K23a1 Build
Old 09-30-2015, 07:36 PM
  #881
Slow98teg's Avatar
Originally Posted by bluecarbonfiber
boost gauge barely moved cant wait to see more vids.. and btw no cares about the cowboys =)
I was thinking the same or the combo of the cams with diff runners
The cams won't do that.
Old 10-01-2015, 10:23 AM
  #882
WTF?
bluecarbonfiber's Avatar
cams changed my exhaust note on my old civic cause of the lobe difference but i guess with the i-vtec its different
Old 10-01-2015, 10:40 AM
  #883
Slow98teg's Avatar
Cams won't make a motor sound like a subaru through the rpms. Bigger lobes will affect idle. Not as much on vtec motors because they don't run on the big lobes at idle. Changing the exhaust note sure. More airflow will definitely affect sound level.
Old 10-01-2015, 11:27 AM
  #884
KenB350z's Avatar
[QUOTE=bluecarbonfiber;15568572]boost gauge barely moved cant wait to see more vids.. and btw no cares about the cowboys =)
I'm see only 6 psi currently. Haha, those cowboy's.....
Old 10-02-2015, 10:19 AM
  #885
WTF?
so with seeing only 6 psi boost im guessing fuel economy is pretty good right now?
Old 10-02-2015, 01:06 PM
  #886
KenB350z's Avatar
Hmmm, haven't even checked that. I'll look next time I hit the road.
Old 10-02-2015, 06:26 PM
  #887
KenB350z's Avatar
Currently asking Hondata if they can make a disable option for our turbo actuator sensor.
Old 10-03-2015, 12:35 PM
  #888
KenB350z's Avatar
First cake delivery with the A/C blasted! Funny how the RDX is still colder then the pilots.
Old 10-03-2015, 06:37 PM
  #889
KenB350z's Avatar
Honda/Acura loving the RDX!
Old 10-04-2015, 03:45 PM
  #890
KenB350z's Avatar
Took her out last night, car feels good. Might hit the track next week!
Old 10-05-2015, 10:03 AM
  #891
KenB350z's Avatar
Nice boost weather!
Old 10-05-2015, 10:56 AM
  #892
andrewbenjack's Avatar
You have to lower that thing Ken. It's so high
Old 10-05-2015, 01:32 PM
  #893
Tomtwtwtw's Avatar
Originally Posted by KenB350z
Nice boost weather!
Bad boost traffic.
Old 10-05-2015, 08:29 PM
  #894
KenB350z's Avatar
Maybe that is a funny angle, but the front is lowered 1.75" and the rear is lowered .25".
Old 10-07-2015, 11:49 AM
  #895
KenB350z's Avatar
Looks like I still have a week before I can run at the track. I will have to find some guys to run with me at Hallett Motor Racing Circuit also.
Old 10-07-2015, 12:46 PM
  #896
WTF?
is your tuning pretty much done?
Old 10-07-2015, 07:03 PM
  #897
KenB350z's Avatar
No, I don't think Vit is comfortable with continuing my tune until I get the (electrical/voltage) issue fix. I took it to Honda and this is what they found. Now, they said this could be from the O2 not being closer to the turbo exhaust and/ or the actuator not being able to function. The current tune that is on it now, feels good though. At only 6-7psi, I'm sure the turbo is like "please....." It's got tons left..
Old 10-08-2015, 10:44 AM
  #898
WTF?
sounds like you need to make a week trip to hondata =)
Old 10-08-2015, 02:16 PM
  #899
KenB350z's Avatar
Ok, just disabled the ELD. I'll see if my voltage goes up and the Jitters stop.
Old 10-08-2015, 02:18 PM
  #900
KenB350z's Avatar
I think you're right! And while I'm there, I should drop by Seibon for some sweet carbon fiber parts..
Old 10-08-2015, 07:42 PM
  #901
KenB350z's Avatar
Just received an updated tune from Vit, he will try and work with me.
(still having voltage issues..)
bluecarbonfiber (10-09-2015)
Old 10-09-2015, 10:20 AM
  #902
WTF?
seibon makes decent stuff.. better than 80% of whats out there
Old 10-09-2015, 10:58 AM
  #903
KenB350z's Avatar
Just uploaded the latest tune, wow didn't know this thing would have that kind of low torque with this longer/larger turbo manifold.
  #904
KenB350z's Avatar
Would be nice to get it up there for them.
Old 10-10-2015, 12:44 AM
  #905
KenB350z's Avatar
I will be a bit busy this weekend. Transmission cooler install and spark plug replacement. Acura did mention that I should consider a differential cooler also with that super stiff CF Driveshaft.
Old 10-10-2015, 10:41 AM
  #906
KenB350z's Avatar
This cooler should do the trick.
Old 10-10-2015, 02:41 PM
  #907
KenB350z's Avatar
As I took the stock cooler off I wanted to see the fluid and it was purple and I forgot that I did a royal purple ATF flush a while back glad I checked.
Old 10-12-2015, 02:18 AM
  #908
KenB350z's Avatar
Taking them in first thing in the morning to get some brackets made. <br/><br/>Stock: 75lbs<br/>Seibon: 19lbs w/o brackets.
Old 10-12-2015, 10:32 AM
  #909
WTF?
yuck both seats weigh that much? or just the driver since it has the electric adjustments?
Old 10-12-2015, 02:43 PM
  #910
Tomtwtwtw's Avatar
Hey, you might actually gain some under-seat storage utility from switching out. Bonus!
Old 10-12-2015, 05:10 PM
  #911
KenB350z's Avatar
I think the passenger is a little lighter then the driver. I'll have to weight it when I pull it out.
Old 10-14-2015, 12:27 AM
  #912
KenB350z's Avatar
Passenger seat: 60lbs
Rear seats: 69lbs
The following 2 users liked this post by KenB350z:
bluecarbonfiber (10-14-2015), TheWrench116 (10-15-2015)
Old 10-14-2015, 08:48 AM
  #913
Slow98teg's Avatar
Good to know. That's a tenth off the ET. At the end of the season I'll probably make one pass with the seats removed.
Old 10-14-2015, 09:21 AM
  #914
KenB350z's Avatar
Good luck! Not sure where I will stand on the 1/4 mile line, considering the heavier turbo manifold, turbo, and the HUGE front & rear gucci brakes. But, those 20's tho....
Old 10-14-2015, 11:42 AM
  #915
WTF?
I thought you were running 19s not 20s? you change back?
Old 10-14-2015, 12:55 PM
  #916
richard cranium
crxtype-r's Avatar
pics of the trans cooler install . that FMIC looks huge . good stuff. keep it up
Old 10-14-2015, 04:43 PM
  #917
KenB350z's Avatar
Nah, the mirror finish TSW's were 19" and the matte's are 20". Do you remember that pic from 7-11 when I had the mirror finish wheels and the matte black ones on at the same time? Those were 19" up front and 20" in the rear.
Old 10-14-2015, 05:06 PM
  #918
KenB350z's Avatar
I see her often when I'm going to work and going home from work. Sometimes with her husband riding with. I passed them once in the morning last week with the beast. He looked! Not sure if they are very big gear heads though...
Old 10-15-2015, 02:47 PM
  #919
KenB350z's Avatar
Just talked with Seibon
Carbon fiber Hood, minimum 40 units
Carbon fiber Hatch, minimum 40 units
Now, they said if we can get at least 50% down then we are good. I'm down! Who is in?!
TheWrench116 (11-11-2015)
Old 10-16-2015, 07:20 AM
  #920
richard cranium
crxtype-r's Avatar
put me down , all in !
Quick Reply: K23a1 Build
