Changed starter still doesn't work
Old 07-05-2013, 08:39 AM
Nik83's Avatar
I changed my starter and my car still won't start. I started a thread last week about my car not working any other idea whatnot could be. Dealer said it was starter and obviously he was wrong!! I need help
Old 07-05-2013, 08:42 AM
MMkay.
Project_CLean's Avatar
Did you check your battery?Make sure your connections were clean and tight? Does it turn over? Or no sounds at all from the motor?
Old 07-05-2013, 08:51 AM
Received 16,260 Likes on 11,971 Posts
very odd, so the dealer gave a non working car back to you????
I dont think that would be the case.
Old 07-05-2013, 09:00 AM
MMkay.
^this.
Who did the repair?
Old 07-05-2013, 09:02 AM
Originally Posted by Project_CLean
^this.
Who did the repair?
right, you cant blame the dealer if they didnt perform the work....
you cant blame us for "suggesting" a fix.
if its not the starter, you're going to have to trouble shoot yourself.
is battery good?
is battery connections good?
is starter good?
did install of starter go well?
is there any lights on the dash?
Old 07-05-2013, 09:03 AM
Nik83's Avatar
Took the battery out and had it tested and its good. I did the replacement on the starter. The funny thing is I took the old starter out and had someone tested it and the starter has power?? I know kind of weird so if its not the starter or battery, what could it be? Relay? Ignition switch?
Old 07-05-2013, 09:06 AM
is their fuel in the tank?
is the car making any kind of noise when you try to start her up?
Old 07-05-2013, 09:17 AM
Nik83's Avatar
I didn't blame anybody for anything! I also assumed that it was the starter and I always work on my own cars and that's why I come to this forum for suggestions and its much appreciated!
Old 07-05-2013, 09:26 AM
Sounds like blame to me.
Old 07-05-2013, 09:30 AM
MMkay.
Okay man, you need to give us alll the information:
YOU changed the starter? -Did you double check all your connections? Not only to the battery but to the starter itself? Especially the solenoid wire.
Your old starter had power? That doesn't surprise me,as it's usually the solenoid WITHIN the starter motor assembly that is the problem,however you can't replace the solenoid itself.
Is the battery clamped down tight? Are the connections clean and free of corrosion?
What does the car do when you turn the key? Do you hear a Click? Does it crank but not start? Does nothing happen at all? Are there any lights on the dash? Does the car even have power? Do the interior lights dim when you try to crank it? What kind of starter did you buy? Are you pressing in your clutch pedal when you try to start it? Not being an ass, it's just sometimes when I get excited I myself forget to do obvious things.
I guess what i'm really saying, you need to be more clear in what you're doing and what's happening.
justnspace (07-05-2013)
Old 07-05-2013, 09:47 AM
YeuEmMaiMai's Avatar
Things to check in THIS order
1. Battery- take it out and LOAD TEST IT
2. Check for power at solenoid when the key is in the CRANK position
3. Find starter relay and test it
Nik83 (07-05-2013)
Old 07-05-2013, 09:51 AM
Nik83's Avatar
Doubled check every wiring from starter to battery! Teated every wire connected to starter Checked the clamps on the battery( snug tight) when I turn the key over it does not make any noise just a single click when I step on the clutch all the way. All the lights in the dash are working fine
Old 07-05-2013, 09:53 AM
dun dun dunnnnnnnnn!
post #12 we find out that its a 6 speed manual....
Old 07-05-2013, 10:00 AM
Nik83's Avatar
@justnspace- if you recall on my last thread #3 I did mention that I have a manual!
Old 07-05-2013, 10:23 AM
thats the thing tho; I dont recall.
you started a brand new thread leaving out TONS of detail.
if you kept it in the same thread, then we can easily read whats going on, what your symptoms are, what you tried to do, where we went wrong, etc.
by starting a new thread, you're basically starting all over and have to re-state your details...
The following 2 users liked this post by justnspace:
Nik83 (07-05-2013), thoiboi (01-09-2015)
Old 07-05-2013, 10:39 AM
Nik83's Avatar
I apologize, I am new to this forum and I'm just starting to get use to it and I find that this forum could be helpful if I just stayed on the same thread and aggravated at the same time trying to figure out what's wrong.
Old 07-05-2013, 10:42 AM
Turbocoop's Avatar
Need more info- do all the accessories work when the key is on "acc", lights, radio, etc....? If so it is not a battery issue. Can you hear the starter solenoid "click" when you turn the key to "start"? If so the starter is engaging but not turning the flywheel, I think you said you heard the click so this might be the case. The engine isnt turning over for some reason, need to figure out why. Check all the fuses, I mean ALL of them- under hood and under dash. Might be a security system thing...
Old 07-05-2013, 11:01 AM
MMkay.
Sorry, but that is incorrect. Though the battery may have enough juice to power the radio and accessories, a drop in voltage would NOT be enough to crank the starter.
NIK, you say you tested the connections..mind if i ask how?
Old 07-05-2013, 11:03 AM
MMkay.
I only knew cause im the one that called him on the double threads under different user names. lol, OP, you have to be more patient,we're not a retail shop that provides instant service and are just waiiiting for you to come and post a new thread. Just regular guys that want to help.
Old 07-05-2013, 11:06 AM
MMkay.
https://acurazine.com/forums/3g-tl-problems-fixes-114/2007-acura-tl-type-s-wont-start-had-battery-starter-checked-everything-ok-891017/
https://acurazine.com/forums/3g-tl-problems-fixes-114/2007-type-s-wont-start-sometimes-818417/
Old 07-05-2013, 11:20 AM
Nik83's Avatar
Multimeter, I just went to turn the key again and now there is no single click it did before! All the lights on the dash works like normal did checked all the fuses under the hood and under the dash I am completely lost! I came to this forum to get help and you guys are doing a great job trying to help me out and this forum can help you save A LOT of money. Lol but any advice helps
Old 07-05-2013, 11:31 AM
MMkay.
Do you have a jumper pack? Or jumper cables and someone that can give you a jump?
Old 07-05-2013, 11:36 AM
pohljm's Avatar
As you are a manual.................Will it bump start? My money is still on the battery
Old 07-05-2013, 11:45 AM
Nik83's Avatar
Nothing
Old 07-05-2013, 11:46 AM
pohljm's Avatar
One word answers are not going to help us diagnose your problem. what happens if you try and bump start it.
Old 07-05-2013, 11:56 AM
Nik83's Avatar
That didn't work either! But good idea
Old 07-05-2013, 12:03 PM
MMkay.
What didn't work ? Jumping it or push starting as pohljm suggested?
Old 07-05-2013, 12:23 PM
Nik83's Avatar
Both methods
Old 07-05-2013, 12:30 PM
MMkay.
Then you have bigger problems.
Old 07-05-2013, 12:33 PM
lol this question was never answered....
Does it have fuel in the tank?
Old 07-05-2013, 12:35 PM
Nik83's Avatar
Lol fuel is full!
Old 07-05-2013, 12:53 PM
Turbonut's Avatar
I assume the battery is good from the conversation, so with the lights on clutch depressed, engage starter and hopefully the lights stay bright and don't dim considerably, then go to the starter. You stated wiring is fine but noise is heard from starter, so if starter noise is heard when ignition turned to start, naturally with clutch depressed, starter problem.
If you have 12 volts at main, the solenoid value should be 12 volts with ignition to start and clutch depressed, so if still no turning, starter.
You can test the starter if it were out with jumper cables, positive to starter terminal, negative to starter housing and with a screwdriver touch the main post and solenoid contact to see if drive comes out and spins.
What's the brand of replacement starter?
Old 07-05-2013, 08:11 PM
Nik83's Avatar
Ok so I changed the starter and car still does not work. I jumped start and pop start it and nothing. All the lights in the interior and dash boards work as normal. I did check the starter by doing what the last post said to do and it worked fine. Tomorrow I will try the ignition switch and we'll see what happens from there. If anybody have any ideas please share lol
Thanks and bunch guys!!
Old 07-05-2013, 08:12 PM
Nik83's Avatar
Oh and I also replaced the battery just for the hell of it and nothing
Old 07-05-2013, 10:48 PM
AndrewA's Avatar
run a jumper between the starter "S" terminal and the battery and see if it tries to turn over. if so, then your problem is electrical and somewhere between your battery, fuses 22 and 23 (under hood), ignition switch, starter cut relay (under dash), and your clutch interlock switch.
start with the jumper and let's go from there.
Old 07-05-2013, 11:12 PM
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
I hate to ask this but when you push started it, was the key in the run position? The interior lights being on might not mean the battery is good but if they do not dim when you're trying to crank, it's not the battery.
Failure to push start eliminates the starter and more than likely the battery and clutch interlock.
Time to look upstream of the starter. Maybe something simple first such as the ignition fuse.
Old 07-06-2013, 05:49 AM
is your immobilizer working properly? (does the green key flash and then go out when you turn the car on)?
Old 07-06-2013, 07:43 AM
MMkay.
I was just thinking about what IHC said, maybe a fuse? But the OP said he heard a click, which means he must be getting SOME type of power to it.
Old 07-06-2013, 07:55 AM
Turbonut's Avatar
Old 07-06-2013, 08:38 AM
Nik83's Avatar
The ignition wire to the starter has 12v checked every fuse in the car. Post's #35 and #36 I did that and nothing happened
Quick Reply: Changed starter still doesn't work
