2007 Acura TL Type S - Heater
Hey Guys -
The heater on my 07 Acura doesn't work. It worked last year. I had a mechanic look at it and I'm hoping for some suggestions, before taking apart the entire dashboard to replace the heater core. Excuse my lack of terminology as I'm not knowledgeable in car parts.
Any suggestions? Do I actually need to replace the heater core and take apart the entire dash?
- AC works
- Heater turns on but blows cold air
- Thermostat has been replaced
- Coolant/Anti-freeze has been drained and replaced/filled
- The small lever in the engine compartment does go up/down when changing the temp from cool to warm
- The small part by the passenger side, under the dash does change when turning on the heater and changing from cool to warm (firewall?)
ok before you replace the whole heater core makes sure you do the following. I highly doubt its the heater core need replace and yes if the heater core need to replace (if its leaks) the whole dash need to come out.
1. Flush the radiator core with compressor air (Eric the car guy) has a DIY video on this.
2. The lever you describe is called water valve actuator it regulate how much hot coolant allow into the heater core, on the out side it might looks perfect but on the inside the valve construct by plastic. over time the plastic might be deteriorate and the plastic valve broke off.
Part label #1
http://www.acuraoemparts.com/delray/...All&vinsrch=no
here is the DIY for it.
https://acurazine.com/forums/third-g...ve-diy-747304/
Part label #1
Fogz (02-04-2016)
Yehokhanan Jackson
1G TL (1996-1998)
11-27-2015 10:48 PM
Preout
11-23-2015 11:12 AM
Johnbright2020
1/2G MDX (2001-2013)
11-22-2015 12:29 PM
