RV6 PCD + XLR8 J-pipe + Stock Cat + Stock Tips
Old 04-13-2012, 11:27 AM
murtezahu's Avatar
Has anybody set up this combination?
If so, what are your impressions?
Any concerns?
Thanks in advance!
2011 AWD TL, 6MT
Old 04-13-2012, 11:44 AM
Pseudomaniac's Avatar
I have RV6 PCD + RV6 J Pipe (which deletes 3rd cat) + magnaflows + Stock tips. I would reccomend getting the whole RV6 package vs mixing and matching. Are you really worried about the 3rd cat after deleting the first two?
I think that mine sounds good - looks stock.
Not sure where tips come into conversation based on the mods you're listing...
Old 04-13-2012, 01:29 PM
murtezahu's Avatar
I was stating the tips, just because i wasn't planning to change them. My only concern with deleting the 3rd cat is excessive noise and/or drone in the cabin, and smell.
Old 04-13-2012, 01:51 PM
3rdGenHybrid's Avatar
Once u delete your primary cats, that 3rd cat doesn't make a difference... From experience it actually makes it raspier, I recommend high flow pre cats if your worried about exhaust being too loud
Old 04-13-2012, 02:12 PM
2G TLX-S
Edward'TLS's Avatar
Received 1,133 Likes on 813 Posts
Will deleting the Cats set off the engine warning light ?
Old 04-13-2012, 02:35 PM
Changing the PCDs and J pipe has no effect on the appearance of the catback or mufflers.
People have reported this problem with the PCDs, throwing O2 sensor codes - I've been running them (on tank of gas number 3 now) and have not thrown a single code.
https://acurazine.com/forums/4g-tl-performance-parts-modifications-295/magnaflow-11225s-installed-853767/
The above is my thread (with sound clips) of in cabin on the expressway and ouside the car using magnaflow mufflers in addition to the PCDs and J Pipe.
Old 04-13-2012, 05:23 PM
2G TLX-S
Edward'TLS's Avatar
https://acurazine.com/forums/showthread.php?t=853767
But will removing the Cats throw any error code ?
Old 04-13-2012, 08:28 PM
Driving habits will determine if you set a slow response for secondary o2 sensors. If I don't floor it and coast in 4th gear(manual trans only) it won't set the p0139/p0159 because the parameters for that code require accelerating in 4th gear(55-75mph) then decelerating. Since I've kept away from beating on it in 4th gear the code hasn't set, but every time I do, the light will trigger instantly, kind of wish I just went with the hfpcds.
Old 04-14-2012, 06:08 AM
How do you have your defoulers set up? I have mine pointed straight up (path of greatest resistance).
I've had test pipes on the majority of my vehicles the past 5 years. Using the defouler trick, I've never thrown a code on any of them.
This is the first one I've done with those nazi pre-cats though.
Old 04-25-2012, 04:41 AM
Former Sponsor
Richie v6's Avatar
Do you have the updated defoulers with the larger orifice. We started shipping those out for people getting the P0139/P0159. If you dont yet have them shoot me a PM.
KBTypeS
25
10-01-2015 04:49 PM
TLCEEZ
09-24-2015 02:35 PM
Rcelestino93
09-23-2015 10:01 PM
4drviper
09-23-2015 09:00 PM
STL TL-S
09-23-2015 08:52 PM
Quick Reply: RV6 PCD + XLR8 J-pipe + Stock Cat + Stock Tips
