-07 Type-S low RPM stumble [Video]
Old 08-13-2023, 12:08 AM
jdmvette's Avatar
Car has recently been having low RPM stumble (<2000) but is throwing no codes. Video is showing neutral examples but this stumble is also present during takeoff or at highway speeds if the RPM drops below 2k. 🤔
The car drives fine at higher RPM but something ain't right...
Any help will be appreciated.
Old 08-14-2023, 07:28 AM
jdmvette's Avatar
Old 08-14-2023, 08:45 AM
Received 1,732 Likes on 1,390 Posts
Welcome to a dying forum.
Has the throttle body / upper intake been cleaned lately?
Old 09-04-2023, 10:32 PM
Robbym's Avatar
I had a very similar issue and it was my EGR valve stuck open. This was when my high flow cats were failing and a small piece of cat material got logged in the EGR valve allowing unmetered air to enter the engine. If it’s not that then you might have a small vacuum leak.
Old 09-05-2023, 04:42 AM
jdmvette's Avatar
Thanks @Robbym
How does one go about servicing the egr valve? Haven't dug too much into that area
Old 09-10-2023, 05:06 PM
jdmvette's Avatar
So I dug into the area today to clean it up some and put in a shiny new EGR
Put everything together and it seems to have fixed about 75% of the issue.
Car seems much smoother at low RPMs
Old 10-29-2023, 05:16 AM
jdmvette's Avatar
so the problem is now 100% resolved. the issue wasn't the EGR or any other nonsense like that.
the problem was the fake-ass counterfeit NGK plugs that came from Amazon which had all lost their igniters.
i put in new, real NGK plugs i picked up from O'Reilly's and the car is running perfect. no stumbling at low RPMs, perfect idle, strong power and I am a happy camper again.
Jackass (10-31-2023)
TLisious
4G TL Problems & Fixes
08-25-2014 05:18 PM
paperboy42190
10-22-2013 11:05 PM
WILLDOGS
10-04-2004 10:41 AM
Quick Reply: -07 Type-S low RPM stumble [Video]
