Not the best first thread. Bent a rod in '07 TL-S
Old 09-22-2015, 02:33 PM
5th Gear
STL TL-S's Avatar
Found the perfect car after a 3-4 month hunt at the end of last year. Found a very well maintained low mile 6speed type S. car currently has 83k miles on it.
Sunday afternoon I went through a low water bridge with about 5" of water. My airfilter down in the front bumper of the car took a drink killed it immediately. Hoping for the best, I stayed positive. My fears were realized yesterday after I drained down the whole motor, flushed it lightly with new oil, then changed the oil and plugs. Shot all the water of of the cylinders and put it back together. Fingers crossed....start up..... Knock knock knock knock.... Well F*#k!!!!
So now I am doing research on rebuilding/replacing my short block. Any tips or tricks with the heads or engine removal that I should be aware of? I can't find any engine build threads specifically.
Old 09-22-2015, 02:35 PM
5th Gear
STL TL-S's Avatar
Old 09-22-2015, 02:38 PM
Received 16,260 Likes on 11,971 Posts
I just recently bought a used J32 for $650. 100k miles...but who cares.
I paid a mechanic $650 + fluids to install.
check Car-Part.com--Used Auto Parts Market to find used engines in your area
Old 09-22-2015, 02:43 PM
5th Gear
STL TL-S's Avatar
Thanks for the link. I will check it out. I'll do the work myself, but want a low mile shortblock. I've found a 73k mile shortblock for $900 that is the winner so far.
Old 09-22-2015, 02:45 PM
I believe you can search for JUST the short block on that site, as well. Good Luck
Old 09-22-2015, 03:41 PM
Received 8,576 Likes on 6,626 Posts
sucks to hear OP
CAI i presume?
Old 09-22-2015, 03:49 PM
5th Gear
STL TL-S's Avatar
sucks to hear OP
CAI i presume?
You got it. Was on the car when I purchased it. It also came with the stock one. I'll be going back to stock when it goes back together. This one cost me a motor
Old 09-22-2015, 04:11 PM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
this is why I don't like CAI.
Old 09-22-2015, 05:46 PM
RnRType-S's Avatar
That's a bummer! Good luck with the replacement S/B
Old 09-23-2015, 08:52 PM
5th Gear
STL TL-S's Avatar
Well I started diagnosing a little bit ago. I'm not convinced its a rod. I don't want to get too excited, but I'm praying its something else. When the car is running (aside from the noise, runs perfect, no lights, smooth etc )
I pulled the connector from each coil killing the spark. It did not change the sound of the "knock" at all. Not even quieted down. This is giving me some hope it's not a rod. Next up is a compression test....
Jamus22
06-11-2023 10:08 AM
emailnatec
29
09-28-2018 04:27 PM
MetalGearTypeS
08-29-2016 08:28 PM
Quick Reply: Not the best first thread. Bent a rod in '07 TL-S
