Group Buy for JnR ECU - Dyno's/Gains (12/23); Prices Posted (1/7)
Old 09-29-2014, 07:58 PM
  #3001
KN_TL's Avatar
I do see Andy post occasionally but I think he's out straight and not doing NA.
I owe Anil a quick look see at his logs and I think he has the most recent hands on with the MS3. I'm currently making 8hr road trips so even my build project is taking a back seat.
Sorry I can't be of more help.
Old 09-29-2014, 11:25 PM
  #3002
Chapter Leader (NY/NJ)
InFaMouSLink's Avatar
Thanks. I just finished looking at this whole thread. I wouldn't recommend it to anybody... i'll plug mine in this week and atleast see if it starts. I know andy had fixed the surging issue after the ECU was sent out so maybe i'll ask him to take a look at the msq. he's pretty busy tho. I saw the Rotrex s/c and 2015's list of things to do over at VsixP... i just want the car to atleast run right. not being able to go over 5K and running so rich just robs all the power out of the car.
Maybe you can take a look at it yourself if you have time.. thanks.
Old 10-06-2014, 09:47 PM
  #3003
cgiap93's Avatar
dang why so expensive? i want but don't have that kind of money...dont some ECU's go for like 200-700? are those just shittier ones?
Old 10-07-2014, 09:19 AM
  #3004
KN_TL's Avatar
There's a MS3 in the BM in your price range.
The unit itself is fairly cheap but factor in the harness building and you end up with this price.
The real question is, why do you need it?
Unless you are a trust fund baby, I can't imagine a 21yr old could afford what it takes to get serious HP numbers out of these cars. Nothing against your age, I'm just saying.
I could buy a new entry level car for the money I have put into this one car.
The following 2 users liked this post by KN_TL:
EvilVirus (10-10-2014), InFaMouSLink (10-07-2014)
Old 10-22-2014, 05:01 PM
  #3005
Black07TLS's Avatar
Old 10-24-2014, 09:14 AM
  #3006
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
Old 02-22-2015, 12:30 AM
  #3007
Speeden6's Avatar
alright, so I'll be the first to say I didnt READ all 76 Pages! but I hooked my MS3 up to 2006 5AT, plugged battery in, turned key to acc, then off, then to acc then off, then tried to start it.
the car started but you had to keep the gas mid way for it to stay on and not cut out. FLOODED the hell out of it. you could totally smell it.
I tried with all A-E plugged in. then went to A,B,C,E (no D) and it wouldnt start.
Any tips? or just need a tune?
Old 02-22-2015, 11:51 AM
  #3008
thisaznboi88's Avatar
probably ignition map is all jacked up
Old 02-22-2015, 05:25 PM
  #3009
KN_TL's Avatar
What harness did you end up with?
Do you know anything about the tune that is currently loaded? I would start by looking at the required fuel setting. Sounds like it's way off.
You'll find, unless you are Andy, that idle will be unstable. I think everyone had issues with it, I know I did. Was the worst part of this solution. Andy said he set the lower end of the map with a finer resolution. I was just getting to understand the fuel maps when Hondata came out with something and I immediately moved to it.
Old 02-22-2015, 06:12 PM
  #3010
Speeden6's Avatar
Yeah, the Map on it is from a supercharged car so much more demand. Im hooking up the Vacuum line as well as the AFR to do a self tune. hope that helps.
Old 02-22-2015, 06:27 PM
  #3011
KN_TL's Avatar
Not always. Things are MAP based and even FI applications have lower map requirements. But if things like injectors were different on the previous application, it would mess things up.
Auto tune wasn't very helpful unless you narrow down the range. It just can't do a magical tune across the board.
Read the manual, the first thing it says is to get a decent idle. If you don't have at least a somewhat good idle, you'll be chasing your tail.
Old 02-23-2015, 09:07 AM
  #3012
Speeden6's Avatar
Yeah, I have a 2006 5AT so I am stuck with this or nothing and I need something.
I'm working with Rodney to get it dialed in so hopefully that will help a little. we will see.
Old 02-23-2015, 09:12 AM
  #3013
Glad to hear some people are getting some good stuff out of this.
Old 02-23-2015, 09:28 AM
  #3014
Speeden6's Avatar
well, cant say I am getting anything out of it right now, but I am hoping too!
Old 02-23-2015, 06:28 PM
  #3015
no doubt, man...hey, if you do, it was well worth it.
cycdaniel
12-17-2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
GhostTL09
09-19-2015 01:57 PM
Leester01
09-11-2015 06:35 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
Quick Reply: Group Buy for JnR ECU - Dyno's/Gains (12/23); Prices Posted (1/7)
