K23a1 Build
#881
#883
Cams won't make a motor sound like a subaru through the rpms. Bigger lobes will affect idle. Not as much on vtec motors because they don't run on the big lobes at idle. Changing the exhaust note sure. More airflow will definitely affect sound level.
#884
[QUOTE=bluecarbonfiber;15568572]boost gauge barely moved cant wait to see more vids.. and btw no cares about the cowboys =)
I'm see only 6 psi currently. Haha, those cowboy's.....
#886
Looks like I still have a week before I can run at the track. I will have to find some guys to run with me at Hallett Motor Racing Circuit also.
#897
No, I don't think Vit is comfortable with continuing my tune until I get the (electrical/voltage) issue fix. I took it to Honda and this is what they found. Now, they said this could be from the O2 not being closer to the turbo exhaust and/ or the actuator not being able to function. The current tune that is on it now, feels good though. At only 6-7psi, I'm sure the turbo is like "please....." It's got tons left..
#900
bluecarbonfiber (10-09-2015)
#903
Just uploaded the latest tune, wow didn't know this thing would have that kind of low torque with this longer/larger turbo manifold.
#904
I will be a bit busy this weekend. Transmission cooler install and spark plug replacement. Acura did mention that I should consider a differential cooler also with that super stiff CF Driveshaft.
#907
As I took the stock cooler off I wanted to see the fluid and it was purple and I forgot that I did a royal purple ATF flush a while back glad I checked.
#911
The following 2 users liked this post by KenB350z:
bluecarbonfiber (10-14-2015),
TheWrench116 (10-15-2015)
#914
Good luck! Not sure where I will stand on the 1/4 mile line, considering the heavier turbo manifold, turbo, and the HUGE front & rear gucci brakes. But, those 20's tho....
#917
Nah, the mirror finish TSW's were 19" and the matte's are 20". Do you remember that pic from 7-11 when I had the mirror finish wheels and the matte black ones on at the same time? Those were 19" up front and 20" in the rear.
#918
I see her often when I'm going to work and going home from work. Sometimes with her husband riding with. I passed them once in the morning last week with the beast. He looked! Not sure if they are very big gear heads though...
#919
Just talked with Seibon
Carbon fiber Hood, minimum 40 units
Carbon fiber Hatch, minimum 40 units
Now, they said if we can get at least 50% down then we are good. I'm down! Who is in?!
TheWrench116 (11-11-2015)
