'07 UA7 6MT Clutch Problem
I seem to be having a clutch dragging/engagement issue on my 07 6MT UA7.
I cannot shift into gears and it feels like the clutch pedal is only half engaging. Feels like a readjustment of the pedal is needed but also told it could be a faulty slave cylinder. Here are my symptoms.
1) Clutch engagement is really low / close to floor.
2) Clutch can be pressed to floor but won't go in gear (locked, due to maybe 3).
3) Seems like clutch pedal needs to be adjusted because when it is pressed all the way to the floor it is only half way engaged.
4) Clutch fluid is topped up with OEM clutch fluid & there is no leaks found.
5) No grinds, no slipping, new transmission installed last fall; new clutch and flywheel installed 12 months ago. All OEM.
6) Car shifts fine into gear when car is off.
7) I will have to turn car off sometimes to get into gear, and car will jump forward like I'm releasing the clutch but yet I still have the pedal fully pressed. (goes back to #3, feels like when clutch is fully pressed it's only half engaged)
8) Clutch pedal squeaks as in video (not sure if that makes a difference).
What do you think guys?
I just got a call from the shop and they say it's a bad clutch slave cylinder but also a bad clutch pedal and the clutch pedal is backordered until the end of August. How can you even break a clutch pedal?!?! Whatt lol.
SidhuSaaB
05-30-2020 12:40 AM
Zonian22
11-14-2015 01:20 PM
