2005 TL - Replaced my battery, now car won't start
Hey all,
I have an 05 6MT TL. I had a really old battery (bought the car at 72xxx and just replaced the battery at 118xxx) and I just replaced it today with an Optima battery. I followed instructions to a T, and when I went to turn the car on I just got a clicking noise and no start. The car was starting before I replaced the battery a couple of hours ago. I had a little bit of trouble starting the car a couple of times a few months ago, but I assumed that was the age of the battery.
My interior lights work and remote lock/unlock works fine. I cleaned the crap out of the terminals (which were horrendous before I did that, btw) put petroleum jelly on the battery ends, and clamped them down nice and tight. I was going to ask my roommate for a jump.
Should I be looking at my alternator/starter? Is it possible that a battery is shipped to you 'dead' and you have to jump it and it will be fine later?
Please let me know, thanks!
Clean off the petroleum jelly and try again. The jelly is not a very good conductor.
If you want to use something to protect the posts from corroding check out this stuff:
I'll be re-doing all my exterior grounds soon using this, with the exception of ground points on the engine. The flash point of this is 250F, so while ok for battery posts and chassis grounds it's not going to be good for components attached to the engine where the temp may get near or above the flash point.
I read good things about NO-OX-ID and even found some government studies that recommended it's use on electrical conductors in industrial applications and uses in places where large currents are flowing such as our power grid.
That tube is probably enough to last a lifetime for house-hold or automotive uses as well and it was like $20.
Otherwise those indications sound like the starter.
Optima wasnt fully charged. bump start the car and drive it till charged
Trickle charge the battery at 2A or less for ~2 days if you want it to last.
It's always a great idea to fully charge a lead battery before use. The cars alternator does not do this.
Any dielectric grease like petroleum jelly is totally fine and a good idea.
petroleum jelly is a poor conductor, I know people use it to protect their terminals from corrosion
If you're going to use it make sure you have a good metal-metal contact on the battery posts to the battery cable before putting that stuff on. If it gets inbetween the conductors it is not going to perform as a good conductor.
A dielectric is an insulator FYI.
You're essentially doing the very thing you're trying to prevent by getting any dielectric grease inbetween the conductors, it's creating resistance the same thing corrosion will do.
The NO-OX-ID is not a dielectric grease. It's a conductive grease that inhibits corrosion.
Try using a wire brush on your terminal connectors. Had this happen one time and the technician resolved the issue by just using the brush alone. Some batteries/cars are just more sensitive then others.
Thanks for the quick responses guys. Unfortunately I tried
a) Jumping my car
b) Removing the petroleum jelly from the terminals and trying to start it that way
I haven't tried to re-jump after removing the petroleum jelly. I'll keep you posted on my progress. I had to get back to work (I can work from home) so I have to try this later in the afternoon. Any other thoughts?
a) Jumping my car
Hi all.
Thoroughly cleaned the terminals (removed petroleum jelly) and jumped my car (took about 10 minute of charging). It works now, I'll get the NO OX ID like people are suggesting.
Thanks for all the help - mod feel free to close
Irissong (08-31-2023)
Welp. My car won't start again. I drove it probably 5-6 times the past few days, it was struggling a little bit more than normal to turn on those 5-6 times. I go to turn it on this morning and nothing. It tries to crank but slows down and then nothing. Is this probably my starter or alternator? I guess I'll bring it in to someone. I wish I didn't have to do this.
have the alternator and battery tested for free at an auto parts store.
if both check out, you might want to consider the HFL as it could be a parasitic draw
also, as of late, Optima branded batteries dont do that well any more. change of production or location or was bought out made the decline in quality
one of the best batteries out right now is the Sears Die hard Platinum series. It's made by Johnson Controls.
another battery made by Johnson controls is the costco branded batteries
mszczep1 (02-28-2014)
handsom-hustla
11-13-2015 05:04 PM
