DIY: Flaccid Armrest Cushion Replacement
#81
http://www.foamforyou.com/Open_Cell_Foam.htm
Luxury firm high dense or tough luxury foam high dense as options.
Have to buy a pretty big piece for 1/2 thick. 8 or 14 dollars plus 10+ dollar shipping. But it looks pretty good?
sauceja (12-19-2012)
#83
#86
Eurotrash
I found that it is not necessary to fully detach the leather from the plastic base, leaving it attached on one of the long sides. I used a high density foam about 1/4 inch thick, trimmed it to size, and glued it down in some spots along the perimeter to keep it in place. Then I used 'Loctite Vinyl, Fabric, & Plastic Flexible Adhesive' in a tube to glue the leather cover back on. This adhesive gives a fairly long working time for you to stretch and massage the leather cover tight back into its original position. Keeping the leather warm and pliable helps...
Pitinzki (08-25-2013)
#90
Eurotrash
While the Redlinegoods.com looks like fairly high quality stuff, judging by these photos of the CL and TL from their website, it also doesn't appear that it matches the original low-quality Acura leather...
#92
Many colors, the picture above shows a contrasting color, check the stripe, it matches the seats.
Here's mine, black with white because I have a WDP.
#94
Registered but harmless
Received 1,102 Likes
I bought 1/2 yard for $6.
The 1/2" foam is the perfect thickness for the sides, but I was thinking I could have tried fitting a second layer at the top of the armrest to make it plusher.
#95
I second guessed it as well but there wasn't any 1/2inch in stock. I used the 1" and if you can get the leather to wrap around enough than I think it is well worth it. I actually cut a lot off the sides to the point that I don't really have any there. It has no negative affect on anything though as I don't rest my arm on the side of the rest.
#96
:what:
Several of us have used the 1" with great success. The leather will stretch over the extra padding. It does compress some...its only natural that it would...but if you want to know exactly how much, you can go ahead and measure after you do yours and report back. It's not rocket science or blue printing. It's just padding. Not even worth measuring.
sauceja (05-15-2013)
#98
I'm gonna do my 03 CL soon. I already bought 3/8" carpet padding, which is probably thicker then the original. I'm not sure how it compares in density/firmness, as the padding was already shot when I bought the car.
#100
I still may wind up biting the bullet and buying a new one, if the cover starts coming loose.
I salute your guys for your efforts and abilities!
#101
Desert Life Sucks!!
LOL mine didn't go all the way to the original position but pretty damn close.
I trimmed some of the padding down at the corners and stretched the leather.
Nobody will ever see the bottom except you. The 1" is well worth it. My elbow feels as if in heaven everytime I drive my car.
Plus I have a 6mt so I am constantly in that area. With my arm rest slid forward I am at a perfect position to change gears.
#102
This can be done on the doors as well.
Also, just an idea, stuff two gel foot insert or a 1/4" yoga mat on the bottom layer, then as much high density as possible above it.
This will let it feel soft to flat surfaces (your forearm) and soft to pointy surfaces (your elbow). Because the gel or mat (MLV) won't let your elbow go through to the bottom.
Second skin MLV would probably be ideal...
#107
I used the 1" foam and the super 77 spray adhesive. The foam worked out great. The adhesive on the other hand did not. The leather keeps peeling off of the plastic. I even took it apart again and completely cleaned all the old glue off and scuffed up the plastic and then used binder clips to hold it to the plastic and let it sit overnight. Still a no go. Now I need to find something different to glue it with. I might try gorilla glue as it is a little more permanent.
#109
I did wait until the glue was super tacky and then pulled the leather and clamped it. I think there is too pressure from all the foam that is inside the leather. I really have to pull hard to get it over the plastic. I could trim more foam off, but I like the way it is and don't want to do that.
#111
I need to do this. Considering using maybe 3mm neoprene as a base and wrapping 1/2" high density foam over it. Should solve the problem of your elbow bottoming out in foam. Or maybe the 1" foam is enough for that?
#114
Desert Life Sucks!!
Why? Because Acura cheaped out on consumer comfort??
I don't use the door armrests because I have to have my left hand on steering wheel and right hand at the ready to shift gears.
That's why I love this armrest mod and the fact that it slides right up to the shifter.
#116
Tired of flat hard armrest
I have a very sharp elbow and with the 6MT, I could use a bit of cushion. My wife thinks to do this would be a waste of time but she will be out of town in a week or so and so I will probably do it while she is gone and then see what she thinks after the mod...Kinda of a drag to be such a nice car and have the center arm rest look so crappy.
Thanks for the DIY.
WhatFurrer
Thanks for the DIY.
WhatFurrer
Slpr04UA6 (02-24-2014)
#118
Stay Out Of the Left Lane
Received 1,236 Likes
I need to do this as well. Probably wait until the weather gets a little warmer so the leather is more pliable.
Thanks for the write - up!
