2004 ACURA TL AC blows warm air after driving for about 5-10 mins - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 06-25-2009, 11:14 PM   #1
New Member
Trader Rating: (0)
The AC blows ICE cold air when the engine is cold, but after driving the car for about 5-10 minutes, it starts to blow warm air and it seems to shut off the compressor. I took it to a mechanic and said that the frean is not low. I live in FL and the heat is killing me. I really apprciate any help!
abe3800 is offline   Reply With Quote
Old 06-26-2009, 09:03 AM   #2
LoveMyTL-S's Avatar
Trader Rating: (0)
micheal.cain
Are you leaving the outside vent on? Try hitting the recirc button. I also live in FL and feel for you. My house A/C went out last week during the heat wave for 3 days........
__________________
2006 Honda CR-V (Sahara Sand Metallic)
2008 Acura TL-S (Carbon Bronze Pearl)
| iJDMTOY | Drop Stop | vLEDS | Trunk Tray | All Weather Mats | Plastidip |
Car of the Month Contests are going on now! Is your car good enough to win our monthly contests and possibly be our 1st Car of The Year for AcuraZine? Click here and Sign up for this month's contest today!!!!!!!!
LoveMyTL-S is offline   Reply With Quote
Old 06-26-2009, 11:46 AM   #3
New Member
Trader Rating: (0)
Thanks for the reply. I guess ac problems always pop at the worst time!! I have tried turning the recirc on and off, but doesn't seem to make a difference. The ac will blow cold only when the engine is cold. Once the engine is hot, it only blows warm air even while setting the AC to the lowest. Someone suggested that the evaporator temp sensor might be shutting off the ac because it thinks the evaporating is freezing, but I don't know how to test for that and how to fix it.
Old 06-26-2009, 12:28 PM   #4
Registered Member
Trader Rating: (1)
Electric cooling fan at the radiator running when the A/C is on?
Turbonut is offline   Reply With Quote
The Following User Says Thank You to Turbonut For This Useful Post:
willis809 (08-09-2011)
Old 06-26-2009, 12:32 PM   #5
Registered Member
SouthernBoy's Avatar
Trader Rating: (0)
Possibly evaporator coil freeze up.
First, make sure you're using the outside air, not recirculate, then turn the A/C off for maybe 10-15 minutes, then back on again. Does it blow cold again? When was the last time you changed your cabin filter? If it is too dirty, it will impede the flow of air across the coil which can promote freeze up.
__________________
In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
Former owner; 2004 TL 6MT NAV, Anthracite/Ebony
New owner; 2016 Audi S4, Dayton Grey/Black fine Nappa
SouthernBoy is offline   Reply With Quote
Old 06-26-2009, 02:26 PM   #6
New Member
Trader Rating: (0)
SouthenBoy, yes, am using the outside air. If I turn off the A/C for 10-15mins and turn it back on, it wouldn't blow cold air. The only time it starts to blow cold air is in either in the morning or after the car is idel at least for few hour.
Regarding a cabin filter, I have never changed it. How easy is it to change the cabin filter?
I had the battery replaced this past weakend and my AC problem started after that, but thats probably a pure concidence.
Old 06-26-2009, 02:28 PM   #7
New Member
Trader Rating: (0)
Turbonut , yes the cooling fan was running when the A/C is on, but I'll double check it. Thx.
Old 06-26-2009, 03:03 PM   #8
LoveMyTL-S's Avatar
Trader Rating: (0)
micheal.cain
Cabin filter changing:
http://tl.acurazine.com/forums/showthread.php?t=555135
http://tl.acurazine.com/forums/showthread.php?t=583555
http://tl.acurazine.com/forums/showthread.php?t=591437
3G garage is your friend:
http://tl.acurazine.com/forums/showthread.php?t=553557
__________________
Old 06-26-2009, 03:23 PM   #9
New Member
Trader Rating: (0)
Thanks! I'll give try chaning the cabin filter tomorrow and update if it helped.
Old 06-27-2009, 05:25 AM   #10
Registered Member
Trader Rating: (0)
if your compressor is out = $$$
Piotr_W is offline   Reply With Quote
Old 06-27-2009, 12:28 PM   #11
Registered but harmless
Trader Rating: (0)
Quote:
Check this thread re: compressor pressure issue: http://tl.acurazine.com/forums/showthread.php?t=729575
You might want to PM the OP in that thread regarding the repair and possible price. G/L.
__________________
Another SSM '05 TL 5AT w/Navi
Stuck in traffic somewhere in SoCal...
Will Y. is offline   Reply With Quote
Old 06-27-2009, 03:43 PM   #12
is in Honda heaven
Derk's K24's Avatar
Trader Rating: (0)
Check your coolant level?
Derk's K24 is offline   Reply With Quote
Old 06-28-2009, 11:10 AM   #13
New Member
Trader Rating: (0)
Derk's K24, my coolant level is close to the Minumim level line. Can I just top it off with a coolant or should I take it to a shop and have them flush and put a new coolant?
Old 06-28-2009, 11:15 AM   #14
New Member
Trader Rating: (0)
I changed my cabin filter and it was really dirty. I also took it to another AC tech yesterday and the compressor wasn't running and it was blowing warm air. However, this morning, it was blowing cold air again as the engine is cold after being idel overnight and comprosser is back running.
Old 08-25-2009, 12:14 PM   #15
Registered Member
Trader Rating: (0)
So did replacing the filter fix it? Or did the tech do something? As I have the same problem now..
pistophchristoph is offline   Reply With Quote
Old 08-25-2009, 02:53 PM   #16
Registered Member
Trader Rating: (0)
Also just to make sure its the same issue, mine will start out cold then gradually about 15 minutes later get hotter and hotter, but if I turn off the AC for about 5 minutes, Its cold again for another 5-10.
Old 08-27-2009, 10:43 AM   #17
Registered Member
Trader Rating: (0)
UPDATE: Welp I just got the car back yesterday and they could not find what it was as it was not reoccuring, although they did check the refrigerant levels and they were fine, also checked the temperature sensor which was fine, and the compressor itself was fine, but hey who knows maybe something was just needing to be reseated or pushed in more who knows but so far its working.
Old 09-10-2014, 11:50 PM   #18
New Member
Trader Rating: (0)
Quote:
So what did they do to fix it? My 05 TL I'd experiencing the same thing with the driver side blowing cold n the passenger blowing hot. Dual on n off. I took been researching so much. Took it the passenger side of dash apart. Unplugged harnesses and fuses out of fuse boxes. It's still the same. Replaced the cabin air filter. It was dirty. Just want cold air. It's hot I texas
tlazy05 is offline   Reply With Quote
Old 09-11-2014, 08:05 AM   #19
Registered Member
Trader Rating: (0)
There is a TSB in another thread regarding moisture in the system. The solution as I recall was to draw the system down and recharge it with fresh r134a. turns out that the expansion valve was icing up causing the A/C to quit and then waiting 10 or so mins you could turn it on and it would blow cold until the valve iced up again.
YeuEmMaiMai is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Triangle with "!" at startup, and VSA light after 30-40mph. Help! mada51589 Problems & Fixes 27 01-24-2016 03:42 PM
Share your best MPG and how you achieved it. peti1212 Acura ILX Discussion 14 09-24-2015 01:22 PM
Peugeot: Fractal Concept News Yumcha Automotive News 3 09-06-2015 05:40 PM
A/C problems dlknight Problems & Fixes 4 09-03-2015 08:54 PM
September 13th Sunday - Touge.ca Cayuga TMP track event 5-9pm! #18 of 20+ Events Mugen TSX Eastern Canada 0 09-02-2015 12:05 AM
Tags
04, 2003, 2004, 2005, ac, acura, air, blowing, blows, conditioning, hot, problems, rl, rsx, tl, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
