New Rack and Pinion self install?? - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 02-03-2011, 06:01 PM   #1
New Member
Trader Rating: (0)
I have a 2004 TL.
I hope that I don't have to do this, but instinct tells me otherwise. I'm leaking power steering fluid badly and it doesn't appear to from the recall hose. I'm running some Lucas Oil leak stop stuff through it now in hopes it's just a bad seal. I've researched prices on racks and doing it myself would be significantly cheaper than putting it in the shop.
I've searched the forum and haven't found anything specifically about a rack and pinion install.
Has anyone done this before? Any tips to share or pitfalls to look out for? Can it be done with a floor jack and tall jack stands, or does the job require a lift? Any guidance or help at all would be great.
JTM04 is offline   Reply With Quote
Old 02-03-2011, 07:40 PM   #2
Wiggy Wiggy Wiggy
powerflow's Avatar
Trader Rating: (0)
It would be too bad with stands.
__________________
>>>> FOR SALE: 04-06 3G TL OEM Exhaust, Houston TX
powerflow is offline   Reply With Quote
Old 02-03-2011, 07:44 PM   #3
Registered Member
nfnsquared's Avatar
Trader Rating: (0)
Hopefully you can trace the source of the leak and fix it. Unfortunately, our steering racks have been known to go bad....
If you have to replace the steering rack, you should consider replacing it with one from a TL-S. It's the same price and totally plug and play.
There is at least one thread where someone did that. Also, Steve5.9 had this done during his collision repair. Folks rave about the difference in feel.
Here's the thread:
http://tl.acurazine.com/forums/showt...=steering+rack
Here's Steve5.9's collision thread, go to post #155:
http://tl.acurazine.com/forums/showt...php?p=12569330
__________________
04 6MT, Navi, WDP, chrome wheels, ASPEC suspension (08W60-SEP-201B), Clifford Matrix 50.7X RS/Alarm, Huper Optik ceramic tints. Original owner....
nfnsquared is offline   Reply With Quote
Old 02-03-2011, 08:55 PM   #4
Trader Rating: (0)
Here's the thread:
x2.
justnspace is offline   Reply With Quote
Old 02-03-2011, 09:53 PM   #5
eg5
user title goes here
Trader Rating: (4)
take it to the dealer. subframe removal is recommended. you can get away with not doing it but it is very very difficult.
eg5 is offline   Reply With Quote
Old 02-04-2011, 11:03 AM   #6
Registered Member
Trader Rating: (0)
Find out where it's leaking first, hopefully its a hose or the plastic resevoir. If the rack is leaking usually you can find a considerable amount of oil/fluid in the left or right rubber boots/bellows, jack the car up & poke a little hole in the boots & see if fluid has accumulated in one or both of them. If so you need to get a reconditioned rack assembly.
I've not changed out a 3rd gen, I did change out my grandson's 97 TL, it was fairly std. mechanic work. Pump out the old contaminated fluid after the rack is removed, wouldn't hurt to then flush it out with some fresh fluid. You'll need your tie-rod ends put on your new assembly so measure them & count the # of turns as you remove them from old rack (one side is rt. hand thread, one may be left hand thread but not always), you need the "toe in" adjusted when finished, use Honda Fluid only. I did it on the floor with jack stands at all 4 points. I got a reconditioned rack from "Sam's Rack & Pinion & Axle" in Hollywood FL. (find on Ebay), excellent results after 3 yrs. now. This rack for the 97 TL was less than $200 shipped & core exchange.
johnny3 is offline   Reply With Quote
Old 02-04-2011, 11:25 AM   #7
Wiggy Wiggy Wiggy
powerflow's Avatar
Trader Rating: (0)
Oops, I meant shouldn't be too bad on stands.
It's sure not uncommon for a rack to fail on a car with 80K plus miles.
__________________
Old 02-04-2011, 06:07 PM   #8
New Member
Trader Rating: (0)
Thanks for the insight. I'm going to jack it up this weekend and try to pinpoint the leak. If the rack must be replaced I'll definitely opt for the type-s replacement.
Definite thanks for the links too, those are helpful.
If I have to replace it, I'll do it myself and document with pics and commentary and post here for others.
Old 02-04-2011, 09:08 PM   #9
eg5
Trader Rating: (4)
sounds like youre more than an average weekend shade tree mechanic. keeps us updated on the progress.
Old 07-09-2011, 02:41 PM   #10
Registered Member
Trader Rating: (0)
Any updates on this? I think I may have to do my wife's soon. ;(
frame is offline   Reply With Quote
Old 10-10-2011, 08:30 PM   #11
Registered Member
Trader Rating: (0)
the manual says you have to remove the steering wheel... is that true? seems like you could center it and leave it alone.
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: 05 WDP Acura TL FULL PARTOUT (ALL MUST GO) - Comptech, RV6P, Tein, Defi, Pioneer, AEM BoricuaTL Car Parts for Sale 111 01-22-2016 02:00 PM
Power steering rack and pinion replacement CaliBud916 Problems & Fixes 6 09-19-2015 02:56 PM
Clutch Pressure Plate Alignment TxRzrBk Problems & Fixes 0 09-17-2015 02:07 PM
Thule vs. Rhino Rack FC2012RDX First Generation RDX (2007-2012) 0 09-04-2015 03:05 PM
Height of 2011 MDX with OEM rack Snafunk 1G & 2G MDX Discussion (2001-2013) 1 09-03-2015 09:01 PM
Tags
04, 2003, acura, fl, hard, hollywood, instal, install, mdx, pinion, pinon, rack, replace, sale, sam, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
