CEL Light - Misfire in Cylinder 1 and 4 (Acura Dealer Baffled)
2005 Acura TL
Hello all -
Just wanted to get some insight to see if anyone had any ideas as to what might be causing my problems (it seems that the dealer is having some issues getting to the root of the problem).
Background:
Driving to another town - about 80 miles or so until i reach my destination, the CEL comes on. I drive carefully until I reach my destination (with my eye on the temp gauge). No noticeable difference in driving, although when i finally got off the high way, I did notice the car was idling rough.
Parked the car and left it sitting for a couple of days. As I leave town, car is ok until I get back on the highway, this time the CEL is blinking and the car is driving very rough and feels like there is no power. Drove 50 - 60 miles to a safe spot and when the car became undrivable. I was watching the temp gauge as well.
Diagnosis:
I ran the codes and the codes that popped up were:
P0154 - O2 Sensor Circuit No Activity - Detected Bank 2 Sensor 1
P0301 - Cylinder 1 Misfire Detected
P0304 - Cylinder 4 Misfire Detected
P0300 - Random/Multiple Cylinder Misfire Detected
Acura took a look at it this morning and found the the coils on 1 and 4 were fried, so they replaced those. With no noticeable difference.
They then checked the compression and tests came back negative (compression is fine).
I just approved them (3 hours of labor for more diagnosis - ~$450 - OUCH!) and they want to check out the fuel injectors to see if thats it.
So they actually seem to be a bit stumped as to what the problem is, which is a bit concerning.
They also asked me if the car had overheated at any point (thinking the heads might be warped), I dont believe this to be the case since I had watched is closely as soon as the CEL came on. Also, I would assume if the heads were warped the compression would be bad.
Anyways, anyone have any ideas as to what else it could be?
Background:
Diagnosis:
The fact that it's 1 and 4 should help with troubleshooting, it's isolated to the left side (looking at the head) of the engine.. gasket leak on that side perhaps... I'm really pulling at straws here though..
The following 2 users liked this post by justnspace:
cray159 (08-05-2015),
nfnsquared (07-27-2015)
I've seen this before. In fact, I just has an 04 TL about two months ago with the problem. I've got about 15 pics of everything, from the melted coil pack, to the totally trashed ECU (I dumped out enough water to fill a dixie cup). What actually happened was the customer took it to a quick lube place (I won't say the name), and the "tech" (I use that term lightly) decided he was annoyed that the A/C drain tube was dripping water on him.
So, he decided to stick a bolt up it. And then never took it out... So water built up in the tube, then the HVAC housing, and finally poured out ontop of the ECU. Which caused multiple shorts, not just to the coil pack, but to some other sensors.
And while we're talking about it, this is the SECOND time in two years this same place has caused this. And let me tell you, it's not fun to remove a totally melted coil pack from the rear bank...
All in all, the customer was quoted $1800 to fix everything (ECU, coil pack, diag, labor for coil pack removal, etc). Needless to say, because of all the pics I took, and detailed write up I did, the quick lube place ended up footing the bill, no questions asked. Trust me, it was pretty obvious!
So yes, the above is a very true scenario of what could have happened. To the OP: I bet they can get the coil pack out, it'll just take a few hours. I was able to, and trust me, this thing was literally melted solid into the spark plug tube. On the flip side, maybe they truly can't get it out, in which case the head would need to be replaced.
If I get around to it, I'll post of the pics from the car I was talking about.
2005 Acura TL
Thanks for the reply guys - I'm waiting for a call back to double check and confirm the spark plugs 1 and 4.
I'll also mention the AC drain to them as well.
I'll keep you guys posted.
2005 Acura TL
It seems after I gave them the go ahead to do the $500 diagnostics, its hard to get a call back!
yup
justnspace (07-27-2015)
2005 Acura TL
Welp, no call back after I left two messages over 4 hours ago and to top it off the website is closed and the service department closes an hour earlier than the website says.
I guess I was a little naive to believe a dealership could provide decent service (even if it was a referral).
2005 Acura TL
Called this morning and they are going to call me back with an update (what a mess).
I asked them about the spark plugs and they still weren't sure if they were checked - boggles my mind. Seems like the natural progression of things to check would be: Oh melted coils! We should probably check park plugs.
Asked them about the o2 sensor - couldn't get an answer if they checked it, kept punting on the question. Maybe they aren't getting that code?
I told them about the AC drain tube getting clogged up and frying the ECU. They said that would almost be impossible since the excess water would leak into the cabin and not onto the ECU. So, sounds like they are tossing that theory aside.
If it ends up being spark plugs, I'm not going to be a happy camper. Should hear more in about an hour.
I can almost guarantee it's not the plugs. Tell them to check the carpet on the passenger side for wetness.
I still say it's the drain tube and your ECM is fried...
Where did you have your last oil change done?
2005 Acura TL
Also, I noticed on my trip my AC also was struggling.
"Acura took a look at it this morning and found the the coils on 1 and 4 were fried, so they replaced those. With no noticeable difference."
The coils are not fry. Dingdingding.
"They then checked the compression and tests came back negative (compression is fine)."
The plugs are fine. They've already been check.
Justin's theory is definitely getting more and more likely... You should throw money at him instead of the dealer.
2005 Acura TL
Well looks justnspace was correct!
They said that there was water on the ECU and they want to replace that. They asked me if I went through any high water (which I hadn't) and I asked them if they had found a screw/bolt or anything blocking the drain tube that would cause the back up.
They said they weren't sure - so I asked them to check and they would call me back.
They are quoting me $2,800 to replace coils and change out the ECU. They think they may have to remove the head an look at that - which would be an $1,000 dollars.
OUCH!
OUCH!
Welps looks like you're being taken for a run by the dealer and now that you've given them what needs to be fixed, they're asking for your to bend over to take it.
Good luck OP, hope they use lube, that sounds extremely expensive..
The DVD-A Script Guy
OP: You really can't toss this one aside. It may not be the problem but it should be ruled out.
Also See:
https://acurazine.com/forums/problem...ed-ecu-720388/
https://acurazine.com/forums/problem...advice-739328/
I'll say it again:
ding, ding, ding
I really doubt the head has to be pulled. If the ECU is replaced and there are no more mis-fires, then you're probably OK.
Any indy mechanic will have to have a HDS to install the ECU, so ask ahead of time.
ding, ding, ding
2005 Acura TL
I just got off the phone with them again - they checked the drain tube and they said there was no sign of it being plugged up. There has been quite a bit of flooding around here lately as well, so that could be it as well.
And you should charge them $450 for diagnosing the issue
2005 Acura TL
- Cabbed it to the dealership, ~$50 during rush hour since I needed a car the next morning. Took them 4 hours to call me back and tell me they had a car ready, if they had called me an hour or 2 earlier would of taken me 30 mins to get there instead and 1.25 hours)
- Wouldn't let me take my toll tag out of my car to put in the loaner car.
- First loaner car had no gas in it.
Story keeps getting better.
Sounds like someone needs to start a case with Acura Client Relations...
Document everything.
2005 Acura TL
I'm in Texas as well and I was under the impression (or the way I've always done it before) is you could just pop the tag out and put it on the dash of a new car?
^you can.
I'm in houston. ours is called EZ-tag. head to EZ-tag website to add the loaner car to your car list.
its free and easy.
our EZ tags have been upgraded to a single flat sticker that encases the RFID chips. so, its pretty hard to remove sticker without damaging.
the website to add a loaner car is easier.
its free and easy.
2005 Acura TL
^you can.
its free and easy.
its free and easy.
But its still an old school tag held on by velcro so easily removable. So I was always able to just pull it off easily and keep it on the dash of the new car. I never notified anything or updated anything - which maybe I should of? But I don't recall any problems stemming from that.
justnspace (07-29-2015)
