84-1 sensor logic failure - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 05-20-2011, 01:22 PM   #1
Registered Member
lankanboy1's Avatar
Trader Rating: (0)
I got a 05 Tl Auto with traction control light on as soon as i start driving couple of meter my Vsa comes on. got the code read and came to 84-1 sensor logic failure.
well this what happen first few months back, my ABS VSAand traction control comes intermittently, and my front passenger wheel bearing was bad so i changed the bearing after that The ABS VSA TC was on so i get the code read and found all theese
1.11-1 Right front wheel speed sesor open or short
2. 21-1 Right front pulsan failure
3.-Battery Voltage low ( CAR WAS PARKED FOR 1 WEEK before the scan" ACURA BATTERY ")
4.83-1 Ecm Pcm related failure
5.86-1 Can Related failure
After clearing all those only
11-1 Right front wheel speed sesor open or short Came back
so i got the front pass wheel sensor replaced after that i get only TC light on as soon as i start driving i get the Vsa light on So i get it scanned and i get 84-1 sensor logic failure What now ?
lankanboy1 is offline   Reply With Quote
Old 05-21-2011, 06:44 PM   #2
Registered Member
Trader Rating: (0)
You damaged the wiring to the wheel sensor, damaged the sensor itself, or damaged the reluctor ring or forgot to replace the reluctor ring.
__________________
'06 TL Dynaudio182/430/110 2x ID Max15s 2x JL HD600/4, HD750/1, PS8..255/40 RS-3..H&R FSB..Progress RSB..A-spec+Konis..Stoptech 13" BBK..Redline 0w40..Redline ATF PSF '84 GN602rwhp 620lbs tq 3,000lbs.Awaiting the heart transplant..4.5L 2,300hp in 2015.
'14 Giant Trance SX '14 328i
I hate cars is offline   Reply With Quote
Old 05-22-2011, 09:47 AM   #3
Registered Member
lankanboy1's Avatar
Trader Rating: (0)
whats the reluctor ring ?
were it is ?
is it on the axel ?
Old 06-04-2011, 11:29 PM   #4
Registered Member
lankanboy1's Avatar
Trader Rating: (0)
So i get my hands on The Gna600 Scanner witch the dealer use and found out that it has 2 codes now 84-1 and 86-1 and i cant seem to clear the codes for some reason.
i dont think the reluctor ring is damaged because all the wheel speed sensor is giving the correct speed.
Old 06-09-2011, 02:41 AM   #5
Registered Member
Trader Rating: (0)
I'm having the same problem right now just came on tonight.
__________________
Lock it up or go home!!
TLGuyNY is offline   Reply With Quote
Old 06-09-2011, 02:52 AM   #6
Registered Member
Trader Rating: (0)
Does your scanner show individual wheel speed? The vehicle speed sensor is on the transmission, not the wheels. This is what's displayed when you look at vehicle speed.
__________________
Old 09-30-2012, 07:36 PM   #7
Registered Member
Trader Rating: (0)
Was there ever a fix for this? I have the same issue
Macoyle is offline   Reply With Quote
Old 10-01-2012, 04:39 PM   #8
Registered Member
Trader Rating: (0)
For anyone searching or wondering the dealer has to reset the computer, no way around it
Old 10-30-2012, 11:44 PM   #9
Registered Member
lankanboy1's Avatar
Trader Rating: (0)
its been so long i dont remember how i fixed it but i changed one of the wheel sensor the calibrated the sensor and every thing worked fine after that
Old 05-01-2013, 11:48 PM   #10
Registered Member
NJAcura2004's Avatar
Trader Rating: (0)
Droid THX 1138 PontiacSucks
I'm having the same problem. If anyone see this I just replaced both my front hub bearings today and am getting a 84-1. I made sure the new bearings are in the right way and i cleaned the wss sensors. ECU reset? Can I do a battery hard reset or does Acura have to do it. I work at a shop so hopefully they'll hook me up
NJAcura2004 is offline   Reply With Quote
Old 05-02-2013, 11:06 AM   #11
MMkay.
Project_CLean's Avatar
Trader Rating: (2)
Might have to take it to Acura, "VSA neutral memorization procedure", basically a Reset that they perform with the HDS.
__________________
Mod List
--Fresh 04 NBP--6MT w/Navi--FUJITA CAI--Hawk HPS Pads--Cryo Rotors--Tein S-Techs--i-Simple Gateway w/Dash Mount --07 Base Front end w/ Type S grille--JnC Modded Headlights w/ ZKW-R Lenses & Philips Bulbs--Type S Rear--Type S Exhaust--ASpec Lip Kit--Tinted Windows--Comptech SSK--Hybrid Racing Linkage Bushings--
Project_CLean is offline   Reply With Quote
Old 07-30-2013, 02:35 PM   #12
04 TL 6-speed
Trader Rating: (0)
Kajan Thanabalasingam kajan_8
my car had the same problem and just got it reset and it works. use a good shop scanner to do it. i used verdict 07 from snap on and it worked. try this if you cant get a good scanner. http://ww2.justanswer.com/uploads/ac...20_Binder1.pdf
dont need to run to the dealer for this. lol
Kajan_8 is offline   Reply With Quote
Old 07-30-2013, 04:08 PM   #13
Registered Member
Trader Rating: (0)
Quote:
I know this is old but did you have the ignition on at any point while everything was apart?
__________________
Old 06-23-2015, 11:54 AM   #14
New Member
Trader Rating: (0)
A very easy fix my dear all, just put the car in a flat surface, with switch OFF, shortcut pins 4 and 9 from ECU port, turn swith on (WITHOUT BRAKE) and whrn the ABS light comes off press the VSA button, the ! symbol will turn off, VUALAA
hoping it will be useful....
gerardo_mejia is offline   Reply With Quote
Old 12-15-2015, 11:10 AM   #15
Registered Member
Trader Rating: (0)
Hi guys, I have a similar issue. I have a 2005 Acura TL, automatic transmission. My VSA light comes on intermittently and the rpm, speedometer and temperature gauge drops to 0. Acura scanned the system and retrieved a 86-1 VSA code. Has anyone encountered this issue and what was the fix? Any help pls......
Darkwave is offline   Reply With Quote
Old 12-18-2015, 03:28 PM   #16
Registered Member
Trader Rating: (0)
FuncofX
86-1 VSA Code only? As per service manual, check connections at Gauge control Module
Click the image to open in full size.
F(x) is offline   Reply With Quote
Old 12-18-2015, 04:04 PM   #17
Registered Member
Trader Rating: (0)
What is the gauge control module? Is that the gauge cluster itself? Also, am I supposed to check connection between the ABS/VSA modulator and gauge cluster?
Just to clarify.
Thanks for the information, I truly appreciate it.
Old 12-18-2015, 05:07 PM   #18
Registered Member
Trader Rating: (0)
FuncofX
Gauge Control Module is the cluster assembly. Is there a VSA light on the dash, or any other lights lit?
Old 12-18-2015, 05:22 PM   #19
Registered Member
Trader Rating: (0)
Yes, the VSA light comes on randomly, but resets with every key cycle.
Old 12-20-2015, 03:08 PM   #20
Registered Member
Trader Rating: (0)
I did fallow this procedure and fix the problem, you must do it, nothing to lose.
Error Code 84 - VSA sensor neutral position memorization - Acura TSX Forum
emegge23 is offline   Reply With Quote
Old 12-20-2015, 03:35 PM   #21
Registered Member
Trader Rating: (0)
The VSA error code that I have is 86-1. The procedure that you are recommending is for the 84-1 error code as for as I know. Do you think this will work for the 86-1 code?
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help Please!!! ABS and VSA light with exclamation point ALL ON Jamus22 Problems & Fixes 18 02-07-2016 07:08 PM
Some details and info about KW V1 Damper kits MrHeeltoe Tires, Wheels, & Suspension 2 09-30-2015 03:06 AM
KW Suspension Pics and Product Feature MrHeeltoe Tires, Wheels & Suspension 3 09-29-2015 11:43 PM
Product Highlight: KW Variant 1 Dampers MrHeeltoe Tires, Wheels & Suspension 0 09-28-2015 06:43 PM
Misfire DTC and TSB 03-033 question thegipper Third Generation TL (2004-2008) 5 09-28-2015 02:01 PM
Tags
84, 841, acura, bearing, cl, clear, code, failure, honda, logic, mdx, pcm, sensor, tl, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
