Acura VSA /!\ and SRS light on - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 10-23-2011, 09:14 PM   #1
New Member
Trader Rating: (0)
Hello all
I am new to this forum. I tried to search for information of tl 2008 type s vsa error code 84 anybody know what is wrong with that code, and srs light error code 85-64 ( i could not reset by paper clip like the thread in here show ) any help is appreciated. Thanks in advance
Kayacura is offline   Reply With Quote
Old 10-25-2011, 12:58 PM   #2
LoveMyTL-S's Avatar
Trader Rating: (0)
micheal.cain
Anyone?
__________________
2006 Honda CR-V (Sahara Sand Metallic)
2008 Acura TL-S (Carbon Bronze Pearl)
| iJDMTOY | Drop Stop | vLEDS | Trunk Tray | All Weather Mats | Plastidip |
Car of the Month Contests are going on now! Is your car good enough to win our monthly contests and possibly be our 1st Car of The Year for AcuraZine? Click here and Sign up for this month's contest today!!!!!!!!
LoveMyTL-S is offline   Reply With Quote
Old 10-25-2011, 08:58 PM   #3
Get Out Of The Left Lane!
NBP04TL4ME's Avatar
Trader Rating: (0)
Not sure if it applies across models but
Error Code 84 - VSA sensor neutral position memorization
http://tl.acurazine.com/forums/showthread.php?t=761015
http://tsx.acurazine.com/forums/showthread.php?t=679631
ServiceNews Article Feb 2008
Helping you fix it right the first time - every time
The VSA modulator-control unit can cause the VSA system indicators (ABS indicator, brake system
indicator, VSA indicator, and VSA activation indicator) to come on with VSA DTC 121-21 (VSA solenoid
valve malfunction: right-front and left-rear regulator valve).
If you get a vehicle in your shop with this problem, replace the VSA modulator (the control unit is a part of
this assembly). Refer to pages 19-169 and 19-170 of the ’05–07 Accord Hybrid S/M for instructions.
(Online, enter keywords VSA MODULATOR and select VSA Modulator-Control Unit Removal and
Installation from the list.) All replacement VSA modulators in Honda parts stock have been fixed for this
problem.
Make sure that you follow the removal and installation steps to the letter, especially the VSA sensor
neutral position memorization. If you don’t, you’ll wind up with DTC 84-21 (VSA sensor neutral position not
writing).
__________________
2008 TL Type S NBP/Ebony 6 Speed (His) - 8.5" Gun Metal A-Specs - Escort 8500 X50
2007 Lexus ES350 (Hers)
2009 Honda Accord EX-L (Kids) / 2007 Honda CR-V EX-L (Kids)
2007 Acura MDX Tech/Ent Nimbus Grey/Ebony (Traded)
2004 Acura TL NBP/Quartz 6 Speed with Nav (Traded)
NBP04TL4ME is offline   Reply With Quote
Old 10-26-2011, 08:05 AM   #4
Registered Member
Trader Rating: (0)
i had the VSA light come on today also on my way to work. Not sure what triggered it.
blkmz3 is offline   Reply With Quote
Old 10-26-2011, 10:48 AM   #5
New Member
Trader Rating: (0)
Thanks for replying guys
NBP04TL4ME: I already tried these steps at your links, but none working for me. I have no ABS light on, just vsa and triangle light.
Old 10-26-2011, 10:57 AM   #6
Registered Member
Trader Rating: (0)
I only have the /!\ light on at the moment. I'm thinking it might be the brakes or wheel speed sensor. The VSA would come on if it had to do with the traction control. The right passenger tire is more worn than my driver or it could be tire pressure. I was wondering if you can get this scanned or not?
Old 10-26-2011, 08:42 PM   #7
Registered Member
Trader Rating: (0)
I had this happen to me and my tire pressure was too low. aired them up to spec (32psi for 17" wheels) and it never came back. Hopefully its that simple for you
The-Chemist is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Triangle with "!" at startup, and VSA light after 30-40mph. Help! mada51589 Problems & Fixes 27 01-24-2016 03:42 PM
OEM Battery Failed Me gemz_acura Problems & Fixes 15 09-26-2015 07:12 PM
swapping my base 3.2 for a 3.2 Type S questions Allen_442 Second Generation TL (1999-2003) 10 09-08-2015 07:01 PM
VSA/ABS/SH-AWD/E-Brake on dashboard Stu2414 Problems & Fixes 2 08-30-2015 08:30 PM
Tags
350, 84, 8421, accord, acrua, acura, code, dtc, fix, honda, light, rl, sensor, srs, vsa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
