20 inch rim upgrade
20 inch rim upgrade
Hi. I'm planning to upgrade my rims to 20x8.5 front and 20x10 rear with 245 35 20 front and 255 35 20 rear. Will the rear rub? Rims are Verde Contra. Going to lower it using Eibach pro kit 1.2 front and 1 inch rear. I need some advise. Thank you.
Depends on the offset
Thanks for the advise. Should I go with 35 or 40 offset?
How much are the coilovers? I live in Canada but I'm planning to buy the springs or coilovers in the states because it is cheaper. Any suggestion where to buy and what brand? Thanks
The Original Shawdy
I love these wheel fitment threads that pop up almost every day.
Easier just to look through all the other wheel threads to find out the fitment you want. If you aren't committed to making them fit. Stay conservative. If it was me in your situation, just go 20x8.5 +35/40 20x10+40. But I personally go more aggressive.
Good Luck.
Good Luck.
Grigio4G (10-21-2014)
Thanks. Will the 20x10 rear rub?
What is your wheel set-up and did you buy your coilovers and wheels/rims in GTA? Thanks
The Original Shawdy
Yes you can get the 20x10 to fit. Rubbing only comes into play if wheels are too wide, car is pretty low and/or if offset is really low. 35-40 is legit.
rspst326 (12-28-2014)
Received 6,470 Likes
Are you willing to roll your fenders or do you want to go with a setup that does not require rolled fenders?
I prefer a set-up without rolling my fenders. What would you suggest? I was also considering Vossen VV7 19x8.5 +30 (front)-245/35/19 (front) & 19x9.5 +33 (rear) with 265/30/19 (rear). Need your advise. Thanks.
The Original Shawdy
If you're running 19". Run a 40 series tire.
The Original Shawdy
Lol. Biggest I've seen on the TL is 21" and its huge! 20's are the max. You'll be riding on 25 series tires trying to squeeze 22" and it won't ride good at all. Slug.
I just bought Tein Street Advance. Do you know where to get it installed in Toronto or Markham. Would you know if my rear tires will rub the fender. Tires 245 35 20. Front 9 35 offset and Rear 10.5 +42. Thanks
Noob question for the experts in here.
If you upgrade your wheel to 19" or 20", don't you sacrifice your riding comfort?
My 2012 Sh-awd with 18" wheels and sport tuned suspension already feel a little rough. Imagine going with 19" or even 20" will even more rough than now besides those low profile tires are not cheap either to buy or replace.
Thanks.
Thanks.
The Original Shawdy
Thanks.
Thanks.
OP. Good choice on going with the Street Advance. You'll like them. You should be fine on the rubbing with the +40 offset but if not, a slight roll will fix your problems. Post pictures after you install your wheels and coils.
Cooldude01 (01-12-2015)
The 19's will work well for you.
I bought my BC from BC racing canada
and my setup is 20x8.5 and 20x10 et 20 all around, don't do this spec, it will ruin your car
Ignore that 3M tape too haha
DSC_5980 by herbert6368, on Flickr
mlody
12-04-2019 02:11 PM
johnpancakes014
09-27-2015 12:58 PM
