I need some help with an 04 TL
Memory seats & mirror tilt doesn't go down in reverse. Also the airbag illumination never appears when everything else does. I would really appreciate the help
Is the switch to adjust your mirrors positioned in the middle or on either the left or right mirror? The switch position must be on either the Left or Right mirror for the mirror to go down when put in reverse. When in the middle the mirrors does not go down
When switched to left or right in reverse they will not tilt at all and the memory seats 1 & 2 don't work and are not lit I'm not sure which fuse to remove
