Innovative Mounts Review
Old 07-22-2011, 06:38 PM
  #361
runnin a little boost
Hi speed's Avatar
I think you zip tie the vacuum lines and use the side mount for the ground.
Old 07-22-2011, 08:32 PM
  #362
18psi
libert69's Avatar
if you dont plan on ever putting the oem mounts back in the car then just pull out all the vacuum lines, take that little vacuum module off the back of the intake manifold and put a little rubber cap over the nipple on the manifold.
If you want to keep the lines then use zip ties to seal them and make sure they are tight so you dont have a vacuum leak.
As far as the ground cable is concerned for the side mount, install it the same way it originally was in the new mount
Old 07-22-2011, 10:40 PM
  #363
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
^^^ this
well explained
Old 08-01-2011, 08:05 AM
  #364
josiel's Avatar
Has anyone noticed the engine sits higher with these mounts
Old 08-01-2011, 09:16 AM
  #365
swoosh's Avatar
to be honest I thought the engine sat lower.....
a lot of people on the forum installed the MDX spacer (had stock mounts) and had to cut their hood in order to have the spacer fit but I installed it and didnt have to cut anything....
Old 08-01-2011, 09:05 PM
  #366
josiel's Avatar
the upper transmission mount looks stretched upwards and it used to be normal before the innovative were installed id say its about 1/4" higher
Old 08-01-2011, 09:26 PM
  #367
swoosh's Avatar
WOW....i didnt notice that....i did notice the mdx spacer but well....any reason why you ask ?
Old 08-01-2011, 09:38 PM
  #368
josiel's Avatar
just wondering if this is something normal
Old 10-25-2011, 12:47 AM
  #369
312 HP 271 TQ Dynapack
mrlunecy's Avatar
IM mounts update;
My mounts just recently busted! I have the 65A, I believe. havent removed them yet, but judging by visual, the rear mount looks like its sagging, front mount bolt that connects to motor is missing, (most likely broken off), and both side mount bolts broke off clean. The engine seems to be sitting like 3/4 inch lower right now...sucks.
I noticed something wasnt right when I started feeling some erratic and heavy vibration, (heavier than normal) and when starting, the engine will jolt pretty bad.
Back to the lab again....and I just recently took the s/c off for battery replacement, now this.
I hear there's a significant reliability issue with these? Sorry, but I havent kept up with the reading. What other options are out there, if any?
Old 10-25-2011, 01:28 AM
  #370
mrlunecy's Avatar
just did some reading....looks like the best thing for me to do is go to IM for warranty exchange and upgrade to 75A. According to Exelerate's HP guidelines, I should've picked those up in the first place.
Scott,
I see you upgraded to 85A last year? How those holding up?
Old 10-25-2011, 09:22 AM
  #371
swoosh's Avatar
75A is good enough until 350-400hp....now if your gonna throw a turbo in her and or track her, go 85A....
Old 10-25-2011, 11:46 AM
  #372
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Scott,
Scott hasn't been on the board in a while. I would WW a stock mount for the side.
Old 10-26-2011, 11:22 PM
  #373
mrlunecy's Avatar
[QUOTE=Majofo;13320885]Scott hasn't been on the board in a while. I would WW a stock mount for the side.[/QUOTE
What's "WW"?
Old 10-26-2011, 11:25 PM
  #374
mrlunecy's Avatar
What's "WW"?
Old 10-26-2011, 11:26 PM
  #375
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Scott,
What are the chances of me seeing this thread? The 85A's were holding up well, but my ride was very...unluxury. I didn't mind at all.
But, you know I'm a track addict.
Too bad we never went, Mario!
Old 10-27-2011, 12:07 AM
  #376
Majofo's Avatar
3M Window Weld
List Mastah Hyung!
Hope all is well. Any Orochon #2's lately?
APC miss you.. don't be a stranger.
Old 10-27-2011, 12:21 AM
  #377
3M Window Weld
List Mastah Hyung!
Thanks, bro! I'm still scared to do Orochon Special #2 again...unless someone pays me $500.
I'll hit up the APC thread again sometime...been busy the last several months.
Old 10-27-2011, 10:26 AM
  #378
Former Sponsor
Excelerate's Avatar
Well, if the Innovative mounts aren't working out for some of you anymore feel free to check out our XLR8 mounts. Our bushings have a much larger surface area and therefore 75A should be the most anyone needs.
http://store.excelerateperformance.c.../i-300870.aspx
Old 10-28-2011, 05:05 AM
  #379
mrlunecy's Avatar
Yeah, too bad I haven't made it. I still wanna go, but kinda scared of blowing something up and putting a dent on my finances. Got too many other priorities going on now. You sound like u got rid of the TL? I know u talked about it, but what's the scoop?
Old 10-28-2011, 05:13 AM
  #380
mrlunecy's Avatar
So here's the status on my bushings....done! :
Took only like 90 min to pull them out, no broken hardware to drill out from the front mount, like I suspected, didn't have to pull the blower out (yaaAAaaY!!!) And Innovative has the 75A's ready to go. They say they will replace all bushings and broken hardware, no prob.
Old 10-28-2011, 08:32 AM
  #381
Gone.
Yup. Those are definitely done.
Old 10-28-2011, 11:38 AM
  #382
mrlunecy's Avatar
Gone.
.....so whatcha get?
Old 10-28-2011, 11:46 AM
  #383
Majofo's Avatar
Scott probably bought a mazda..
Innovative Mounts = Garbage. I said it.
Old 10-28-2011, 07:07 PM
  #384
thisaznboi88's Avatar
okay how do you do the warranty claim? Do you need to be the original owner, and /or have the receipt?
Old 10-28-2011, 11:40 PM
  #385
mrlunecy's Avatar
Ownership and receipts don't matter. they are warranted for life. As long as the mount bushings say "innovative" on them, they'll swap them out for ya. They are in Anaheim, so I just drove up with bushing assemblies and broken bolts and they swapped out the bushings (upgraded to 75A) in 5 minutes. The hardware they gave me wasn't great (grade 8.8, no flange) but I can get em somewhere else. They're super nice people, no questions asked. Give them a call, I'm sure you can ship or make other arrangements.
Old 10-29-2011, 04:28 PM
  #386
^ thank you. I saw someone had a set of innovation mounts for cheap. So I was debating should I get it or not.
Old 10-29-2011, 07:29 PM
  #387
swoosh's Avatar
^^^ think you should....even if they are 60A and you wanna go for 75A, use the 60A for a while and as they donut, order the 75A replace the 60A with 75A....ship the 60A back to Innovative and get your money back (what you paid for new 75A bushings)
Old 11-08-2011, 04:24 AM
  #388
mrlunecy's Avatar
Just recently installed my new replacement 75A's.....so far so good. Vibration is not as bad as I thought. Just slightly more vibration than the old 60A's, IMO. Not to mention these have yet to break-in. Hopefully they last longer.
Old 11-08-2011, 08:17 PM
  #389
swoosh's Avatar
^^^ was waiting on a review....i might get mine switched out as well....
Old 11-24-2011, 10:47 AM
  #390
N0w $hiftinG N/A
GtMaxx's Avatar
mrlunecy congrats on the new mounts bro. im here waiting for the review on the innovative 75A mounts since im ordering a set soon so im debating if to go with innovative or xcelerate 75A. I previously had the 62A in my old 05 A/T TL and since it was auto the vibration was pretty shaky when coming to a complete stop. Now since im 6mt vibration at a stop would not really be any concern and as far as HP goals if u might ask what kind of setup so i do it once and right the first time im aiming for 340+ might stay N/A running meth and nitrous.......
Old 01-13-2012, 10:16 PM
  #391
purplerims's Avatar
I just installed these tonight the rear took a long time like 2hrs but it was pretty straight foreward the front and side mounds were screwed but rear was fine...
Old 01-14-2012, 12:58 AM
  #392
Inaccurate's Avatar
^ After you have spent a few days with them, remember to report back to tell us what you think
Old 01-14-2012, 08:57 AM
  #393
purplerims's Avatar
I love the solid feel it gives you when you crank it up and when you get on it the shifts are soooo much smoother I love em I hope I dont have to swap emout for the 75a's anytime soon..
Old 01-14-2012, 03:12 PM
  #394
N0w $hiftinG N/A
GtMaxx's Avatar
switch to the xlr8 jus recently installed these 75a, when the car takes off its hard to keep straight from all the power thats felt after lol
Old 01-30-2012, 07:21 AM
  #395
purplerims's Avatar
I took the motor mounts outafter a few weeks and they already were failing... And I have an auto... I guess I will upgrade to the 75a's but I loved the way they felt in my car
Old 12-17-2014, 08:32 PM
  #396
Mondo375's Avatar
Anyone using the newer style innovative mounts?
Old 12-18-2014, 12:24 AM
  #397
TLX-S
wilztlxs's Avatar
I have the newer style mounts, installed for over a year now, no issues with them.
The following 2 users liked this post by wilztlxs:
Mondo375 (12-18-2014), MrHeeltoe (12-22-2014)
Old 12-18-2014, 06:01 AM
  #398
Mondo375's Avatar
Where did you relocate the ground on the mount? Pics by chance? I may bite bullet and install front and side today lol
Old 12-18-2014, 01:49 PM
  #399
TLX-S
wilztlxs's Avatar
I moved it to a spot behind the power steering pump. I had a long ground cable laying around that I used.
Old 12-25-2014, 04:31 PM
  #400
Bruce Banner's Avatar
How bad was the vibration with that much wear?
Quick Reply: Innovative Mounts Review
