Can someone tell me how do i troubleshoot this?
thx
Old 05-18-2011, 05:58 AM
lankanboy1's Avatar
what do u mean by brake light ABS ? or the ((!)) light
Old 05-18-2011, 07:46 AM
3rd Gear
Acura3401's Avatar
Originally Posted by trulegend
Hello,
thx
My brother got those same lights on his 01 cl type -s auto. He took it to the Acura dealer and they told him his transmission is shot.
Old 05-18-2011, 10:42 AM
trulegend's Avatar
no not ABS light
it is ! VSA and hand brake light.
i smogged the car yesterday with those lights without a problem.
trulegend's Avatar
also reset the battery but the light came back
Old 05-18-2011, 07:11 PM
trulegend's Avatar
anyone???
Old 05-18-2011, 08:15 PM
the overexplainer
ez12a's Avatar
have your batt checked
Old 05-18-2011, 10:10 PM
acurabum's Avatar
If my 08-typeS has a (!) light up on the cluster then what it means ?
Old 05-27-2011, 12:44 PM
trulegend's Avatar
update on this.
i had a honda/acura shop inspect it they had the honda scanner.
The code came back as Low Voltage and Brake fluid.
They cleared the low voltage with tighting battery terminals (battery terminals were loose)
They flushed the brake fluid, the code kept coming back. They suggested i need new brakes and rotors cause they are gone.
I had them replace new brake pads and rotors in the front.
Still the code shows up, they are thinking that there is a sensor that is attached to the brake master cylinder and the entire brake master cylinder will need to be replaced.
Before i shell out more bucks on this anyone with this experience has seen that it could be the brake master cylinder/resovir?
They inspected the entire car no check engine lights, tranny shifts fine etc..
Only The brake light, Triangle ! and vsa light is on. The vsa light comes on pass 15mph and remains on.
Can anyone chime in regarding this.
thx
Old 05-30-2011, 12:27 PM
bluetl04's Avatar
hey man...i have a 04 tl with 130k on it...i just got those same 3 lights come up...i also tried resetting the pcm and it still shows up...so what exactly did they say about the sensor on the master cylinder?
Old 05-31-2011, 01:01 PM
trulegend's Avatar
as i mentioned check your battery cables if they are tight, there is a sensor that is attached to the brake master cylinder, his thought was the brake master cylinder needed to be replace.
If you find some other fix for it, plz let me know
Old 05-31-2011, 04:50 PM
05AV6's Avatar
I had this same issue on a 2005 Honda Accord V6, I replaced the master cylinder, didn'tdo much, it ended up being ABS unit itself was bad, replaced it for $875, problem was gone.
Old 05-31-2011, 05:54 PM
bluetl04's Avatar
it cant be the abs unit because me nor trulegend is getting a abs light on...the only three lights are the brake, vsa and the triangle
Old 05-31-2011, 05:55 PM
bluetl04's Avatar
i was reading a thread that a member here was having the same issue and it was the sensor in the master cylinder....
Old 05-31-2011, 05:56 PM
bluetl04's Avatar
if any of the abs compenents are not working or if a sensor went bad, the abs light would pop up
Old 05-31-2011, 05:58 PM
bluetl04's Avatar
i did a test....i disconnected the front driver side wheel speed sensor which is connected to the abs unit, and my abs light went on....i connected back and the abs light shut off
Old 06-01-2011, 12:25 AM
trulegend's Avatar
I did a similar test but removed the vsa fuse from the box inside the engine and abs came on.
If you disconnect the plug that attaches to brake master cylinder it will turn of the brake light. The triangle is on when the car turns on and vsa pops up after 35 mph.
Old 06-01-2011, 04:34 PM
bluetl04's Avatar
i just disconnected the sensor from the master cylinder and all my lights are gone...i drove from work to home and nothing came on...once i got home, i plugged it back in and all 3 lights came back on.,..so i have figured out my problem....
Old 06-01-2011, 04:35 PM
bluetl04's Avatar
im not sure why ur vsa light came on but im assuming you might have more of a problem than that sensor
Old 06-01-2011, 07:45 PM
Chapter Leader (New England)
JMillerUA6's Avatar
Do these lights flash when the initially come on?
Old 06-01-2011, 08:49 PM
bluetl04's Avatar
no they do not flash bro
Old 06-27-2011, 12:47 PM
7th Gear
bkbobby's Avatar
my vsa light and (!) light came on now i can start the car but can not come out of park unless i use shift release button
Old 06-28-2011, 07:41 AM
trulegend's Avatar
I Was so annoyed by this after going to the shop multiple times spending several hundred dollars I ended up selling my TL.
Old 06-28-2011, 07:44 AM
Received 16,260 Likes on 11,971 Posts
what did you pick up?
and i hate to see when your next car throws a light, you gonna sell that one too?
Old 08-11-2014, 02:56 PM
Future23's Avatar
Hey guys I know this tread is old, but I recently encountered da same problem n I'm pulling my hair out with this issue. I got all 3 lights on, I switched out da master cylinder n da lights are not going away. The diagnostic is saying low brake fluid n da master cylinder is full with new fluid. Can some1 please help me those lights are annoying to look at.
Old 08-12-2014, 08:27 AM
flyromeo3's Avatar
Did you pull any codes?
You have to get a reader that can pull ABS codes.
autozone, pepboys, etc... should have one of those readers you can use to get the DTC.
Once you get the DTC code, let us know.
Old 08-12-2014, 01:03 PM
pbook4g5's Avatar
Had this same thing happen in my accord (like someone else mentioned above) and it was my VSA modulator. ABS light was not on, either. Just brake, !, and TCS/VSA
Old 08-12-2014, 01:06 PM
dirtyspitshine's Avatar
This happened to me. Turned out my rear driver's side caliper had seized up. After I replaced it and the brake hose the light never came back.
Old 10-14-2014, 03:07 PM
illstyliztic1's Avatar
solved?..
I have the same problem but the VSA light and the triangle with the exclamation mark on it comes on intermittently but when i shut off the car and turn it back on the lights are gone. I went to a friend who is a mechanic and he ran the codes and it showed low voltage but checked the alternator and battery both worked fine and he also got a code for brake light switch so once he changed that out i no longer had the problem. Hope this info helps some of you
Old 10-21-2014, 09:26 AM
davedas90's Avatar
Brake Light Problem
My brake light on the dash on my 2006 TL stays on all the time to can't for a good answer
Old 10-21-2014, 12:02 PM
Registered but harmless
Will Y.'s Avatar
Received 1,102 Likes on 763 Posts
Start with the basics-- have you checked the brake fluid level?
Welcome to AZ.
Old 12-14-2014, 11:32 PM
4th Gear
cavitt423_UA6's Avatar
Okay so i have exact same iaaue. Except my abs light is on as well. also brake lights. Including third light. Does not function when pressing brake. I changee brake light switch being my first option. Is it possible that my subs blew these fuses ? My horn doesnt work either. And i have to manually do the shift lock as if my nuetral safety switch is out. HELP PLEASE 2007 TL BASE NO NAVI 101,000 MILES
Old 12-15-2014, 08:33 AM
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
Check under hood fuse 13 for horn, fuse 4 for trail lights. While at it, check all the fuses under there...
Old 09-01-2015, 11:53 AM
rsxs9400's Avatar
Im having this same problem. Code comes up low brake fluid. I topped off and it went away. Came back a month later. Filled up and now it stays on. I unplgged the wire to the resevoir and the light goes off. Is there a sensor/float in the resevoir that is able to be replaced?
Thanks in advance...will keep posted
Taking to local shop to check pad thickness as I have read this could cause fluid level to drop as the calipers have to push pads futher.
Old 09-02-2015, 10:50 AM
rsxs9400's Avatar
Just a follow up to some having this same problem.
VSA/Brake light was due to the float being stuck in the resevoir. That was leading the sensor to read low fluid.
Slpr04UA6 (09-02-2015)
Old 09-03-2015, 01:08 PM
mada51589's Avatar
Hey everyone, I know that this thread is old and has been picked back up a couple of times through the years, but I'm out of troubleshooting steps. Here's the deal: I have a 06 TL with almost 200k miles. Before mind blowing or boggling begins, its 90% highway miles, I drive 150 miles round trip to my work, 5 days a week. Anyways, I've owned the car since 2011 with 59k miles, I maintain oil changes every 3k miles, which is usually about once a month for me, and always use Full Synthetic oil, either Mobile 1 or Royal Purple(which is overkill, but with my long distance, I need it to be reliable). The transmission fluid gets a flush service at the dealership once a year, and a 3x1 change once every 6 months. Brakes are well maintained, slot & ported rotors, platinum ceramic brake pads, DOT4 (haven't ordered 5.1) flushed once a year.
Recently, I found my rear running lights on, not brake lights like when the brake pedal is pressed, when the car was off & locked. At the time this first occurred, no DTC or ABS codes, or any lights on the dash were on. Disconnected the battery and it went away for a day or so. Then they came on again, still no dash lights or codes on, just the running lights in the rear, and the brake lights worked when you pressed on the brakes. Didn't worry about it too much, I was lazy and didn't investigate too much. After a few weeks, the Triangle "!" light came on while driving home from work. After restarting the car, it didn't come on the rest of my travel home, and not until I arrived at work the next morning......
So now, a few weeks and lots of troubleshooting/researching later, the Triangle "!" light is always on, and after reaching 20-30 mph, the "VSA" light turns on. Note, when I first start the car up and the VSA light hasn't turned on yet, but the Triangle "!" is on, there are no DTC or ABS codes. Once the VSA light turns on, the ABS code 84-1 "Sensor Logic Failure" is produced, but thats it. I clear the ABS code with my OBDII/ABS scanner, and the VSA light clears, but the Triangle "!" light stays on, same thing happens when restarting the car.
Troubleshooting: I have replaced the Brake light switch, the APP Sensor, tested all 4 Transmission Control Solenoids (first unplugging each one and watching a code pop, then taking each one out and applying power to them to feel/hear them click), flushed the entire brake fluid system, cleaned all 4 ABS/Wheel sensors (as well as unplugging each one and watching a code pop), Did a 3x1 transmission fluid change (the oil was dark but not burnt), and the neutral safety switch is working fine.
Before I changed the APP Sensor, the car did do a traction control stutter on take off, but that has been resolved. Also, after changing the neutral safety switch, the running lights issue has been resolved. I have two fairly new Optima batteries in the car, red top under the hood, and a yellow top in the trunk, (for the sound system), which are at equal amps and tested good on a hard battery test (took the batteries out of the car to test inside the part store rather than that little hand held crap tester). Oh yeah, the HFL unit was removed a long time ago, so battery drain and low voltage are not the problem. Also, the VSA switch/button isn't doing anything, even after holding the button for a long period of time.
Sorry for the really long post, I wanted to make sure I listed every possible thing going on and every possible troubleshooting step I've taken. I have a Santech OBDII/ABS scanner that I am using to read and clear the codes... Is it possible that there are codes or clearing methods that a "Honda" scanner would/could do? Any help would be greatly appreciated! Thank you all!
93LT1 (09-23-2020)
Old 09-08-2015, 06:15 PM
6th Gear
Noland21's Avatar
Here is a link to what helped me on my 2002 grand am... https://acurazine.com/forums/problem...h-help-935803/
Old 01-13-2016, 02:44 PM
optical24's Avatar
Bumping this thread. I just had the same problem for a few days and it turns out that I was running low on brake fluid. After adding some brake fluid, the VSA and e-brake lights disappeared.
Old 07-28-2017, 01:30 PM
kayeat's Avatar
This answer needs more love. Saved me $$$$
Thanks so much for the quick and dirty suggestion. I had a fuse out & had no idea.
To anyone still having this problem, start with these cheap ($30 or less) self solutions first
- check the battery connection
- check the fuses (as mentioned above. Mine was the rear lights)
- check the break sensor
.....if all those check out and you don't have a different error code. Might be time to take it in.
Old 07-31-2017, 09:29 PM
9th Gear
Jason Chase's Avatar
i had the VSA problem before and i had to get a buddy to hook up is obd fancy computer to tell the vsa to relearn. You just tell it to do it take your car for a quick drive and bam its back to normal
Quick Reply: VSA and the triangle light along with the brake light just came on
