Switchback LED's inside Headlights.... FINALLY!!!
Old 07-25-2007, 01:40 PM
  #81
Tristate ViP Crew
CL Platano's Avatar
Hallelujah
http://.com/Gallery/HiN2007/HiN_Money_Shot
Old 07-25-2007, 03:18 PM
  #82
No He Can't
6MTUA5's Avatar
Old 07-25-2007, 08:41 PM
  #83
King of NYC
rockyfeller's Avatar
WOW that pic makes me wanna change my stock HID bulbs quick (and take off my wedding ring)
Old 07-25-2007, 10:05 PM
  #84
Retired!!! ON TOP!!!
rodneyc77's Avatar
No Doubt fellas
It was definitely a great day...
Old 07-29-2007, 02:33 PM
  #85
TLatVULS's Avatar
How did you make your sidemarkers blink???
Old 07-30-2007, 08:36 AM
  #86
rodneyc77's Avatar
There is a DIY write-up in the 3G Garage, Section G, subparagraph 043... (G-043)
Old 08-20-2007, 05:56 PM
  #87
crazymonkeytl's Avatar
im getting headlights blackened out n then im going to do this mod, just purchased all the LEDS and the equalizer
Old 02-18-2008, 12:18 AM
  #88
B A N N E D
kushsmoker's Avatar
what color do these blink when hazards are on?
Old 02-25-2008, 07:44 PM
  #89
Mistuh DRiiVA
maddsiick's Avatar
i have the switchback LEDs on my turn signals and the passenger side works fine...however the drivers side only works wen the parklamp is off...wehn its on its only blinking white when the turn signal is on and both signals blink really fast...any help on this?
Old 02-25-2008, 09:05 PM
  #90
rodneyc77's Avatar
turn the bulb around on the socket... contacts aren't right within the socket
or it could just be a defective Bulb...
Old 02-28-2008, 03:39 AM
  #91
Make Nice, Not Rice
ballerjai's Avatar
is it true for the 07 tl type-s, the front signal lights are 1157, and rear are 7443? I was looking at the site: http://autolumination.com/1156_1157.htm and sorry to sound inexperienced, but which do I buy? Which one fits stock housing, how much LED's is a good amount, and do I buy the dual circuit?
Old 03-15-2008, 05:40 PM
  #92
maroco's Avatar
Talking
Originally Posted by rodneyc77
Well.. after looking at the switchback LED 7443 bulbs sittin' on my desk for over 6 months... I finally decided to introduce them to my headlights...
Enjoy fellas...
The Moment you've been waiting for... PICS...
A little contrast... triton3k HID's pulling up behind me...I only have the parking lights on...
Here is a little video I put together in a few minutes....
with the CLASSIC playin' in the background....
http://img532.imageshack.us/my.php?i...backledsr3.flv
CRAZYYY!! Exactly how do they work? What does switchback mean?? You can manually change the color?? Sorry, very green here with mods.....
Old 03-22-2008, 11:29 AM
  #93
Make Nice, Not Rice
ballerjai's Avatar
HELP! switchbacks are installed with resistors. Parking lights work fine (white). Emergency lights work great too you can see them switch white to amber, amber to white etc (normal speed). However, when you signal, its a total different story. The lights flicker WAYYYY to fast. prob 2-3 times per second. Is this normal? Did something go wrong with installation? I tried all 3 wires, positive, negation, and parking lights... still going way to fast..
Old 03-22-2008, 01:27 PM
  #94
rodneyc77's Avatar
how did you wire in the load equalizer/resistor ?
I think it's an error in the install of the load equalizer... One side of it goes to the black (negative) then the other side goes to the blinker wire (possitive)...
Good Luck...
Old 09-02-2008, 04:16 PM
  #95
Make Nice, Not Rice
ballerjai's Avatar
What's up with the search option lately? I had to used google and search it..
Anyways, big problem guys.. tell me if you've experienced something similar.
So recently, I noticed my left switchback doesn't lit up completely. What I mean is, it's very very dim. With the parking lights on, signaling would only show white flickering. You can barely and I mean barely see the yellow. It's get weirder, my audio sounds works, but accessing it by pushing the "audio" button doesn't do anything. The other buttons like "Menu, Map, Cancel" all work just not the audio. Okay, it get's even more problematic... my rear camera doesn't work either.
So the night this happened, I figured.. it's too dark so I would just bother with it in the morning. Turned the car on... no problems, switcback, audio, and rear view camera all back to normal. Checked the connection on the switchback and they were fine.
The same evening, problem happened again. Restarted the car after 10 minutes of letting it sit.. and it was fixed.
What do you guys say to that?
Old 09-02-2008, 04:50 PM
  #96
Fulani has a TL's Avatar
Get your battery tested? Could be battery not having enough charge, but once the engine is running it gets enough charge..... Get a battery load test done
Old 09-03-2008, 12:37 PM
  #97
rodneyc77's Avatar
At least your car is warning you of a future totally dead battery
Old 09-09-2008, 06:02 PM
  #98
cdan's Avatar
Well, they do say to verify that the opening is bigger than 1" in diameter... I did but I just eyeballed it...
After spending $50 cash for some 7443 bulbs... I had to make it work... even if it meant cutting open $500 headlights...
Special Ed... that's definitely a Classic... ... I knew that most fellas would appreciate it....
I just bought some LEDs that look like they'll fit (H120xW85xD20mm stated on the package) and they have two resistors and a diode within the bulb. I bought them at autobacsusa.com in Stanton, CA for $27 each. The Ohinata 7443/T20 LED Orange 21/5W Bulb is made in Japan and I can't read any of the characters on the package.
Before I install them, do any of you know of switchback LEDs that fit without mods and blink at normal rates for a base '07-'08 (w/7443 turn signal bulbs)? Thanks!
Old 09-09-2008, 07:27 PM
  #99
07 tl-s in
subbuzz's Avatar
your shit is wack :wink:
as always look's great
Old 09-09-2008, 08:32 PM
  #100
Trew's Avatar
http://www.autolumination.com
you're looking for the 30LED 7443 Switchbacks. You will have to install resistors to get the blink rate back to normal though. Easiest place is in the trunk tapped into the rear (yes rear) turn signal wires. They are on the same circuit as the front.
Old 09-09-2008, 10:14 PM
  #101
6-SPEED LOVER
ABP_04TL's Avatar
get the 30s not the NEW 48s.... since those have a seperate line for each color, while the 30s are both colors in 1
Old 09-10-2008, 03:15 PM
  #102
cdan's Avatar
Thanks for the autolumination 7443 link! I didn't really want to mess w/the electrical system (i.e. the load resistors and grounding wire) but white running lights are too tempting. Especially considering my bumper is off, the lights are being cleared/blacked-out. That and I'm not sure if the internal resistors in the Ohinata OH-117 bulbs will make them blink at a normal speed. I'll put the hazards on and roll down my limo-tint windows if I get pulled over.
Summary of links from Trew and jptl04
Base TL 7443 switchback turn signals,
30 Led SMT Tower Style 7443 plastic wedge base $25.99 x 2
http://autolumination.com/switchback.html
and 6 Ohm deluxe aluminum, 50 watt LED Load Equalizer $6.99 x 2
http://autolumination.com/equalizers.htm
or
V-LEDs dual color white/amber 48 M-SMT parking/turn signal bulbs 7443 $49.99
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
and 2 LED turn signal blinker fix 50W 6 Ohm load resistors 7443 or 1157 $9.99
http://www.v-leds.com/Shop/Control/P...d/0/SFV/32481#
TL S-Type ’07-’08 1157 switchback turn signals,
30 LED SMT Tower Style 1157 metal bayonet base $25.99 x 2
or
V-LEDs TPE 2 dual color white/amber 60 M-SMT bulbs 1157 $54.99
and same load resistor for base or S-Type
2 LED turn signal blinker fix 50W 6 Ohm load resistors 1157 or 7443 $9.99
http://www.v-leds.com/Shop/Control/Product/fp/vpid/4783296/vpcsid/0/SFV/32481#
Old 10-04-2008, 11:30 AM
  #103
greenarcura's Avatar
I have a question for you. I've got a 1997 Acura CL and the low beam head light sockets were removed efore I got the car. There are no low beam lights. What wires to I use to wire up regular low beam headlights? Thanks
Old 10-04-2008, 11:37 AM
  #104
Agent0r's Avatar
You're going to want to check in the CL section of this forum
Old 10-04-2008, 04:32 PM
  #105
TonyBui's Avatar
Hey guys i'm a rookie with car, so what do you think i would be charged to get this done ?? OR, anyone from Maryland that wouldn't mind to help ?
Old 10-06-2008, 08:32 AM
  #106
rodneyc77's Avatar
They now sell these bulbs in the correct diameter that the headlights don't have to get modified...
all you have to do is remove and replace... so easy that a caveman can do it...
Old 10-10-2008, 05:51 PM
  #107
ac-attack's Avatar
hey i ordered the switch back with the bigger diameter is there anyway i can make it fit or should i just return them and get the normal size?
Old 10-10-2008, 06:13 PM
  #108
6-SPEED LOVER
ABP_04TL's Avatar
return them and get the 30leds or the 48s, <---- those fit with no modification of the housing
Old 10-11-2008, 12:38 PM
  #109
I disagree with unanimity
sho_nuff1997's Avatar
Switchbacks installed....my hazards blink normally, but the blinkers are speedy. Can I just install a more powerful flasher or do I need the resistors?
Old 10-11-2008, 12:51 PM
  #110
Trew's Avatar
Old 10-12-2008, 12:55 AM
  #111
zaino'd
jmkiang's Avatar
Quick question. I'm gonna install my switchbacks tomorrow...
For the load resistors, do I just install them in series with the REAR signal wire? Cut wire, insert load resistor, clamp?
Also, does the load resistor need to be mounted? If so, where is the best place to mount and with what? Do they heat up? I read somewhere on the 2G forum that it melted thru someone's trunk liner!
Old 10-12-2008, 01:07 PM
  #112
USDM -> JDM
AZN.M3NACE's Avatar
i got pulled over for having switchbacks............... damn seattle popo's
Old 10-12-2008, 01:17 PM
  #113
zaino'd
jmkiang's Avatar
I thought that as long as you have amber turn signals, you're legal (in most cases).
Old 10-12-2008, 11:01 PM
  #114
Blazing GT's Avatar
looks great
Old 10-12-2008, 11:11 PM
  #115
Too Fast TOO FURIOUS
enigmaos's Avatar
what did the officer say about the switchbacks?
Old 10-12-2008, 11:29 PM
  #116
USDM -> JDM
AZN.M3NACE's Avatar
so what happened was i was a stop light, and i was making a left turn, so i turn on my signals. then i make a left turn after the light turns green, and bammm he was tail gaiting me running my plates. then lights flash, i pull over and this is what happened.
Officer: How are you guys doing tonight?
Me and Frankie02: We are doing great, how about you?
Officer: I'm doing good. Thanks for asking. Reason why I pulled you over was because your turn signals was flashing Blue and Amber. It is illegal to have flashing blue lights on your car. Did you not know that?
Me: No, I'm sorry officer, I didnt know that. These are my temps because my regular turn signals just burnt out on me tonight.
Officer: Alright, may I see your registration, license, and insurance information please.
Me: I hand over my registration to the officer
Officer: Thank you, i'll be right back.
Me and Frankie think to our selfs, why are we being pulled over for my switchbacks blinking amber.. i mean, they arent blinking blue... they dont even look blue. more like of a coool white to me...
Officer comes back: I have to get going but drive safe, and get those replaced as soon as you can.
He drives off...
I'm still thinking to myself, wtf, why was i pulled over for legal turn signals... i mean looking in your pictures of the switchbacks turned on, they look like how mine are turned on... and i didnt want to say anymore so i was playing it cool.... GAY though...
so yeah there is the story.
Old 10-12-2008, 11:43 PM
  #117
zaino'd
jmkiang's Avatar
^ That sucks. I passed by a couple cops with my switchbacks and turned in front of a couple. No issues yet. *knock knock*
I haven't installed the resistors yet so my shit blinks fast. I kinda like it but I think it may start to annoy me in a week. Haha
Old 10-18-2008, 04:15 PM
  #118
I just put mine in. It was pretty simple. Find your blinker wires (the 2 going into the top plug on a 3G), clamp one end of the resistor to each wire and you are done. Took about 10 minutes. The hardest part was holding the trunk liner down. Stupid thing kept popping up when I was trying to push the clamps together. lol
As far as burning the liner...I was able to push the resistors all the way against the body, close to the clear tube. I am not worried about them burning through.
Old 10-20-2008, 10:37 PM
  #119
Tay119's Avatar
would switchback LEDs be tough to install on a early 2G TL?
Old 10-20-2008, 10:46 PM
  #120
6-SPEED LOVER
ABP_04TL's Avatar
no same as the 3G
Quick Reply: Switchback LED's inside Headlights.... FINALLY!!!
