RV6 HFPC, ATLP, K&N intake, ktuner (RV6 tune)
Old 10-07-2015, 02:16 PM
9th Gear
ncciv's Avatar
RV6 HFPC, ATLP J-Pipe, K&N intake, ktuner (RV6 tune), Borla hiflow mufflers, BFG Comp2 tires, all together, a huge performance increase and great sound. The tune from RV6 made all the difference. The front and rear under spoilers may make it slower, but look much cooler. Worth every penny.
https://www.dropbox.com/s/dvxgtxjik1...11228.mp4?dl=1
The following 3 users liked this post by ncciv:
614erich (02-17-2016), KSeriesTuner (10-10-2015), Richie v6 (02-08-2016)
Old 10-07-2015, 05:09 PM
KarKraze's Avatar
Very nice and good to hear you are happy with the results but stop hitting the rev limiter like that.
Old 10-07-2015, 05:19 PM
9th Gear
ncciv's Avatar
can't help it. It sounds so friggin awsome!
Old 10-08-2015, 01:07 AM
CruzanTLSH-AWD's Avatar
What numbers you end up doing after the tune?
Old 02-06-2016, 03:29 PM
9th Gear
ncciv's Avatar
Dyno results after perf mods - 256HP, 240torque
Dyno sheet after 2 pulls. It is still running a bit lean in most of the rev rang.
Old 02-07-2016, 11:00 AM
CLS^6
suspekt360's Avatar
Thanks for posting.
Is the car tuned or using the provided base tunes for your mod combo?
Old 02-07-2016, 03:11 PM
9th Gear
ncciv's Avatar
I am using the maps from the 4th gen ktuner kit based on RV6 mods. It still needs finer tuning since it is running pretty lean (AF 14+ until 5k), but not bad for bolts-on and a pre-made map. I can say that without the new map, the mods sounded great and had some effect (butt dyno), but the new map really unlocked the potential.
Old 02-07-2016, 11:28 PM
Man your numbers are nice.. Is this the 3.7 OR 3.5? Thanks for this posting.
Old 02-08-2016, 07:02 AM
9th Gear
ncciv's Avatar
2012 TL base+tech package, so 3.5.
Old 02-08-2016, 04:12 PM
Not bad at all. There is a guy on here with your set up think he did 277WHP with a tune.What I do notice the FWD guys numbers be looking real nice.
Old 02-08-2016, 04:28 PM
9th Gear
ncciv's Avatar
I also ceramic coated the hpfcs, which my mechanic tells me keeps the hot air in and increases air velocity - making more power. With a better tune for AF and more timing, I am hoping to get closer to 275whp.
What I hope to really improve is low and mid range torque, which is what really gets the car moving...
Old 02-08-2016, 04:50 PM
You just did Dyno pulls and no tuning in the process I assume?
Old 02-08-2016, 05:10 PM
9th Gear
ncciv's Avatar
That is correct. I was using the RV6 tune from ktuner. It needs a bit more work.
jmoney2001
08-12-2019 06:23 PM
bungln
02-20-2019 08:47 PM
swany0095
2G TSX Performance Parts & Modifications
10-07-2015 02:18 PM
c1souk
09-28-2015 11:20 AM
P1zzaman
09-16-2015 06:46 PM
Quick Reply: RV6 HFPC, ATLP, K&N intake, ktuner (RV6 tune)
