Lock problem
Old 11-20-2014, 07:50 AM
9th Gear
Pull_Up_Selecta's Avatar
Lock problem
My 04 tl doors wont close with either the lock button on the door nor using the remote. Any ideas what this could be?
Old 11-20-2014, 07:52 AM
Received 16,260 Likes on 11,971 Posts
maybe a fuse problem.
maybe a lock actuator problem.
maybe lots of things.
get in there and investigate.
Old 11-20-2014, 08:08 AM
Make it so
DuoDSG's Avatar
Thumbs up
+1 to what justnspace said. Until you take a look inside of the door panel, you won't be able to diagnose the problem correctly.
I had a similar problem to you that my driver's side door wouldn't lock using any switches (manually it did work for me, thankfully). In my case it was both the door actuator and the wire cable that connects to it- the plastic casing on one end of the cable had split so the cable wasn't catching anymore, preventing the lock from remaining in place whenever I used my key fob or the button on the door.
Good luck!
justnspace (11-20-2014)
Old 11-20-2014, 08:17 AM
cars are like mini houses.
theres always something that needs to be fixed or looked at.
an inquisitive mind is needed to figure out what the problem is and how to solve it.
the first thing I would do; is tear into the door panel to see if the actuators and cables are actually working/connected.
or it could be a simple fuse that's burnt out
Old 12-01-2014, 02:40 PM
9th Gear
Thanks im going to open everything up on the weekend
SidhuSaaB
05-30-2020 12:40 AM
blacktsxwagon
10-27-2015 10:12 PM
Matthew Purpura
09-25-2015 06:10 PM
95oRANGEcRUSH
09-25-2015 12:50 PM
rboller
09-23-2015 02:49 PM
Quick Reply: Lock problem
