P0453 - Evaporative Emissions Control System Pressure Sensor High Input - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 10-01-2012, 04:31 AM   #1
18psi
libert69's Avatar
Trader Rating: (7)
I cant seem to get rid of this code.
Things I tried.
Replaced fuel cap - no good
Replaced ftp sensor on evap canister - no good
Replaced evap purge valve - no good
Dont know what to do next. Already wasted 150$ on parts with no luck. Once I clear the code, it comes right back as soon as the car is started.
__________________
J&R Turbo 2004 6spd 500+whp...RIP :(
libert69 is offline   Reply With Quote
Old 10-01-2012, 09:01 AM   #2
LowNslowTL
nismopowerdqg's Avatar
Trader Rating: (0)
A P0453 code may be caused by one or more of the following:
  • Open on FTP sensor signal wire
  • Short to voltage on FTP sensor signal wire
  • Bad FTP sensor
  • Abnormally high pressure in fuel tank due to blockage in EVAP purge hoses or overfilled tank
  • Loose/damaged FTP sensor connector
  • Loss of ground to the sensor
hope this helps
nismopowerdqg is offline   Reply With Quote
Old 10-02-2012, 01:07 AM   #3
18psi
libert69's Avatar
Trader Rating: (7)
^yea ive read that list before.
was hoping that someone else had this code before and figured it out
ordered a used evap canister on ebay to see it that cures it.
__________________
Old 10-09-2012, 04:47 AM   #4
18psi
libert69's Avatar
Trader Rating: (7)
bump
__________________
Old 02-05-2014, 04:10 PM   #5
New Member
Trader Rating: (0)
I'd like to know how this problem was solved, I'm having thesame problem with my TL
row2ray is offline   Reply With Quote
Old 06-19-2014, 02:33 PM   #6
Registered Member
jpm3071's Avatar
Trader Rating: (0)
John-Paul Macedo
Any update on this?
__________________
RACING...Because football, basketball and soccer only require ONE ball.
Modifications:
235lbs via TL Diet, Full UCM, Stage 1 Exhaust, Sharkmouth mod, Carbon Rear Tail lights, Painted Muffler Tips, Progress Rear Sway Bar, 3000k HID Fog lights
jpm3071 is offline   Reply With Quote
Old 06-19-2014, 03:21 PM   #7
No Vaseline
Majofo's Avatar
Trader Rating: (0)
koobecaf rettiwt nideknil $2PlayNay NSP MARGATSNI
Majofo is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Triangle with "!" at startup, and VSA light after 30-40mph. Help! mada51589 Problems & Fixes 27 01-24-2016 03:42 PM
DIY: Converting DBW to Mechanical Cable Throttle with Working A/C cycdaniel Performance Parts & Modifications 2 10-05-2015 05:38 PM
Check Gas Cap Light? SpraykwoN Acura ILX Discussion 4 09-23-2015 12:44 PM
Tranny only 2 years old, pressure switches already bad??? HeloDown Problems & Fixes 4 09-08-2015 07:51 PM
Peugeot: Fractal Concept News Yumcha Automotive News 3 09-06-2015 05:40 PM
Tags
acura, code, control, emissions, evap, evaporative, high, input, p0453, pressure, review, rid, sale, sensor, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
