how do I remove the glove box on 05 tl? - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 09-02-2009, 05:58 PM   #1
Registered Member
Trader Rating: (0)
I need to tighten the u shaped bracket that the glove box comes to when shutting it. It sounds like the screws holding it are loose and it vibrates on bumpy roads etc.
So can someone please easily describe how to safely remove it without damaging anything. it sounds like there are clips to remove???
Please help, want to fix this rattle today.
Thanks so much an advance!
Chad
Pureadrenaline is offline   Reply With Quote
Old 09-02-2009, 06:08 PM   #2
The DVD-A Script Guy
Adobeman's Avatar
Trader Rating: (0)
http://tl.acurazine.com/forums/showt...move+glove+box
This thread is how to replace the cabin air filter but to do that you first need to remove the glove box. Pictures are in the thread
Adobeman is offline   Reply With Quote
Old 09-03-2009, 12:43 AM   #3
Registered Member
Trader Rating: (0)
dude you ROCK! Thanks for this find. I'll report back when the rattle is gone!
Old 09-03-2009, 01:05 AM   #4
Registered Member
Trader Rating: (0)
Ok, I'm choked. My tl doesn't have the tabs on the inside of the box to use the flat head screwdriver to pop off. It's different? What year of tl is that in the pics?
What am I missing???
Old 09-03-2009, 09:40 PM   #5
Adobeman's Avatar
Trader Rating: (0)
Yeah, those picks are an 04. I just looked in my 05. No tabs, just squeeze in the same area of the glove box and you will see the tabs you need to clear. After that it's pretty much the same as I recall from when I did my cabin filter.
Old 06-03-2010, 04:47 PM   #6
Registered Member
mrsimeon's Avatar
Trader Rating: (0)
Chad
HEY did you ever Fix the RAttle in the Glove box...Mine is rattling and looks like it is coming from the right side of the glove box. IF i press the door shut hard enough the rattle stops.....????
anyone else have this problem?
__________________
2004 Acura TL 6SPD, Drive it LIKE YOU STOLE IT. BUT Take care of it. SKROFA
mrsimeon is offline   Reply With Quote
Old 06-03-2010, 06:01 PM   #7
csmeance's Avatar
Trader Rating: (0)
I facetube, I think! Is it twitting? Twittering? Darn it! Linked-Out csmeance :idontlikemyinfostolen:
Yes, the clips can come out or become loose, take out the glove box and then the trim piece behind it (the one that comes out to change the air-filter). Check to make sure all the clips are there, and if they are carefully put the piece back (make sure the tab on the side goes in properly) and hit it to make sure it's in place. Put the glove box back and and see if it rattles!
__________________
2013 TL Advance 3.5L
2010 Honda Accord EX - Basque Red/Ivory
lOE Fog Lightsl
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
l426WHP/430WTQ V12l M5 Brake Conversion l
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
csmeance is offline   Reply With Quote
Old 06-04-2010, 08:34 AM   #8
Q('.')=O
imj0257's Avatar
Trader Rating: (1)
Yea what they ^ posted above. I was weary doing it my first time to replace my cabin filter but it is easy as pie.
__________________
'04 SSM TL ...w/ stuff
imj0257 is online now   Reply With Quote
Old 06-04-2010, 02:45 PM   #9
Registered Member
Trader Rating: (0)
Just go slowly when you take the back of the glovebox (trim piece) out...making sure how the tabs/clips come out. And be sure to take your time putting them back in slowly to make sure they are all in.
Going out...start from right and work your way left.
Going in...start from left and work your way right.
Be sure to use some strong force to get them to pop back in, but go slow and if it doesn't feel right, don't overly force it.
I was too anxious the first time I did this, pulled it all out...broke a clip, and then had a bear of time figuring out how it snapped back in. Not hard, but just took some time.
Musky300 is offline   Reply With Quote
Old 06-04-2010, 04:28 PM   #10
Registered Member
Trader Rating: (0)
This is unrelated but do any of you know how to replace the vanity mirror lights? I would appreciate the help
cowboys9193 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: 3G TL Parts LoneRonin Car Parts for Sale 2 01-04-2016 02:03 AM
FS: Neuspeed Sport Springs!! eastsideride Car Parts for Sale 6 10-15-2015 05:26 AM
Not the best first thread. Bent a rod in '07 TL-S STL TL-S Problems & Fixes 9 09-23-2015 09:52 PM
Access to adding Transmission fluid ROSSARONIE Third Generation TL (2004-2008) 6 09-22-2015 12:46 PM
Shifting Gears (6MT): Help diagnose the problem SidhuSaaB Problems & Fixes 0 09-22-2015 11:32 AM
Tags
05, 2005, acura, box, dvd, glove, glovebox, lock, nav, removal, remove, replace, rsx, tl, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
