Type S turbo build, remote mount
Old 11-26-2014, 05:26 PM
  #161
UTAH TSX's Avatar
Originally Posted by UTAH Type-S
this is the air filter i pland on puting in the on in those pictures was just on from my cia i put on for looks in the photos. and i might run some piping into the fender well and put an air filter on it there, or leave the filter directly on the inlet and build a box around it with an elbow that leads to outside the engine compartment. we'll just have to see what i feel like doing when its done, one thing i am considering not too far down the road is water-meth injection.
Reading this made my brain hurt, now I'm looking for my screwdriver son (inside joke) https://acurazine.com/forums/perform...-910371/page4/ post #136
Old 11-26-2014, 07:24 PM
  #162
KN_TL's Avatar
I was also running in the 8-10lb range. I've got an injection system but never got around to using it. When the engine is finished, I'll have it tuned with and without.
Learned by example how very little detonation can damage the stock pistons on the J32. In your case, the J35 may be a bit beefier. Yungone501 would be a good resource for that answer. After the pissing contest earlier, I doubt he visits here much though.
The following 3 users liked this post by KN_TL:
Pghpizzaman (11-29-2014), thisaznboi88 (11-26-2014), UTAH Type-S (11-28-2014)
Old 11-28-2014, 11:14 PM
  #163
UTAH Type-S's Avatar
turbo manifold is just about ready to go to the welders just got to get the holes drilled for the 02 sensors. after that. the down pipe
here is the back manifold, kinda tricky to get this one. in lost a couple of spare elbows in the process.
i might not go with this badge on the new cover i might just go to a trophy shop and have a new plate made for it. opinions anyone?
sbuoy (04-21-2016)
Old 11-28-2014, 11:39 PM
  #164
moar pix, 'cause dad says so
The following 2 users liked this post by UTAH Type-S:
gerzand (11-29-2014), sbuoy (04-21-2016)
Old 11-29-2014, 06:37 AM
  #165
screaminz28's Avatar
Looking good! What size downpipe off of the turbo are you going to use? 2.5 or 3in? I figure it is going to run behind the motor and down, like the stock precat would? Is there enough room with the exhaust manifold coming to the turbo there?
Also, do you have a bracket for the turbo or is it held soley by the manifold?
Old 11-29-2014, 09:09 AM
  #166
thisaznboi88's Avatar
I want 1!
Old 11-29-2014, 10:30 AM
  #167
we made a bracket to hold the turbo up the manifold is a little long to hold the turbo up had to twist the bracket a bit to get the turbo to line up with where the charge pipe is gonna go. the down pipe is gonna be tricky to run it the way we want to. it has to go out at about 30 degrees for about half a foot and then up and over the rear manifold. and somehow we have to find a way go under the exhaust head then down and under the engine mount. and yes it will be 3"
Old 11-29-2014, 10:35 AM
  #168
Originally Posted by thisaznboi88
I want 1!
ok we'll make you one, just bring your tl down to utah and give us ALL your money. lol. jk.
Old 11-29-2014, 02:00 PM
  #169
mzilvar's Avatar
If ALL my money is $5 is that enough?
Old 11-30-2014, 10:14 AM
  #170
UTAH TSX's Avatar
Send it to us as a nonrefundable deposit LOL, we need it bad.
We are about done spending money on parts all I can think of that we still need is spark plugs but we still need to get the manifold and down pipe Titanium High Heat Ceramic Coating done by Rukse Development and that will be a couple hundred bucks uuuuuhhhhhh we have been bleed dry of cash but almost done
Old 11-30-2014, 11:55 PM
  #171
mzilvar's Avatar
Yah this stuff is so expensive, I'm sure you're already in it for a few thousand.
Another expense will be tuning, that time on the dyno with a tuner is probably another several hundred once things are all done.
Old 12-01-2014, 11:53 AM
  #172
Yeah whats sad is how unprepared I was for it. When my dad said it was expensive he was not kidding.
And the time as well. If im not working at one of my jobs im working on my car. Last saturday I got off work at 8. Just to work on my car till at least 2 am. Thank god im single.
TheBlueBomber (12-08-2014)
Old 12-01-2014, 12:22 PM
  #173
what is the bill total so far?
Old 12-01-2014, 01:53 PM
  #174
UTAH TSX's Avatar
About
Attached Thumbnails Type S turbo build, remote mount-%24%24%24%24%24%24%24%24%24%24%24%24.jpg
The following 3 users liked this post by UTAH TSX:
DrOwNiNgPoOl84 (12-21-2014), EL BAN (12-06-2014), Pghpizzaman (12-01-2014)
Old 12-01-2014, 05:49 PM
  #175
2004 TL SSM w/NAVI
Pghpizzaman's Avatar
so true^^^^
anytime i got into anything like this i would set a budget, and my wife would say double that.
when it was all said and done she was right EVERY time
Old 12-01-2014, 06:38 PM
  #176
Originally Posted by Pghpizzaman
so true^^^^
and when its all done you end up doubling that even
Old 12-01-2014, 06:40 PM
  #177
About
yeah something like that
Old 12-05-2014, 10:24 AM
  #178
UTAH TSX's Avatar
This is the plug that NGK recommends with 12 PSI max boost with .033 gap NGK# BKR7EIX does this sound like the right one to you ?
http://www.ngk.com/product.aspx?zpid=9352
Old 12-05-2014, 11:10 AM
  #179
maddogtheta's Avatar
NGK 2667 BKR7EIX Iridium Spark Plug
I have the one step colder plugs BKR8EIX.
Amazon.com: NGK (2668) BKR8EIX Iridium IX Spark Plug, Pack of 1: Automotive Amazon.com: NGK (2668) BKR8EIX Iridium IX Spark Plug, Pack of 1: Automotive
I saw they were used in previous turbo TL's when I read through the ginormous turbo thread.
Old 12-05-2014, 12:28 PM
  #180
UTAH TSX's Avatar
The stock plug is a 6 heat range plug so 2 steps colder that seems like it would have some fouling issues for a street car, anyone have problems with the plugs not self cleanning and fouling out after a few months ??
Old 12-07-2014, 10:00 AM
  #181
UTAH TSX's Avatar
Manifolds, down pipe, exhaust flex pipe, all done on there way to Ruske Performance Coatings Monday to get titanium coated,
We are getting close all of the major fabrication is finished, oil pan is off getting oil drain -10AN fitting welded on, the only thing left to buy is an air filter (I'm sure some other expensive thing was forgotten LOL)
This was the unexpected cost on my car OUCH
Old 12-07-2014, 05:58 PM
  #182
KN_TL's Avatar
Was that your ride???? If it is, that sucks!
Old 12-07-2014, 09:07 PM
  #183
What caused the destruction and what as done to prevent it from occurring again?
Old 12-07-2014, 09:15 PM
  #184
Ever get the downpipe finished or will that be after the coating?
I was curious - what size is the oval on the exhaust port or the p2r flange? Did you use a 3in weld el transitioned to 2.5in? What about the pipe diameter into the turbo flange?
Old 12-07-2014, 10:15 PM
  #185
J-series addict
yungone501's Avatar
Looking good there Utah!
I would like to REALLY emphasize the severity of heat these manifolds will contribute to the engine compartment. Had my setup ceramic coated, titanium wrapped, wrapped again in ceramic wool, then once more in oem Bmw heat shielding. That's what it FINALLY took to make underhood temps manageable. Before doing this, detonation and cooling system issues were almost uncontrollable...these two problems went hand in hand mind you.
The accord is my daily driver and wanted absolute reliability. Up till my 4g TLS dash swap, that was one of the most challenging problems that was presented since beginning this build.
UTAH Type-S (12-09-2014)
Old 12-09-2014, 05:22 AM
  #186
Cant remembrr the diameter of the port but we went with 3" off of it and i lined up quite well so that would be my guess. We stepped down to 2.5 shortly after the exhaust port and ran that all the way to the turbo
Old 12-14-2014, 12:14 AM
  #187
update. got my manifold in for ceramic coating. going with a high temp titanium coat inside and out, have my oil pan and a couple pieces of charge pipe ready to weld along with my blow-off valve. did my first valve adjustment as well while im waiting, after that just have a few modifications to the intake manifold and some heat wrapping and im going to be ready to tune
Old 12-14-2014, 09:52 AM
  #188
Very cool! I can't wait to see the finished install!
Old 12-19-2014, 02:32 PM
  #189
UTAH TSX's Avatar
Got bored at work today life of a Honda tech in December, polished up the intake pipe, waiting for the stuff to get back from ceramic coating
Old 12-19-2014, 03:13 PM
  #190
Looking good!
Old 12-19-2014, 08:08 PM
  #191
Did you already get the downpipe figured out?
Old 12-19-2014, 08:56 PM
  #192
UTAH TSX's Avatar
Yes it's done getting ceramic coating on it with the manifold pipes
Old 12-19-2014, 09:19 PM
  #193
UTAH TSX's Avatar
oil pan finished one AN10 for turbo drain and another for crank vent to catch can
heat shield on the bottom of throttle body
the best parts is watching the oil pan being put on by my son and not me
Old 12-21-2014, 12:36 PM
  #194
6th Gear
amzedan's Avatar
Nice!
Old 12-22-2014, 08:47 PM
  #195
got the manifold pieces and the down pipe back from the coating place.
decided to do a little photo op before i turn in for the night.
gotta be at work at three thirty in the morning, but after work im off till next year, so i have plenty of time to put it all back together, finish moving things around, and installing my gauges.
hopefully i can have it all done before i return to work.
Old 12-22-2014, 08:53 PM
  #196
Looks really awesome! I can't wait to see it installed.
Old 12-23-2014, 08:30 AM
  #197
TheBlueBomber's Avatar
Wow that looks absolutely fantastic. The coating came out amazing!
Old 12-23-2014, 03:55 PM
  #198
2004 TL SSM w/NAVI
almost there!! looking amazing
Old 12-23-2014, 07:19 PM
  #199
mzilvar's Avatar
Just curious, were you planning to stick the secondary O2 sensors in defoulers somewhere?
I only see the primary O2 sensor bungs
Looks nice though!
Old 12-23-2014, 09:13 PM
  #200
Looks nice though!
Easier to just disable with hondata since they are only for catalyst efficiency.
Quick Reply: Type S turbo build, remote mount
