Rear passenger window only goes down half way
Old 10-20-2010, 12:14 PM
woowoo's Avatar
I am having a hard time finding a solution for this particular problem here on the forum.
My back right window will roll down about half way before it makes a clicking noise and stops. I think something might be off track or lodged in the track causing the regulator to kick off to protect itself.
The window rolls up just fine though.
Does anyone have any recommendations on troubleshooting this problem?
Old 10-22-2010, 03:22 PM
woowoo's Avatar
I lubricated the window tracks and was able to get all but the last 2 inches of the window to roll down. Anyone have any other ideas?
Old 10-22-2010, 04:13 PM
Chapter Leader (Central New Jersey)
07tl-s6spd's Avatar
pop that door panel off and take a look...only way you can be sure if something isnt right....makes sense to me
Old 10-22-2010, 10:07 PM
woowoo's Avatar
I don't have a problem taking the door panel off but I don't know where to look after it is off. Do I pull off the plastic lining and start poking around behind it?
Old 10-23-2010, 01:30 PM
pohljm's Avatar
Yes, so that you can visually see the tracks and if anything is binding. are the windows tinted? sometimes the glue can get the tracks a bit sticky and bind, probably just needs some lube down there
Old 10-23-2010, 08:12 PM
woowoo's Avatar
I'll check that out. Thanks pohljm.
Old 06-30-2015, 08:28 AM
Jaxs Teller
saggipaul's Avatar
Check link for tsb 06-031,
Acura (Honda) Workshop Manuals > TL V6-3.2L (2004) > Body and Frame > Doors, Hood and Trunk > Doors > Front Door > Front Door Window Regulator > System Information > Technical Service Bulletins > All Technical Service Bulletins for Front Door Window
Old 06-30-2015, 08:42 AM
Received 8,568 Likes on 6,621 Posts
Old 07-05-2015, 07:42 PM
WDPanda's Avatar
You need a new window regulator. If you keep using the window, it may get stuck open.
rockyboy
12-06-2022 02:29 PM
02-25-2020 09:57 AM
Fabian43
07-13-2016 09:07 PM
HairyMonkey019
04-22-2016 10:50 PM
Dunnik
09-14-2015 02:56 AM
Quick Reply: Rear passenger window only goes down half way
