P2254 CEL Code on 2004 TL - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 02-10-2012, 11:00 PM   #1
Registered Member
JBSTRD's Avatar
Trader Rating: (0)
I recently popped a P2254 code upon startup yesterday. My car has shown no signs of any apparent issues. The code reads: Negative current circuit/open Bank 2 Sensor 1.
I cleared the code and have driven about 20 miles. The code has not appeared again. I have searched, but I have not found much info on this particular code. I found a write-up on the P2251, which is the same issue only for Bank 1 Sensor 1.
I am wondering if anybody knows if this typically means the o2 sensor needs replaced. If the light stays off should I still replace the sensor? The best I can tell, Bank 2 Sensor 1 is located on the exhaust manifold just behind the radiator. Is this correct? Also, is the correct part number for this sensor 36531-RDM-A01?
Thanks in advance, Jason
__________________
2004 TL- NBP, Navi, 6MT, Type-S Wheels, A-Spec Lip Kit
JBSTRD is offline   Reply With Quote
Old 02-11-2012, 06:56 AM   #2
Registered Member
Trader Rating: (1)
There are many tests that can be performed, but most need to be done with the Honda/Acura test equipment, but yes, that is the problem child and the correct sensor number. There are electrical values and continuity checks that can be made, but probably the easiest, although not the least expensive, is to just replace the sensor and give it a try.
Turbonut is offline   Reply With Quote
Old 02-11-2012, 10:14 AM   #3
Registered Member
JBSTRD's Avatar
Trader Rating: (0)
Quote:
Thanks for the reply. My plan is to monitor it and see if the CEL returns. If so, I will just suck it up and drop the $130 on a new A/F Sensor.
__________________
Old 02-17-2012, 09:08 PM   #4
Registered Member
JBSTRD's Avatar
Trader Rating: (0)
Just a quick update since I hate when I am searching and find good info, but people do not talk about their resolution.
Anyways, the CEL came back on after about 4 days. Went and checked the code and it was another P2254. I guess that is a good thing, huh? I ordered the proper sensor for Bank 2, Sensor 1 (Part #36531-RDM-A01) from OEMAcuaraParts.com. Should be here tomorrow. I will let you know if the CEL comes back on after the install.
***fingers crossed***
__________________
Old 12-25-2012, 10:35 AM   #5
New Member
Trader Rating: (0)
Did it work?
trileftwing is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help Please!!! ABS and VSA light with exclamation point ALL ON Jamus22 Problems & Fixes 18 02-07-2016 07:08 PM
Error codes stored in messages MilanoRedDashR Problems & Fixes 2 10-02-2015 11:49 AM
Misfire DTC and TSB 03-033 question thegipper Third Generation TL (2004-2008) 5 09-28-2015 02:01 PM
EGR Valve /Extended emissions warranty shawnafoxx First Generation RL (1996-2004) 2 09-28-2015 01:33 PM
Check Emissions CEL hrothgar02 Second Generation RDX (2013+) 1 09-28-2015 12:08 PM
Tags
2004, 36531rdma01, acura, acure, b2s1, back, bank, cel, code, codes, honda, installing, p2251, p2254, test, tl, troule
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
