A-125: Valve Adjustment Procedure/Scans - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 03-10-2009, 01:47 AM   #1
Registered Member
erick3's Avatar
Trader Rating: (0)
I'm fairly sure I'm in need of a valve adjustment; can someone point me in the direction of HOW to do this? Or would it be best to get it serviced and done? I'm only at 76k, so I figured it wasn't necessary, but I've been hearing the knocking more so lately...
I KNOW that Acura charges an arm...
__________________
5AT 2005 A-Spec Full Bolton TL
6MT 2010 Sport G37 Sedan [4.08 FD|AK-X|Fast Intentions|GTSpec|HKS||Injen|Invidia|Osiris|Tanabe|Volk]
erick3 is offline   Reply With Quote
Old 03-10-2009, 01:47 AM   #2
Registered Member
erick3's Avatar
Trader Rating: (0)
* what you do for the valve adjustment would be great info too, if someone could provide it! thanks all!!!
__________________
Old 03-11-2009, 12:16 PM   #3
Registered Member
Trader Rating: (0)
It's in the service manual eric. I've never done it on the TL but have on b-series engines which require removing the valve cover, a special socket to loosen the adjustment bolt, a flat head screw driver to adjust the valve lashes, and feeler gauges to get them in spec (all adjust with each cylinder at TDC and not 180 degrees off).
It's funny that you asked this because I've noticed my valves are pretty noisy and I'm at 86k miles now. I did slightly overrev it a few weeks back so I'm wondering if I bent any valves (although that's usually pretty obvious).
A valve adjustment is a part of the 105k service, as far as I know, but I bet most dealers don't even bother.
Also, it should be a ticking sound, not really a knock. If you hear a audible knocking sound.... that's not good. The injectors will make a ticking sound as well but usually it's pretty faint.
eluzion is offline   Reply With Quote
Old 03-11-2009, 01:45 PM   #4
Registered Member
Trader Rating: (0)
yup i need mine too i just ordered the gaskets the other day...i ahve all the tools and its pretty involved... so u need to take your time the tech told me he likes to do it 2 ways....fist when the car is cold and then tear down n retighten after it gets hot n starts to cool off.....im like yea there goes 3grand out the window ill just do it myself thanks
__________________
05 SSM 6MT
Ebony Leather/Grey suede.
Maven Motorsports shift knob
AEM CAI
Outlaw Spacers
Progress 24mm RSB
Comptech ShortShifter
Type S Tail light ghost mod
Type S exhaust with J-pipe and mid muffler delete
Type S Race Pedals
Type S Side Mirrors
Type S A-Spec Rear
Type S Lip Spoiler
Type S Side Marker
Apec Suspension
Ronjon Front Bumper
Ronjon Legend Liquid Graphites with Pirelli Pzero
Neros
Tripnbeats is offline   Reply With Quote
Old 03-11-2009, 01:46 PM   #5
Registered Member
Trader Rating: (0)
oh and u need to be super careful like eluzion said if ur off by 180 degrees say goodnight to ur motor
__________________
05 SSM 6MT
AEM CAI
Outlaw Spacers
Progress 24mm RSB
Type S Race Pedals
Type S Side Mirrors
Type S A-Spec Rear
Type S Lip Spoiler
Type S Side Marker
Apec Suspension
Ronjon Front Bumper
Neros
Old 03-11-2009, 03:06 PM   #6
Registered Member
Trader Rating: (0)
Does anyone know if you need a special wrench to hold tighten/loosen the nut? I'm not sure how far down it sits down inside the head.
It actually looks very straight forward on the TL. There's even numbered indicators to let you know what cylinder is TDC. The only part that can be a pain if you've never done it is getting the clearance right. The manual indicates it should be "a slight amount of drag", which can vary from person to person. The best way I've found to do it is always make sure the feeler gauge that is .001 inches bigger can't fit. For example, the intake side valve clearance is 0.008-0.009 inches. I would adjust it using the 0.008 inch feeler gauge until you feel a slight drag. Grab the 0.009 inch feeler gauge and it shouldn't fit and the 0.007 feeler gauge should slide around very easily.
Also, when you tighten the adjustment nut, you have to carefully hold the valve adjustment screw in place else when you tighten the nut, you will turn the adjustment screw with it. Always double check the clearances after you've tightened the nut.
EDIT: On a second thought, adjusting those rear cylinders is probably a pain in the ass with the lack of room to work back there. Damn these V6's...
Anyways, here's the instructions from the 2004 TL service manual.
Click the image to open in full size.
Old 03-11-2009, 03:10 PM   #7
Registered Member
erick3's Avatar
Trader Rating: (0)
...definitely will not be doing these myself lol
it's expensive i hear though, booo...
jamie, how are you? how's MS?!
__________________
Old 03-11-2009, 03:13 PM   #8
Registered Member
Trader Rating: (0)
no special tools needed bro... it is straight forward make sure u get the new instake gaskets and valve cover gaskets. and anything else you pull apart u need gaskets.... and even tho it indicates what piston is TDC it doesnt tell u if its 180 out of phase or in...lol those r stereo terms but it seems to make sense here. you can be at piston 1 and it says tdc but you can be all the way down in the motor so then you have to crank all the way around again til u hit true tdc.
__________________
05 SSM 6MT
AEM CAI
Outlaw Spacers
Progress 24mm RSB
Type S Race Pedals
Type S Side Mirrors
Type S A-Spec Rear
Type S Lip Spoiler
Type S Side Marker
Apec Suspension
Ronjon Front Bumper
Neros
Old 03-11-2009, 03:14 PM   #9
Registered Member
Trader Rating: (0)
just a word of advice because ive done a few of the older TL's if u get frustrated step away and take a brether....clear ur mind....u dont wanna fuck this up
__________________
05 SSM 6MT
AEM CAI
Outlaw Spacers
Progress 24mm RSB
Type S Race Pedals
Type S Side Mirrors
Type S A-Spec Rear
Type S Lip Spoiler
Type S Side Marker
Apec Suspension
Ronjon Front Bumper
Neros
Old 03-11-2009, 03:19 PM   #10
Registered Member
Trader Rating: (0)
Yeah, well it should be obvious if you're 180 degrees off because the valves would be pressed in (open) and no feeler gauge will fit. Plus you can just look at the cam lobes to make sure the valves are fully closed.
Anyways, how is it working on the back ones? I had a hard enough time just trying to replace the damn spark plugs, haha. Man, how I miss the easy DIY 4 bangers...
Eric - It's alright, could be worse I guess. Food is good, people are different, and I hate mosquitos.
Old 09-01-2011, 02:34 PM   #11
Middle Finger anyone?
NCTL05's Avatar
Trader Rating: (9)
lance.gamber
Ok. Kinda a thread resurecction but its the best place for my question.
Do you adjust both the intake and exhaust valves at the same time on one cylinder?
And what size is the adjusting nut? 8mm, 10mm?
__________________
STOCK!
NCTL05 is offline   Reply With Quote
Old 09-03-2011, 08:19 PM   #12
NCTL05's Avatar
Trader Rating: (9)
lance.gamber
Bump. Can some please answer my ?s
__________________
STOCK!
Old 09-03-2011, 09:01 PM   #13
Bearcat94's Avatar
Trader Rating: (0)
Faceless Not a Twit Un-Linked No Live Box StealMyInfoPls
Have not done this, but the way the Service Manual is written, you'd do all the valves on one cylinder, then move to the next cylinder.
8mm or 10mm. .
Not be a smart ass exactly, but don't you have both? (you knew somebody would say that, right?)
BTW - I don't see anything in the Service Manual or that says one way or the other.
__________________
'07 WDP/Taupe TL-S 5AT
'02 WDP/Parchment TL-S 5AT
Bearcat94 is offline   Reply With Quote
Old 11-01-2011, 11:41 PM   #14
Registered Member
Trader Rating: (0)
Some good info here, i will be checking the clearance and hopefully it is within spec.
poor_owner is offline   Reply With Quote
Old 11-21-2011, 05:58 PM   #15
Registered Member
jisleyjr's Avatar
Trader Rating: (0)
I am thinking i need to do this at 90k.
So i need to formulate a parts list.
From here i'll need 2 of 12030-RCA-A01
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Then from this shot i'll need the intake gasket 17105-RCA-A01
Anything else?
__________________
2006 Acura TL Auto, 18" Sport Edition
1987 Mitsubishi Starion, 2.6L Turbo, Magna MPI Intake, 75lbs injectors, Megasquirt 2 3.57, KDM 3" turbo back exhaust.
jisleyjr is offline   Reply With Quote
Old 11-22-2011, 02:01 AM   #16
Registered Member
robocam's Avatar
Trader Rating: (0)
Is there a thread with scans on how to remove the valve covers? thanks
robocam is offline   Reply With Quote
Old 12-15-2011, 08:25 AM   #17
Registered Member
Trader Rating: (0)
i may pick up a honda valve adjustment tool for like 15 bucks. They all seem to have a 10mm socket. is that the correct size for the 3g TL?
mac10 is offline   Reply With Quote
Old 05-21-2012, 12:28 PM   #18
Registered Member
Trader Rating: (0)
Videos for the visual learners
Thanks for the info, just an FYI the engine needs to be stone cold when doing this. Here are 2 really good videos that I think explain it well, for the visual learners out there
Shipit is offline   Reply With Quote
The Following User Says Thank You to Shipit For This Useful Post:
JD TL-S (03-28-2015)
Old 03-16-2013, 12:16 PM   #19
New Member
Trader Rating: (0)
I have an 08 with 102k on it. The ticking was occurring for three days. It stopped 3 days ago. Should I still go through with the service? Is it possible for the noise to come and go?
mraurora is offline   Reply With Quote
Old 09-11-2013, 02:08 AM   #20
Registered Member
BxTrini_TL's Avatar
Trader Rating: (0)
Richard Sankar Trini605 yuh_boy_rich
BxTrini_TL is offline   Reply With Quote
Old 09-11-2013, 02:08 AM   #21
Registered Member
BxTrini_TL's Avatar
Trader Rating: (0)
" title="You Tube" target="_blank">You Tube
The Following User Says Thank You to BxTrini_TL For This Useful Post:
Old 09-11-2013, 07:53 AM   #22
Registered Member
Trader Rating: (0)
Box end wrench works best for me, don't have to fiddle with reversing the ratchet all the time when a socket is used.
__________________
2013 Corvette G.S. Vert, Night Race Blue, Manual 6 spd.
johnny3 is offline   Reply With Quote
Old 10-04-2013, 12:49 PM   #23
HASTA LA VICTORIA'
cipdagr3at's Avatar
Trader Rating: (0)
cipdagr3at
How much would it cost if I take it to the shop. I just hit 200k and starting to really hear it hopefully nothing bad comes out of it...
__________________
2004 TL NBP, 20/20 TINT, ROCKFORD PUNCH 10', ISIMPLE....
FUTURE MODS- AEM CAI, DEPO TAILS, POSSIBLE LOWERING
cipdagr3at is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
EGR Valve and Intake Manifold fifer16 First Generation RL (1996-2004) 8 10-05-2015 11:12 AM
EGR Valve /Extended emissions warranty shawnafoxx First Generation RL (1996-2004) 2 09-28-2015 01:33 PM
Ft front axle leaking Mike734 Tires, Wheels & Suspension 0 09-28-2015 11:40 AM
Adjusting Koni's is a PIA lowgrowl Tires, Wheels & Suspension 2 09-26-2015 06:18 PM
Clutch delay valve MilanoRedDashR Problems & Fixes 5 09-25-2015 12:04 AM
Tags
2005, 3rd, acrua, acura, adjust, adjusting, adjustment, clearance, gen, lash, spec, tl, type, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
