ucf_bronco’s Progress Thread (Updated September 2015)
#442
<p>I don't trust Firestone...so much so, that this last go I paid to have it done at Acura of Pembroke Pines instead even though I still have lifetime. Are those "outside" only directional tires? I had my kumho's flipped and the inner edge was in worse shape than that. Buy's me another year on em, if I leave the Aspecs on. :wink:</p>
#443
I also drive at least 15k miles a year so I'm racking up the miles pretty quick.
My tires aren't directional, but they do have "outside" stamped on them. I can still rotate like normal but I can't flip the tires, unfortunately.
It sucks because there's still a good amount of tread left too. Hopefully since I corrected the negative camber in the rear and plan to lower the PSI I can buy some more time. These tires came with a 50k treadlife warranty so I figured I'd get at least three years out of them.
#444
I wonder if it's due to higher than normal tire pressure. I run 40 in the front and 35 in the rear (as opposed to 37/32 as specified in door panel). I do that since I have aftermarket wheels with a lower profile tire but I may just have to go down to the OEM specs.
I've had good luck at Firestone (at least with the alignments). I get them done about every six months and always leave with everything other than camber in spec. I recently went to a different location and was very happy with the guy that did the work. It was right after I installed the SPC camber kit and surprisingly I was allowed in the work area to watch.
Also check your front compliance bushings. BTW warranty won't cover the wear if it's worn like that, clearly alignment wear.
#445
That's purely camber wear. Throw the worst 2 tires on the front and the good ones on the rear. Make sure the Toe is Zeroed out, that's what kills insides of tires along with camber.
I'll have to take a look at the front compliance bushings (first have to figure out what the hell those are, haha).
I knew the warranty wouldn't cover the wear but I threw that out there so it was clear these tires should have much more life. Hell, I don't think the warranty applies anyway since the sidewall is under 40.
Thanks for the input!
#446
I agree with the above poster about not trusting Firestone. Their lifetime alignment package is BS. I've had customers who thought Firestone did their alignment take it into another shop and find out they were not even doing the alignment. My brother had one of those packages a while back too. They used to do anything they could to avoid doing it.
Those tires are soft and wear quickly anyway but I would chalk that one up to the toe being out more than the camber. Yes, the camber being off will slowly wear the inner shoulder more but it's not a massive amount. Tires take the most abuse under cornering. When you corner, that negative camber decreases because the tire actually stands up straight.
Lastly, I would highly recommend getting a higher quality tire on your next set. While a comparable set of Continental's may cost a bit more from the get go, the added mileage you will receive out of them will more than make up for it. On top of that, they will ride better, be quieter, have more traction and be an overall safer tire.
#447
I wouldn't be shocked to find that out at all...I mean, I watched the guy align...
but, you can take a shiet in a box and label it guaranteed.../Tommy Boy
either way, they don't care...they align...or don't...you need tires faster...win for them.
Whatever, what I do find in my own 3G experience is the TL is VERY prone to squatting under load...I wouldn't be shocked if my fatass in the car causes toe out as soon as I drive away from the damn alignment shop.
#448
I don't really get how Firestone does sub-par alignments. The two I go to have the newest Hunter machine and I leave with a printout that shows the specs. The last one I had done I was right there with the guy while he was doing it, so I know they're not fudging the results. How is an alignment done different (i.e. better) at other shops?
#449
The interesting thing is the two worst tires came off the front. I think the severe irregular wear is because I was running 40 psi cold (in combination with camber out of spec). When I rotated them I put those two in the back but since I have the rear camber corrected now and I'm sticking with OEM specs (37/32) I'm hoping it won't get any worse.
The front tires must have that inner wear due to bad alignment then with the Toe set wrong. Bad toe eats through front tires. Running at 40PSI should have worn the center of the tire out before the rest.
Printouts are the best thing you can get.
#450
Firestone and other alignment places are supposed to put weight in the driver seat and then perform the alignment (bags of sand usually). Some will get things into the green zone while others take the time to zero things out and get adjustments done right. One adjustment affects all the others so it's a bit of a game to get it right.
#451
Well...my comment was only in reference to my personal experience and opinion after years of going through odd wear and very strange explanations for things...
go in, get green paper back...all good...but my steering wheel isn't straight.
they fix the steering wheel but now the camber says it's 2 degrees different than the day before...I ask..."oh, yeah, the machine is sensitive, the numbers can change every time"
then once I took a 2 arm lower kit where you set toe then camber and I get home and one of my rear tires is obviously facing outward to the point that I'm cutting the tire with my fender. and
Just the level of attention, quality...etc...
Plus, the machine is only as good as it's calibration and the tech using it giving a shiet about getting it right.
nats007 (12-29-2015)
#457
Don't get me wrong, I don't mod my car for anyone but myself but a pat on the back every once in a while doesn't hurt.
Thanks man!
rockstar143 (10-13-2015)
#461
Well, the KTuner that was planned for this month has been pushed back. My two little girls are the higher priority and this baby has altered the Dec budget.
I will still be doing some work to the car though. I am in need of new brakes (pads are low and a lot of vibration when braking) so I'm upgrading to drilled/slotted rotors with black zinc coating, adding SS brake lines and premium semi metallic pads. I'm also re-painting my calipers as I plan to fully remove them. Up next is re-doing the vinyl on my grille and taking apart my driver side headlight to fix some hazing on the lens (from the VHT on the reflector). Last is a slight adjustment on the height of my coils since the rear is a bit higher due to the camber correction. Then of course the necessary alignment.
Pics to follow! I'm starting a week from this Saturday and will be spreading the work out over a week or two since I'll be traveling.
The following 3 users liked this post by ucf_bronco:
#462
I'm sure that will make the kids smile a lot bigger than the K-Tuner would make you smile. Looks nice!
#463
Haha, exactly! And of course when they're smiling, I'm smiling...so it's a win-win!
The nice thing is the TL is still getting some love...fixing some things that have been bothering me while improving the looks/performance in other areas. Another win-win!
The KTuner will still be added at some point, probably late 2016.
#464
awesome, man...
I want to put a pool in at some point. Wifey wants it and now that we have a daughter too, I picture her having friends over when she's older and spending the summer's playing at the house.
Car stuff can wait...I'm with you there.
#465
Agreed, car stuff can definitely wait! How old is your daughter? I'm thinking she's young because I thought your only kids were your dogs
I was dead set against a pool when we were looking for houses back in 2008. I had one growing up and was responsible for maintaining it. It wasn't easy! I didn't want to deal with that headache years ago but now that we have kids it's another story...our next house will definitely have a pool. Fortunately we have a nice area out back now (swing set along with our deck and screened in porch; both additions since purchasing the house) so we can enjoy ourselves out there. Our house faces west too so it's shady and cool out there in the afternoon and there's a conservation area behind us so no rear neighbors.
#466
That sounds effin awesome, man.
She turned 1 month yesterday. My new life, man...crazy but fun.
Funny, you and I are so similar in our thinking. I did live in a house with one for a while and hated the added cost and need to maintain. But after hearing so many people and thinking back to summers at Grandpa's pool...I realized it would be awesome for her to hang and bring her friends over instead of being at someone else's house! We don't have a TON of space for one, but we can put a small one in down the line. I bet the $15-20K to put it in will double in additional valuation on the crib.
#467
That's awesome man, congratulations!!!
Our second daughter just turned 7 months last weekend. We're at that nice stage now where she's still a baby but smiles and laughs all the time and more importantly...sleeps through the night!
Agreed on the spike in the value of your home with a pool. I'm sure you'll get more in return in the the end than what you put in...not to mention of course, like you said, having her and her friends there playing rather than somewhere else is priceless.
#473
That's why I do have a pool, I don't want to maintain it. The community I live in has a pool that we can use whenever.... I'll pay my 39 dollar HOA fee not to have to deal with pool maintenance. I have a spa in my backyard, but it's currently not working right now, plus I'm in Cali we don't need no spas.
#477
^^^LOL!
Thanks man! Great way to put it, haha!
Couldn't agree more!
We fortunately have a community pool as well so we can head down there if we want, but that's definitely different than having one out back. Granted there's a trade off for that convenience, and it's the maintenance. We've talked about getting a spa as that's all our backyard could handle but it's nothing we're pulling the trigger on anytime soon.
#478
Well, I've made some progress over the past week. It's been nice to space it all out. Took everything apart on day 1, then did headlight and grille, then stripped/cleaned/sanded/repainted calipers. The headlight is still slightly hazy and the vinyl on the grille is far from perfect but still improved in both areas. The calipers look great though.
Heading out of town for a few days then gonna get SS brake lines in and put it all back together. More pics to follow.
