Need help with HFPC install
Old 09-23-2015, 09:56 AM
KBTypeS's Avatar
Quick question:
Do I need a defouler with HFPC?
Is it easier to take out the HFPC from the top or the bottom?
I am just trying to eliminate unnecessary work. I know that a lot of folks do it from the bottom with PCD, but the HFPC is thicker so not sure how that would work.
Any info in regards to this is appreciated.
Old 09-23-2015, 10:07 AM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
no defouler.
take from the top.
i've installed and reinstalled my HFPCs 2x and i really don't want to do it again...it's not fun.
here's my two best tips:
- take the heat shields off the rear one first, otherwise it's very very hard to get the rear cat out.
- buy a swivel head socket wrench (something like
Amazon.com: TEKTON 1491 3/8-Inch Drive Quick-Release Swivel Head Ratchet, 72-Tooth Round Head: Home Improvement Amazon.com: TEKTON 1491 3/8-Inch Drive Quick-Release Swivel Head Ratchet, 72-Tooth Round Head: Home Improvement
The following 2 users liked this post by sockr1:
KBTypeS (09-23-2015), rockstar143 (09-25-2015)
Old 09-23-2015, 10:24 AM
KBTypeS's Avatar
Thanks for the info man. Did you have to take the front strut bar off?
Old 09-23-2015, 10:27 AM
sockr1's Avatar
yes im pretty sure you have to. you need a lot of room
Old 09-23-2015, 04:50 PM
Life Connoisseur
MonkeyTrucker's Avatar
Remove at minimum for easier access: strut brace, rear right (passenger) and rear middle coil packs, release several (all you can find) of the green connectors of the main wire harness from their brackets all the way from fuse box to power steering pump area, passenger side strut brace bracket off (piece that was bolted to strut brace). Pull power steering hose out of it's aluminum and wide clip and pull it behind same clip.
I'd also suggest you remove the rear pre-cat oxygen sensors before attempting the pre-cat removal. You can leave the front ones on if you want, but label all of them as you remove them. Removing the oxygen sensor clips was probably the most time consuming ordeal for me.
It would also be of great benefit to either remove or replace your engine mounts while you're at it. This will allow you to get much more clearance and you'll have it out in an hour to hour and half tops. Would be a shame to be in the area of the rear engine mount and not replace it.
Doing the above allowed me to pull the rear pre-cat over the top of the rear middle coil pack. Could have likely left the heat shield on, but didn't want to stress the side engine mount, which I did leave on.
I've been running HFPCs and an aftermarket j-pipe with "third cat" delete and have had no thrown codes thus far. No additional fouler "tricks" are necessary.
The following 2 users liked this post by MonkeyTrucker:
Catzilla (08-08-2020), KBTypeS (09-25-2015)
Old 09-25-2015, 12:05 AM
KBTypeS's Avatar
that is some great info man. I appreciate it.
Old 09-25-2015, 12:21 AM
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
put a towel on the engine and get comfy...take your time, don't drop anything. The rear cat and wrestling the stock one out will be the part where you get frustrated...everything else is cake.
Old 09-25-2015, 01:06 AM
sockr1's Avatar
so true haha. i went out and bought a home depot gardening kneeling pad and put that on top of my intake manifold and sat on my knees on top of the manifold for a good portion of the job haha. my neighbors probably thought i was crazy since i do my work in my apartment parking spot haha.
Old 09-25-2015, 01:30 AM
I wonder if they came outside, shrugged and said to themselves "man! that guy is ALWAYS on his knees!!!"
late night for me...bed time.
Old 09-25-2015, 02:42 AM
sockr1's Avatar
wouldn't be the first time hey oh!
haha i never see you post this late!
Old 09-25-2015, 09:25 AM
yeah, man...recovering from knee surgery...mind was going, couldn't sleep. Oh well.
Old 09-25-2015, 09:37 AM
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
So glad I didn't have to do this myself. LOL
Old 09-25-2015, 09:39 AM
It was actually pretty therapeutic!
Old 09-25-2015, 09:48 AM
maharajamd's Avatar
I don't mind the time but my back and hands thank me.
I did have to replace the HFPC->j-pipe gaskets myself last weekend though. Luckily all the bolts had been used the weekend before so it was ez pz.
Old 09-25-2015, 09:56 AM
see...and that one I dread very much because my cats don't have fixed bolts on them and it's a very tough time holding the top nut while tightening/loosening.
Old 09-25-2015, 10:00 AM
sockr1's Avatar
how come you had to replace them, could you hear an exhaust leak?
Old 09-25-2015, 10:17 AM
maharajamd's Avatar
I bought the v3 jpipe new but the v3 HFPCs used. They came with two all metal gaskets for the "block" side but were missing the two for the jpipe side. The tech who installed the HFPCs for me while doing my 105k said that one had crumbled away and I had a minor leak. I couldn't even hear the leak but then again he was right next to it with the car in the air...
So I ordered replacements from Rich. They were beefy af compared to what was there.
Old 09-25-2015, 10:18 AM
Rich for the MFW.
Old 09-25-2015, 01:36 PM
Life Connoisseur
Wasn't going to admit I climbed onto my intake manifold cover, but I did too. At over six feet tall, it's still much easier on the back. I climbed on barefoot, didn't want to mar the paint.
Old 09-25-2015, 02:51 PM
Former Sponsor
ExcelerateRep's Avatar
You shouldn't need a defouler, although you might want one just in case.
Without a lift, I'd take it out from the top.
Old 09-25-2015, 03:55 PM
Just wanted to ensure you know this post is slightly different in that I did read the thread and have nothing to sell.
Old 09-26-2015, 11:08 PM
Jeff
Oh Sickest TL's Avatar
Old 10-01-2015, 02:08 PM
KBTypeS's Avatar
Looks like I might be doing it this way...doesn't sound comfortable though..
Always the funny guy...lol.. Look like i have all the info I need.
ExcelerateRep (10-01-2015)
Old 10-01-2015, 02:48 PM
Former Sponsor
More like:
"Not only do we offer great products and customer service, but we offer technical advice as well. If you have any questions, let me know."
Old 10-01-2015, 04:44 PM
Old 10-01-2015, 04:49 PM
KBTypeS's Avatar
Originally Posted by ExcelerateRep
More like:
cycdaniel
12-17-2019 10:58 AM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
TxRzrBk
09-17-2015 01:07 PM
P1zzaman
09-16-2015 06:46 PM
MonkeyTrucker
09-14-2015 11:57 PM
Quick Reply: Need help with HFPC install
