Replacing PCV Valve for "Tighten Gas Cap" Message
Hey everyone,
Like a lot of you, I have been dealing with this "Tighten Gas Cap" message for a while now. I dealt with it in my older 07 TL Base also, but it went away after a while.
I have an 07 TL Type S now, and the message pops up much more frequently. After doing some research, I decided to replace the PCV Valve. Unfortunately, it was in there pretty tight, and when I was trying to remove it, the plastic valve broke and now there are pieces remaining in the valve cover that are too tight to just get with my fingers, and the pliers have nothing to grab. Any way to get it out aside from removing everything? I'll be sure to update y'all and let you know if it fixes the TGC message.
Thanks!
Thanks!
the purge control solenoid is what you want to change. if your part was only $20 instead of $100, it's the wrong part.
the purge control solenoid is super simple to change and you can't mess it up...all you do is remove 2 screws, take off 2 hoses and you're good to go. i did this about a month ago
Do you have a diagram or anything showing where it is? I'm still working on taking off the valve covers so I can remove the plastic fragments. I do not have the tools to blow compressed air into the hole.
it won't come back, I will bet on it.
Anyone else have the engine light kick on after the tighten gas message had stopped briefly? It seems to jus be another warning light for the same thing how it kicks on only when the tight gas cap message stops briefly.
