V8/rwd TL
Old 10-20-2013, 04:50 PM
  #41
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
Hopefully that is not a stock 5.0. I used to race against those every weekend. Literally hundreds of them. The stock block tends to crack down the valley area in the 500hp area. There are some pushing more for a while but it doesn't last. Nothing wrong with that, mine is not supposed to be good for the hp it's making on almost stock internals but I know one day I'm going to run over the crank or launch a head.
It's a cool project but why why why why do a blow through carbureted setup? It can make big power but that setup is just not street friendly and it's much more likely to destroy the engine in boost. I've spent 3 days straight with one of the legendary tuners on the dyno trying to get the part throttle behavior acceptable on a turbo 347 that made a bit over 1200whp. The less hp and the narrower the range of airflow the carb sees the easier it is to tune but the wider range of airflow can make it a nightmare.
Honestly, turbos and carburetors do not mix on street cars and it's less safe for the engine. Maybe he will keep it around 500hp and it will be great. I look at this as a guy pioneering a way to do a RWD V8 conversion and the problems you will encounter and the mods needed. Personally I would turn the J series 90 degrees and turbo it. You keep the stock wiring. The block and crank are rock solid I'm going to guess past 800hp. With pistons and rods and the right prep work along with the incredible flow of the stock heads, just a turbo will make all the power you could ever want.
I wish him luck with the build. Carbureted or not it's pretty cool.
Old 10-20-2013, 10:56 PM
  #42
anx1300c's Avatar
Originally Posted by vietxquangstah
He says its a mustang 5.0 and it surely isn't the coyote motor so I would assume it's a 5.0 out of the fox body.
Stock motor it's said to make 300 ft/lbs tq at only 3200rpm. With the added turbo it's going to be one torquey beast!
At the beginning he states it's a 351, and then later states it's a 5.0, which is 302ci, hence my confusion. Guess it's a 5.0?
Originally Posted by yoks032rs
Why a chevy motor? The ford 302 small block is a dead reliable motor and
you can extract good HP numbers. I guess with just the turbo set up he
could get 450 HP. Now with heads, cam and intake 550HP. Now a stock
T5 trans wont hold up to long. If he goes with six speed or a built AOD
they both can handle 500+ HP. But I'm just talking here. There will be
extensive fab work here too. But this could be a great project build.
They just sound so much better. Set of long tubes and exhaust on an LSx is straight up spine tingling at WOT.
Old 10-21-2013, 09:39 AM
  #43
jvillefinest's Avatar
Nothing is wrong with it...what your talking about is possible.
Its just alot easier and much CHEAPER to do it with a Chevy motor. I have a buddy that have pulled LS 4.8L out of vehicles with 150k+ miles and have not had to do a single thing to it and now make over 600hp with a turbo kit. Not bad for a $200 motor
Old 10-22-2013, 12:30 AM
  #44
chrisd421's Avatar
I highly doubt ur buddy pulled a 4.8L motor, did nothing but slap a turbo kit and put down over 600hp
Old 10-22-2013, 12:33 AM
  #45
pohljm's Avatar
600 HP Is nothing for that displacement under boost
Old 10-22-2013, 06:49 AM
  #46
Received 16,260 Likes on 11,971 Posts
lol, some one doesnt know about LSx engines...
The following 2 users liked this post by justnspace:
350 (10-22-2013), fsttyms1 (10-22-2013)
Old 10-22-2013, 08:14 AM
  #47
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
For many reasons, but the best is find an aluminum LS engine. It is lighter, its not carb and better for boost and to tune than this motor, and will make more hp more reliably.
Old 10-22-2013, 11:12 AM
  #48
pohljm's Avatar
Think i have seen a twin turbo 4.8 at 1200 HP
Old 10-22-2013, 11:26 AM
  #49
fsttyms1's Avatar
You doubt wrong. Hell there are stock internal 3.2J series out there with really nothing more than a big turbo on putting out over 700whp.
justnspace (10-22-2013)
Old 10-22-2013, 12:13 PM
  #50
The stock J series has the airflow to make 700whp with only a turbo but unfortunately not the rods or pistons to do so, at least not for more than a couple dyno pulls.
This is one reason I don't know why some of the turbo J guys put money into the heads and valvetrain and all of that stuff. The airflow is there, just add boost and a bottom end that will handle the power. If you want the same gains of ported heads, turn the boost up 1lb lol.
The following 2 users liked this post by I hate cars:
AccordFlex (10-22-2013), Majofo (10-22-2013)
Old 10-22-2013, 12:22 PM
  #51
Having seen many, many LS1s on the dyno, it's a little known fact that the stock pistons give up around 550whp. Maybe they've changed some things (obviously on some versions since they make that hp stock) since the LS1 came out and I was dynoing stuff all the time but I've seen more than a few come apart on the dyno at that level. The internet tends to give a best case scenario.
It's like my setup. Stock cast crank, stock 2 bolt block, stock cast rods. Mods are JE forged piston with tool steel pins, a block girdle, and a little hardbloc in the water jackets. I'm past what it's supposed to be able to hold and so are several people but I know this is a 1/4 mile car, I'm not going to be doing extended high speed runs into the higher gears and really loading it down. I could say a stock bottom engine will make 600+rwhp but that's a partial truth. It will only stay together on a perfect tune and it's a bad idea to shift to 4th and load it down. I've seen some let go at 550whp. Driving around it's limitations I've made it last for almost a decade while those wanting to do lots of high speed running on stock parts have not survived.
Majofo (10-22-2013)
Old 10-22-2013, 12:59 PM
  #52
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
I don't think this project is going far.. but..
Old 10-22-2013, 01:18 PM
  #53
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
good luck!
Old 10-22-2013, 01:50 PM
  #54
Gnargasim's Avatar
Okay not going to lie I thought this was going to be a "How hard would it be" thread and a troll playground lol. Pretty tight though
Old 10-22-2013, 02:15 PM
  #55
JJH
JJH's Avatar
I think the reason he went with this application is because it's what was available to him. He had this engine/turbo in his fox body mustang prior to this, or else I'm sure he would have looked at the better alternative in an LS block.
Old 10-22-2013, 02:17 PM
  #56
so this motor is a 5.0 LS1 right?
Old 10-22-2013, 02:22 PM
  #57
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
Uhhh. You'd probably do best to stick to Japanese buddy. LOL
Old 10-22-2013, 02:34 PM
  #58
I have no knowledge on American cars. I just read what was posted in this thread. Someone wanna clarify?
Old 10-22-2013, 02:36 PM
  #59
maharajamd's Avatar
LSx is GM. 5.0 eludes to Ford.
Old 10-22-2013, 05:02 PM
  #60
anx1300c's Avatar
Technically, GM has made three 5.0's. Or two 5.0's and one 4.9 rounded up to 5.0. The legendary 302 DZ (4.9L), the not so legendary Lxx 305 and the even less legendary 307. But none had an LSx designation. Even though Ford ran with the 5.0 marketing, the Fox body Mustangs were technically 4.9L. The Coyotes displace a true 5.0 liters.
When I was in HS, there was a guy a few towns over with a numbers matching '69 Z/28 and that 302 running at 8k RPM's still resonates in the back of my mind. I've never heard a car sound so good and I probably never will.
Old 10-22-2013, 08:28 PM
  #61
fsttyms1's Avatar
Actually from what ive read one did more than just a couple dyno runs, he made many passes at the strip. It did blow up, but that was because he found the limit of the valve train reving past 7200rpm, not because something was week inside Got into the 9s in the 1/4 717whp@6950rpm/581wtq@6170rpm...20psi, 110 octane fuel
Old 10-22-2013, 10:39 PM
  #62
I don't buy it. An engine doesn't blow up from a valvetrain issue. The stock pistons have the top ring very close to the top with little material in the ring land and pin area. The rods while forged are tooth picks.
People can claim what they want but it's just not happening, at least not for long. I always knew the supercharged TLs were blowing engines at the 300-350hp level because of detonation when most thought that was the limit of the engine. The turbo guys managed to make 400-500whp while monitoring knock which is great but they had one thing in common, they eventually failed.
A stock J might be able to hit 700hp but it's not something you're going to be able to beat on all the time. It will let go. I was at Ken Duttweilers during a pull and a wastegate vacuum line blew off and boost hit just south of 50psi. I saw a very near stock LC2 hit over 650hp and nearly 800lbs of torque but I would never say an LC2 is capable of 800lbs on a stock bottom end because one held together for a second or two. For drag only duty, 100 passes is only 50 miles, half of which is basically coasting back to the lanes. Run that same car on the street and you can put the equivalent of a years worth of 1/4 mile runs in a good weekend. I know when I take my turbo car out it's to look for trouble, not to cruise. I'll have to find an old article where a mag installed a huge nitrous shot on a Yugo. It outran some legendary cars on the strip and beat a healthy old mopar (either a 440 Magnum or a 426 Hemi) on the freeway on the way home from the strip..... And then it blew up.
If I believed a J series could sustain 700hp, my TL would have a turbo. I'm assuming the 9 second car referred to was a Civic or at least much lighter than a stock TL which will help it to hold together but a quick view of the pistons screams I hate boost. The low friction and high top ring is great for what they were designed for, emissions and fuel economy but not sustained high combustion temps and pressures. It's got an awesome crank and block and if the pistons and rods were solid I would probably have a hot rod with a junkyard turbo J.
I should've asked in the beginning but was this a J32 or one of the larger engines? I call mine stock too, to most people because it is almost stock but I'm sure without the light mods to the bottom end it would have gone a long time ago. Maybe stock to one person means stock crank and block and heads.
Old 10-22-2013, 11:44 PM
  #63
Majofo's Avatar
a J in the 9's
Was it in a civic with slicks?!
Old 10-23-2013, 06:57 AM
  #64
fsttyms1's Avatar
It was stock other than port and polish intake and runners, it wasnt opened up. Engines do plow up from valvetrain when things start to float and they contact the piston by running 7600rpm . There is a build of it, he is a reputable guy with vids as well. And yes it was a civic.
http://www.j32a.com/showthread.php?t=2237
Old 10-23-2013, 07:00 AM
  #65
fsttyms1's Avatar
Originally Posted by Majofo
a J in the 9's
Yes it was. See link above.
Old 10-23-2013, 07:52 AM
  #66
maharajamd's Avatar
LS = GM
5.0 = Ford
I don't care about the anomaly of a 4.9 Fox body blah blah. Or that GM made an engine with that amount of displacement. Aren't there a few companies that technically do? Audi's V10... Anyway, when people refer to 5.0s they are implying one thing.
Old 10-23-2013, 07:58 AM
  #67
^going along with it...Mercedes 6.3l isnt an actual 6.3l
Old 10-23-2013, 08:27 AM
  #68
Here you go
I begged him to atleast break down the motor and gap the rings but he laughed...."Why when its a $250 motor?"
For anyone doubting the LS engine and stock bottom end here is a good read for you:
http://www.hotrod.com/techarticles/h...g_bang_theory/
For those that dont like to read, the guys at Hot Rod Magazine were able to get 1,203HP from a stock block 4.8
Old 10-23-2013, 09:38 AM
  #69
bouncer07's Avatar
This should be kept in the FORD forums even thought the body on the outside is an ACURA.
Old 10-23-2013, 10:41 AM
  #70
Majofo's Avatar
Mercedes never said it was 6.3L, it's the "63" series. That includes a 5.5L biturbo (M157).
Please explain the Q50
  #71
Majofo's Avatar
Old 10-23-2013, 10:48 AM
  #72
Obviously a 5 liter.
Old 10-23-2013, 10:54 AM
  #73
Majofo's Avatar
Originally Posted by Nissan
With the optional hybrid electric motor, you're effectively driving a 5L V8 *trollsmirk*
Old 10-24-2013, 10:40 PM
  #74
9th Gear
vossenua6's Avatar
nasty
Old 10-24-2013, 11:12 PM
  #75
Majofo's Avatar
Old 10-27-2013, 12:19 AM
  #76
J-series addict
yungone501's Avatar
I commend this guy for these two reasons:
1. Being the first to convert a 3g into RWD
2. Having the balls to use a carbed Ford motor with boost. Why? It will never hit a righteous tune and won't last.
Seriously though, congrats!
As for the conversation on the j-series and its bottom end capabilities, some of you have been reading too many threads where someone hasn't tuned properly and spreading inaccurate data is the outcome. Truth is, people run double and sometimes nearly triple the factory power ratings very frequently and the ones who have done it correctly get a lot of use from their engines still. It's actually very simple and has nothing to do with anything else except this: the less detonation an engine experiences under high load, the longer it will last. So, if you've been reading too many horror stories about broken motors, that just means that underneath it all THEIR TUNER SUCKS.
To those of us rocking the shit of the j-series, rock on!
Old 10-27-2013, 12:56 PM
  #77
pohljm's Avatar
Other than being a conversion I wasnt sure where to put this, but I want my TL to accelerate like this. at 54sec!! hahaha turbo j35
Old 10-27-2013, 04:51 PM
  #78
Red face
I was the first to preach about the importance of zero detonation and preignition to the supercharged guys who were blowing engines at the 330whp level and saying that's the limit of the engine when I knew it wasn't. However, a 700hp stock internal J is not going to run 700hp in a street car that's driven every day or at least on the street fairly often. It will let go. There's a difference in a 1/4 blast for 10-12 seconds on a cool engine vs something that's driven in far from optimal conditions that might see several "passes" in a few minutes on an already hot engine. The pistons are not built for boost. Look at the top ring. With no pinging you can get away with those kinds of cylinder pressures for a very short time. How many daily driven Js are on the street at that level? This is an honest question, I don't know the answer to.
Old 10-27-2013, 07:10 PM
  #79
fsttyms1's Avatar
No one said it was a daily driven car, BUT it did do more than just a few dyno runs and 1/4 passes. It (the J) with a proper tune/standalone could easily be a daily driven 600hp car on pump gas that would be reliable and last The more that is discovered with these engines the better and more hp they are making. Especially with the tuning options becoming available now.
Old 10-27-2013, 07:16 PM
  #80
Thrall's Avatar
Where Did you get the factory looking bumper with those side inlets or did u mod that bumper?
