Throttle body coolant bypass mod
Old 09-03-2006, 10:10 PM
  #81
afici0nad0's Avatar
etarui
let us know how your method holds up in a few days...
Old 09-03-2006, 10:28 PM
  #82
PWPTSX's Avatar
i just did this mod to my 06 a few days ago too
i even took the 2 shorter hose off the car, and re-route the longest hose there.........
i bought 4 valve caps to cap those valve off........
will take a picture when i have time!!!
Old 09-03-2006, 10:36 PM
  #83
GSGOMEZ's Avatar
Originally Posted by moda_way
Here in Ohio, we've got plenty of cold days last winter and I've never had an issue. You just let the car warm up a little bit if you are concerned.
Thanks, moda_way. I will probably do it someday.
Old 09-03-2006, 10:37 PM
  #84
GSGOMEZ's Avatar
Originally Posted by GIBSON6594
Gets pretty cold here in NY too, never had a problem
Oh I see, thanks. I will probably do that someday.
Old 09-04-2006, 12:40 AM
  #85
PWPTSX's Avatar
Easy setup
Here is a diagram i drew................(don't blame on my bad drawing!!)
i try to make it as simple as possible.......basically, from input of coolant, thru the TB, and then to the output of coolant, it uses 3 hoses.......1, 2 and 3......
i was thinking of buying those hose connector like JTso and other member here, but i decided not to because we don't need it!
A - that's where the coolant comes out..........
B - that's where the coolant goes back in............
so all we need to do is just use a hose to connect A and B...........
DO THIS ONLY WHEN THE ENGIN HAD COOLED DOWN!!
~the only thing i bought is the 5/16 valve cap.~
1. first disconnect hose #1 that's attached to A (yes coolant will spill out.......so hurry and do step #2)
2. use a valve cap to cap off A...................
3. disconnect hose #3 that's attached to B, again, coolant will spill out, so use a valve cap to cap off B
4. disconnect all the hose........the only hose we will save is hose #2
5. now use hose #2 to connect A and B together
and done..........for me i used some fresh water to clean up any coolant that i had spilled inside the engin bay...........and of course dry it with a towel.......
Done Product:
i used 4 valve caps............
2 for this:
and the other 2:
~hope this help for all the 2006 TSX people~ (sorry for this long post btw......lol)
Old 09-04-2006, 04:46 AM
  #86
JTso's Avatar
PWPTSX, nice try but you got it all wrong. Just follow what etarui did instead.
Old 09-04-2006, 10:30 AM
  #87
PWPTSX's Avatar
**I DREW THE PICTURE WRONG**
but the done product is also a correct way to do this TB bypass mod.
Same as etarui did, but for me i just connected point A to point B using a longer hose (rearrange hose #2), without passing thru the "U" metal tube.....which is by the way, not necessary.
Old 09-04-2006, 12:41 PM
  #88
Reach's Avatar
No, PWPTSX, what you did is re-route coolant away from the air sensor (I believe... MAF sensor?), which is also a good thing to do, but not the TB bypass. You've bypassed the air line in stead of the throttle body.
Old 09-04-2006, 12:58 PM
  #89
Reach's Avatar
To confirm (JTso...),
According to this picture, B1 is the throttle body's coolant intake nozzle, and A1 is the throttle body's coolant output nozzle. By re-routing existing hose on the 06, you can complete this mod without the need for additional parts.
In fact, wouldnt' the optimal setup be to route the hose from B2 straigt to the return, at my newly marked "C1" point? Thus bypassing the throttle body and the air sensor all in one step?
Old 09-04-2006, 01:51 PM
  #90
etarui's Avatar
I'm sure there are several ways to complete this mod, as there is typically more than one way to skin a cat. I performed this mod the way I did, as I wanted to keep it simple. In my method, only two lines are disconnected, and swapped.
afici0nad0 - I have driven approx 100 miles so far and no issues. I will contine to update over the next few days.
Old 09-04-2006, 02:49 PM
  #91
Time to Climb
godfather2's Avatar
pwptsx, what your bypass mod for the 06?
Old 09-04-2006, 03:09 PM
  #92
PWPTSX's Avatar
all 3 hoses are anitfreeze line, no air line involved.
what you mean?
Old 09-04-2006, 03:13 PM
  #93
offset_98's Avatar
This is very simple, I did it on my LS1 Camaro 3 years ago. I had no side effects. I'll do it on the TSX whenever I have spare time.
Old 09-04-2006, 04:01 PM
  #94
JTso's Avatar
1. Yes, you have the coolant flow path correct (B1 = in, A1 = out).
2. Your C1 reference is incorrect. C1 is the "air inlet" that gets routed to the injector ports when the coolant is at a certain temp. It has nothing to do with the lines going to the throttle body.
3. The bypass can be done many ways. The key point is to keep it simple and disconnect as little as possible.
Old 09-08-2006, 10:54 PM
  #95
Super Noob
jjkim325's Avatar
Ok... so I'm a lil freaked out since this is my first mod ever... I have a 04 and I finished doing the TB bypass and made sure there were no leaks. Started the engine and boom.... there's the CEL. I did fill the coolant in the reserve tank about 3/4 of an inch above the max line. Would that cause the CEL to come on? Other than that the car feels fine and nothing else seems to be going wrong. Any help would be appreciated.
Old 09-08-2006, 11:09 PM
  #96
JTso's Avatar
You probably forgot to reconnect the IAT sensor on the intake tube.
Old 09-08-2006, 11:29 PM
  #97
Super Noob
jjkim325's Avatar
Nope.... I got all of the connections in place... unless I'm missing something... I would take pix but I dont have a digicam.... sister stole it from me. Anyhow, all wires are connected and all tubes are accounted for and connected. I did remove the wire that goes to the TB so I could manuever around better and for got to attach that at first and started the engine. Of course my engine started acting weird so I checked all connections again and connected that wire.
Old 09-08-2006, 11:44 PM
  #98
Super Noob
jjkim325's Avatar
Capped off nozzle on TB. The one under the TB is also similarly capped
I was only able to find a straight connector that was the right size. It was white so the lil white thing you see in the middle of the pic is the connector that is connecting the 2 coolant hoses.
Just a general shot of the intake near the TB
Another general shot of intake where (I'm assuming) the IAT is attached.
Ok this is the best I could do as far as pix. Had to use my phone.
Old 09-08-2006, 11:47 PM
  #99
JTso's Avatar
That is enough to trigger the CEL until you reset it.
Old 09-08-2006, 11:51 PM
  #100
Super Noob
jjkim325's Avatar
how would I reset it?
Old 09-09-2006, 12:02 AM
  #101
JTso's Avatar
You can borrow a scan tool from Auto Zone to reset the code, or disconnect the battery for a few seconds to reset the ECU.
Old 09-09-2006, 02:10 AM
  #102
Super Noob
jjkim325's Avatar
Thanx a bunch.. I found some threads on how to reset the CEL but they were all kinda unclear. Thanx for the clarification.
Old 09-09-2006, 06:56 PM
  #103
Bye TSX, hello domestic?
xizor's Avatar
your pics don't show up for me
Old 09-10-2006, 01:27 AM
  #104
Super Noob
jjkim325's Avatar
yeah... they arent working for me either but it's ok... JTso helped me figure it out
Old 09-10-2006, 01:30 AM
  #105
Time to Climb
godfather2's Avatar
i'm going to be tackling this mod tomorrow ... is there any difference between using a T fitting (3 outlets) vs. elbow (2)?
Old 09-10-2006, 02:35 AM
  #106
JTso's Avatar
You only need to connect 2 hoses. Why use a T fitting?
Old 09-10-2006, 03:59 AM
  #107
etarui's Avatar
Originally Posted by afici0nad0
etarui
Still holding up. No problems!
Old 09-10-2006, 11:40 AM
  #108
Time to Climb
godfather2's Avatar
i couldn't find the appropriately sized hose barb
Old 09-11-2006, 01:22 PM
  #109
Super Noob
jjkim325's Avatar
yeah those connectors are hard to find. The Pep Boys near my house had em but they were hard to find in the store. Took me 15 min to actually find it.
Old 09-17-2006, 04:12 PM
  #110
Time to Climb
godfather2's Avatar
^ finally found the item at ace hardware. btw, i never even checked if this mod is good for automatics. i don't see there being any difference, but lemmy check to be sure ...
Old 09-17-2006, 06:36 PM
  #111
Port & Polish Everything
outersquare's Avatar
i found my hose mender at lowes, home depot didn't carry the right size.
Old 09-17-2006, 11:19 PM
  #112
Master Graphic Artist
PixelHarmony's Avatar
I went to a Napa Auto, Home Depot, and Autozone... none of them had it and to my astonishment acehardware had it for $0.80 or something...
Old 09-18-2006, 11:53 PM
  #113
Super Noob
jjkim325's Avatar
Update.... so I guess this is working out for me. Just one concern though. I've been watching my rpms a lot more carefully than usual and I noticed that when starting from a cold engine the rpms are at 1.5k after a lil driving the rpms drop to normal range 700-800. Anyone know if this behavior is the norm?
Old 09-18-2006, 11:57 PM
  #114
jlukja's Avatar
^^ normal. Mine are always higher right after startup and drop to 700-800 after a slight warmup.
Old 09-19-2006, 08:16 AM
  #115
Time to Climb
godfather2's Avatar
^^ i haven't noticed anything of the sort. i consistently idle around 750rpm
Old 09-19-2006, 11:49 AM
  #116
JTso's Avatar
It's normal for the idle rpm to be higher during a cold start. The rpm then stays at the idle speed after warm-up.
Old 09-19-2006, 11:51 AM
  #117
Drives With Hands
rmpage's Avatar
The ECU program idles a cold engine (ECT <125F) at 1500RPM and keeps AFR a little on the rich side. When ECT begins to rise above 125F, RPMs drop incrementally before finally settling at ~750RPM. I've verified this using an OBD2 scantool. It is true for both stock and reflashed programs.
Old 09-19-2006, 06:35 PM
  #118
Rep'n Taxbrain.com
Tsx536's Avatar
I can verify that it's also true for the Hondata NA and SC refashes.
Old 09-20-2006, 07:23 PM
  #119
Time to Climb
godfather2's Avatar
just finished the tb mod ... it was fairly straight forward and simple, just took me forever to get the clamp off of the bottom coolant line! i used a brass hose barb from ace hardware. on another note, i found something quite peculiar (crack in rubber tubing) on my injen cai). i don't wanna hijack this thread so i'll post in another forum.
Old 10-10-2006, 05:27 PM
  #120
RaCeR4LiFe022's Avatar
i just did it... it changed the sound of my vtec.. ( atleast im pretty sure it did.) sounds crazy good. and i spilled alot of that blue liquid but im still almost full since the car is new lol =]
Quick Reply: Throttle body coolant bypass mod
