No Fan or Air Conditioner - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 12-11-2010, 05:50 PM   #1
Registered Member
Trader Rating: (0)
Question No Fan or Air Conditioner
Anyone have any suggestions? Changing the level on the manual control for the fan has no effect, and there is no cold air even when the A/C is on Max Cold. It does have heat coming out (no fan) if I set the heat up high and select the vents.
I tried changing out Fuse 21 (Heater Motor) but it has no effect.
Car is a 2004 TL 6MT with Nav with 106,000 miles. By the way, I bought this car new and this is the first problem I have had since the cruise control on/off switch went out at about 35,000 miles.
Thanks in advance.
__________________
jime
15 Hyundai Genesis Ultimate my daily driver
09 Acura RL Advance/silver/ebony (hers)
14 Acura RDX Tech/Red Pearl (hers too)
jime is online now   Reply With Quote
Old 12-11-2010, 08:30 PM   #2
Registered Member
nfnsquared's Avatar
Trader Rating: (0)
Check fuse #30 (7.5 A) in the under dash fuse box.
If it's not that, there is a transistor that protects the blower motor. That may have blown as well. It's separate from the motor and is user replaceable. It's around $40...part #79330-S6M-941
Read this thread before you spend money on a new transistor:
http://tl.acurazine.com/forums/showthread.php?t=800460
The transistor is under the passenger side dash 2-3 inches above the edge of the carpet and at the firewall. I believe you'll have to remove the underdash cover to see it. Look for a 4-wire connector (wire colors are:BLU/BLK, BLU/RED, BLK, BLU/YEL) that plugs into the transistor. Two screws hold the transistor in.
__________________
04 6MT, Navi, WDP, chrome wheels, ASPEC suspension (08W60-SEP-201B), Clifford Matrix 50.7X RS/Alarm, Huper Optik ceramic tints. Original owner....
nfnsquared is offline   Reply With Quote
Old 12-12-2010, 01:52 PM   #3
Registered Member
Trader Rating: (0)
blower fan has to be running to make ac operate
on gen2 we have a prob with the connector at blower motor melting and failing,
often takes the resistor with it
Remove cabin air filters and ck there --might be able to see connector under edge of glovebox (Im gen2 not sure about yours)
01tl4tl is offline   Reply With Quote
Old 12-15-2010, 05:06 PM   #4
Registered Member
Trader Rating: (0)
Problem now fixed - thanks for the help. After doing a search on heater fan and reading several "DIY", I decided that I would let my mechanic fix it. It only cost me $130 and that included $55 (including tax) for the part.
__________________
jime
Old 05-05-2011, 06:38 PM   #5
Registered Member
Trader Rating: (0)
I am having the same problem...do you know what the fix was? The display shows the fan speed increasing when I adjust it up, but the fan isn't blowing and the A/C compressor isn't engaging.
It worked fine this morning and then just died when my wife was on her way back home from picking up my son from school.
I will check the blower motor connection tonight after reading the G2 problems they had. I have checked the fuses under then hood.
Any help would be great!
SILVRTL04 is offline   Reply With Quote
Old 07-06-2011, 07:36 PM   #6
Registered Member
Trader Rating: (0)
Add another member to the fail train :(
So............................................just another fucking bullshit problem to deal with on my "luxury" car. I already had to blow $140 on an APP sensor, and that was a great "deal". I need a new passenger window regulator, but haven't gotten around to that yet. anywho.. about the current issue:
A/C has been PERFECT and ice cold for the past 3 months I have owned it. Was working perfectly yesterday. Got in the car to leave for work this morning and the fan won't even come on, much less the A/C. I Bert stared at the display for a minute, and then when I pulled out of the driveway it came on. Worked normally for the 30 min drive to work. Got in the car at lunch, and same deal; nor fan or A/C engages. No sound, no nothing. Came on after driving a few feet. Please GOD, tell me this is a cheap and easy fix. If not, I may kill myself because a working A/C was a huge reason I got this car, so I could get through a Georgia summer comfortably, after the A/C went out last July in my 95 Accord.
gogators22 is offline   Reply With Quote
Old 07-07-2011, 09:01 AM   #7
Registered Member
Trader Rating: (0)
The problem is cause by a bad power transistor in the blower motor circuit. My cost to repair from my local mechanic was $51.00 for parts, $75 for labor and $5 for tax for a total of $131. I was told this problem was common with Honda Accords.
This was my first problem with the car in the last 40K miles and also the first that was not under the (100,000) extended warranty.
My extended warranty repairs (40K to 100K) consisted of only the cruise control on/off switch going bad at 70K miles. So the extended warranty was a very bad investment for me, but I purchased one of the earliest 2004 6MTs that came from the first 6MT production run (Nov. 2003) so I thought the extended warranty would be a good idea.
__________________
jime
The Following User Says Thank You to jime For This Useful Post:
gogators22 (07-07-2011)
Old 07-07-2011, 11:20 AM   #8
Registered Member
coykiam's Avatar
Trader Rating: (0)
Didn't you know Acura is a great "luxury" brand? Did I mention you get "luxury" service from the idiotic Service Advisors that only cares about bullshitting and not about their customer or reputation? I mean isn't it the reason why we pay a little more for luxury is to get less hassle?
Honda = Acura after all.....just add 1 more year warranty and the difference stops there. Oh...but warranty does not mean crap if the dealer can't find the problem. They'll just point the blame to their customers.
__________________
must resist the new car itch!
Impound vehicles with loud exhaust and radios!!!!!
Damn I'm gettin old!
coykiam is offline   Reply With Quote
Old 07-07-2011, 01:00 PM   #9
Registered Member
Trader Rating: (0)
I feel everyone's pain. For the price we paid for these cars you would think we would get a better car. We thought wrong. Dont believe the hype.
Tegnut is offline   Reply With Quote
Old 07-07-2011, 02:06 PM   #10
csmeance's Avatar
Trader Rating: (0)
I facetube, I think! Is it twitting? Twittering? Darn it! Linked-Out csmeance :idontlikemyinfostolen:
Just because you had 1 bad service experience you shouldn't be bad mouthing a whole brand of cars. Acura has been more reliable as witnessed on these boards than BMW's, Mercedes and other brands time and time again. And adding onto that Acura has tried to do the right thing over and over again to make the customer happy.
Take me for example, I bought an 06 MDX Touring and the battery kept on dying. Acura got me a new 2007 MDX Sport + Entertainment with my choice of accessories and a 10 year Acuracare warranty to show that they were sorry and wanted to fix their mistake.
Then take my TL, I got a new dashboard for almost FREE at 100K miles and a new transmission at 105K for the price of shipping and tax.
My warranty was up a long time ago however they saw I was a loyal customer who was willing to be calm and work with them and they helped me the best they could have. By you ranting on here shows how much you tried to work with them.
Quote:
Trust me, you haven't see anything with the price of this car. My 760 is upwards of $130,000 new and it's been with the dealer more times I can count. IN the last 2 years, my warranty has paid out over 22K worth of repairs for things such as transmission repairs, coolant leaks, electronics failures, etc.
__________________
2013 TL Advance 3.5L
2010 Honda Accord EX - Basque Red/Ivory
lOE Fog Lightsl
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
l426WHP/430WTQ V12l M5 Brake Conversion l
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
csmeance is offline   Reply With Quote
Old 07-07-2011, 05:03 PM   #11
Registered Member
Trader Rating: (0)
Is there a DIY for this?!?!?
Old 07-07-2011, 10:44 PM   #12
Registered Member
Trader Rating: (0)
How come its the BMW you have as your picture not your Acura's? Lol :rofl Just messing with you. You helped a lot of memebers on here. Me greatful.
Old 07-09-2011, 12:45 PM   #13
Registered Member
Trader Rating: (0)
guess I'm the lucky member to have an issue only one other person has ever had
Similar Threads
Thread Thread Starter Forum Replies Last Post
Black Vinyl Wrap iRaw Photograph Gallery 22 11-14-2015 01:29 AM
tsx 04 sparco seats tsx_boy Performance Parts & Modifications 2 10-22-2015 11:08 AM
2015 Formula One Fantasy League - Russia GP F-C Motorsports News 17 10-21-2015 08:17 PM
AC fan noise SexyRL Problems & Fixes 5 10-02-2015 08:29 PM
Driver Fan blower change mode by itself hashbrown Fourth Generation TL (2009-2014) 2 09-29-2015 01:13 PM
Tags
04acura, 2004, 2006, ac, acura, air, blower, blured, conditioner, fan, heater, install, mdx, tl, transistor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
