Questions about 3.5 swap.
Old 10-23-2012, 08:03 PM
fabricator's Avatar
i have accuired a J35A6 out of a 2005 Pilot. and was wondering if that block will bolt up to my J32A3 auto trans..I have searched and searched and have found nothing other than for A5 and earlier. any help would be great.
Old 10-23-2012, 08:21 PM
Former Sponsor
Richie v6's Avatar
The bell housing is different on the 04-06 and half of 07 I believe.
fabricator (10-23-2012)
Old 10-23-2012, 08:29 PM
fabricator's Avatar
Thanks Richie, I only paid $25 for the core on the longblock. looks like i'm parting it out. thanks.
Old 10-23-2012, 08:41 PM
thisaznboi88's Avatar
just buy the belt housing and swap all your stuff over if you really want to do it. that's what that guy on k20a did with his j35 swap in a tsx. Swapped all the internals from a 3.2tl tranney into a j35 belt housing.
Old 10-23-2012, 08:46 PM
Former Sponsor
Richie v6's Avatar
Does that work for the AT?
Old 10-24-2012, 12:53 AM
KingKong_Dav
kingkong_dav's Avatar
belt housing or bell.?
Old 10-24-2012, 12:54 AM
KingKong_Dav
if it did rich i dont think it will last long
Old 10-24-2012, 07:16 AM
gwiffer's Avatar
Will you take a picture of the transmission mounting pad on the back of the block?
I'm pretty sure that this engine is a 2G J-series block (has same trans mounting as 1G, close-coupled cats, and crank sensor behind TB cover) and will bolt up, but you'd be giving up the higher compression ratio of your j32a3 (11.0:1 vs. 10.0:1) for a little more low-end torque. It might be a good choice for a TC/SC application.
Old 09-16-2014, 03:36 PM
screaminz28's Avatar
Hate to bump a super old thread, but would rather do that than ask the same thing over again. Was this ever determined if it has the same bellhousing pattern?
The part number is the same between the J32A3 and the J35A6/7, except for the letters, which is what vehicle they came in originally.
11000-XXX-810
I know the A7 has piston oil squirters which would be nice to have, and the lower CR for FI.
The other question is in regards to the sleeves. I saw speculation that they may be FRM instead of steel sleeves? Any truth or verification? I know people don't like FRM sleeves in a FI scenario, but I think Mahle makes specific pistons for FRM sleeves.
Old 10-02-2014, 09:28 PM
J-series addict
yungone501's Avatar
11000-XXX-810
The blocks have the same bolt pattern, no worries.
Also, I've heard rumors about some of the j30's having FRM sleeves but I don't believe any of the larger j-series engines (j32 and larger) were ever manufactured with FRM sleeves. As a matter of fact, other than the j37 that had aluminum cylinder walls, all other j-series were produced with iron lined sleeves.
mlody
12-04-2019 02:11 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
Quick Reply: Questions about 3.5 swap.
