Type S turbo build, remote mount
#202
We will make a converter with the secondary sensors on the down pipe where the stock 3rd cat was with v band flanges so we can bolt it in and pass emission testing every other year then remove it after we get the registration done and disable it with flashpro like screaminz28 said (BECAUSE THIS IS FOR OFF ROAD USE ONLY AND WE WOULD NEVER BRAKE THE LAW) WE ARE JUST TRYING TO GET BETTER GAS MILAGE
#204
just about done with everything now.
do to all the modifying we did to the car (moving/extending wires, relocating valves and plugs, adding a vacuum box, all that good stuff...)
we decided to start her up just to make sure everything is all good.
https://www.youtube.com/watch?v=NyhY...ature=youtu.be
nothing exploded and/or burst into flames so im taking that as a good sign
#208
Got the turbo mounted . And the intercoolwr pipes put in. Left the top of for the pic
And the coolent lines the vertical is the feed and the horizontal is the drain.
these originally went to the throttle body.
sbuoy (04-21-2016)
#210
Efr 8374
Got home from work the kids been busy it's getting close
sbuoy (04-21-2016)
UTAH TSX (01-11-2015)
#216
the down pipe we wrapped at home.
dont really have much more to do.
she is more or less ready to tune.
sbuoy (04-21-2016)
UTAH TSX (01-03-2015)
#222
Finished the exhaust today ran 3 inch to to stock mufflers will see how this works
sbuoy (04-21-2016)
UTAH TSX (01-04-2015)
#224
That looks awesome man great workmanship this is mechanically the finest this is exactly what I would love to do to my car. Can you give me a ball park figure of your total cost. just so I can have an idea.
#225
Looking good.
Not sure if you're going to like using those restrictive mufflers.
Did you mention what boost levels you're shooting for?
While I am waiting for my heads to come back I started working on the fuel system. What did you end up doing? Did u install a return system or keeping it single sided?
#226
J-series addict
I'm running straight exhaust all the way back and actually doesn't sound bad at all...especially under wot boost. Not as loud as most would think because the turbo actually deadens the noise level like a muffler. Your setup will sound good as well once boost is being generated.
#227
Will this OBX fuel rail fit a J35a8 http://www.ebay.com/itm/OBX-Aluminum-Hi-Flow-Fuel-Injection-Rail-98-02-Honda-Accord-V6-3-0L-Acura-TL-CL-/311008738069?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AHonda&hash=item486990bb15&vxp=mtr
#229
Thank's yungone we just ordered it, to good of a deal to pass up and OBX is no longer making them.
KN_TL we are going to try the stock mufflers and dead end fuel system for now, we did install a deatchworks DW300 fuel pump and 970cc injectors, we need to strike gold or something to buy more parts.
#232
Tuning has begun, Vit sent the first map he drove it and sent the data log back
#233
J-series addict
If you can, let me know what he tunes the AFRs to under WOT boost. Vit was the first one to discover that there was a flaw in Flashpro during the cat warm up phase of the factory tables and how they would cause AFRs to be inconsistent until a set coolant temp was reached. Hondata followed up by adding a disable feature. Wish I knew about this when running into what appeared to be a 15lb threshold....
UTAH TSX (01-06-2015)
#234
Werd.
#235
I don't think he uses the knock control isn't it to slow to do anything worthwhile ?
I don't know crap about tuning I'm into fabrication stuff
#236
Exactly why it should be zeroed out completely. The TL (and TSX I think) have a knock control method that is not made to detect instant knock, but is more of an octane determiner. The knock control tables should be zeroed out and all timing should be set by the timing maps. Without doing that, I think around 8 degrees of timing can be ADDED by the knock control tables. If the car is tuned properly on the fuel that is going to be used, ideally you wouldn't have a range of 8 degrees, since you would tune it to max power without detonation, and maybe back it down a degree or two. An extra 8 degrees on top of that would not be good.
#237
#239
Let me go on record that zeroing out the "Knock Ignition Limit" and "Knock retard" tables will prevent unintended ignition advance from occurring. Once it has been tuned safely, then as a 'method of last resort' you could add some knock retard back in, but that likely won't save a motor in the case of big problems.
I'll go on record saying that a knock control mechanism is your best friend. I know you have the traction control which is beneficial, but I'd also suggest a J&S safeguard and more important.
#240
Yeah, the tuner was very surprised at the timing. I'll make sure to talk to him about the knock control advance happening.
