'08 TL Type S Rotrex supercharger build
Old 02-24-2011, 09:40 PM
Random88's Avatar
I have a black 08 TL type S, I am currently putting in a rotrex supercharger with 8lb pulley and full exhaust, headers back. I need to know what are some of the best mods I can do to the car to make it a street beast. I know I need bigger injectors for a start but I can't seem to find any for this car. Can anyone help me?
Old 02-24-2011, 09:58 PM
runnin a little boost
Hi speed's Avatar
The RDX injectors are a direct fit as are the RSX type s injectors. The J and R standalone ECU will also be a nice addition.
Old 02-24-2011, 09:59 PM
Received 16,260 Likes on 11,971 Posts
Sub'd
Old 02-25-2011, 05:17 AM
TLdream's Avatar
Just like mentioned above rdx injectors will probably be the most cost efective. You might also look into an external trans cooler, and some kind of intercooler setup. Check out the different alchohal/meth injection thread also. A must to have is a computer to Tune it with. The J and R standalone ecu should be released shortly and will provide the TL with everything it could ever want and more, in the tuning dept. A less costly alternative to tuning would be the aem fic. You can add fuel, but it is difficult to pull timing.
Old 02-25-2011, 06:10 AM
MY KBP IS BTR THN URS...
OneWickedTypeS's Avatar
Um I'm pretty sure we do not have headers as ours are cast in to block ?
Can some one correct me if I'm wrong please.
Good luck man I would love to strap a super charger on my Type-S...
Old 02-25-2011, 06:44 AM
Chapter Leader (San Antonio)
TheChamp531's Avatar
Pre-Cat Deletes = Our version of "headers"
Old 02-25-2011, 10:00 AM
apnorm's Avatar
How far in the process are you? Any time frames on when this might be completed?
Old 02-25-2011, 10:50 AM
handsom-hustla's Avatar
What application was this rotrex intended for?? Rdx you can get bnib for 36 an injector. Are u mt or at? If at, an additional trans filter as well as cooler. Meth is another must for any fi. Aem or snow seem to be the top two people like..also an external fpr.. Def a/f gauge preferably aem. Two steps colder spark plugs..Yes also we don't have headers, we use pre cat deletes. Also I would recommend a 3" exhaust..
Old 02-25-2011, 11:55 AM
Comptechtl2367's Avatar
I have never heard of this supercharger for a TL. any pics of what you have so far or is this just an idea for right now?
Old 02-25-2011, 12:52 PM
I got the Shifts
phee's Avatar
http://www.rotrex.com/Home/Superchar...1-069ac466df3f
Old 02-25-2011, 01:04 PM
After a quick search over the web site it seems they make it for the Mdx and 8th gen accord only, not the 3G.. Were compatable with the 7gen accord. Not sure if u were going to fab it to work but look into it a lil deeper before u proceed with the build.. Either way good luck. I a well never hears of this type of blower..
Old 02-25-2011, 01:57 PM
myron's Avatar
so this will give 425hp from 307hp to a MDX? Is this some kind of scam or something? how come no one has heard of this before?
Old 02-25-2011, 02:07 PM
Registered Member
Toddy's Avatar
Im with Myron
Old 02-25-2011, 02:15 PM
I have not double checked the gains but those numbers Myron I guess are some what reasonable to say for sc gains.. a lil over exaggerated yes. While overlooking to see if it was for the 3G I noticed it was intended for BMW.Mercedes and other cars. Only applied to 2 Acura/Honda.. Magnuson makes the ct sc so maybe this is a company that does the same for other makes and models.. I'm hoppy to here from the op soon, so.he can fill us in on some more details..
Old 02-25-2011, 03:31 PM
The limited picture they have of it on that MDX makes it look... cheap and cobbed together. I would like to hear from the OP at some point about this.
Old 02-25-2011, 04:52 PM
Registered Member
Toddy's Avatar
Id like some better pics of this setup
Old 02-25-2011, 04:56 PM
ScoobyZINE
AMUA6's Avatar
Originally Posted by myron
so this will give 425hp from 307hp to a mdx? Is this some kind of scam or something? How come no one has heard of this before?
+1
Old 02-25-2011, 08:12 PM
TLdream's Avatar
Look into rotrex there blowers are much more effeciant than the comptech units.
Old 02-25-2011, 08:24 PM
B A N N E D
friesm2000's Avatar
i want to see how this turns out, subscribed
Old 02-25-2011, 09:34 PM
KN_TL's Avatar
That has to be one of the worst web sites I have ever visited. A whole lot of nothing.
That is an interesting blower. Looks like a belt driven turbocharger.
Old 02-25-2011, 10:13 PM
Registered Member
Toddy's Avatar
heres some info on the blower itself...http://www.power-enterprise.co.jp/ro...rotrex/C30.pdf
B A N N E D
friesm2000's Avatar
you mean a centrifugal supercharger
http://auto.howstuffworks.com/supercharger4.htm
but yes it is basically the same as a turbo, but instead of the turbine/exhaust side, it gets driven by a belt
Old 02-25-2011, 10:23 PM
KN_TL's Avatar
Interesting, thanks.
The size of a turbo without the plumbing......there must be some disadvantages since it seems like either conventional turbo's and screw type superchargers are commonly used.
Old 02-25-2011, 10:33 PM
B A N N E D
friesm2000's Avatar
turbo= more power due to less "power loss" due to using the excess energy in the exhaust; but it is alot harder to plumb though, with have to also run the exhaust up to it
screw blower = VERY linear power band, due to the boost coming on at a consistent rate
centrifigual= basically kinda that laggy/surge feel of a turbo, with the power lost of a screw blower; BUT they do have there place though, especially when space constraints come into play; let me try and find a video/picture that someone showed me with a centrifugal on a J motor
i just covered for the most part the VERY basics of the various types
Old 02-26-2011, 01:13 AM
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
Centrifugals like this one produce good peak numbers but don't hit full boost until redline. It's like having turbo lag all the time. They're as efficient on the compressor side as a turbo with comparable charge air temps but of course they require power to be driven. Probably the best sounding and intimidating of all superchargers except for a cogged drive.
They all have advantages and disadvantages. This one would probably have a similar looking powerband as a stock TL but with more power. You won't get the huge torque gains you do from a turbo. Think of this one as a belt driven turbo.
RDX injectors are borderline. I would choose carefully in the fuel department. Remember that you have to leave a larger margin of safety on a supercharged engine because 20-60hp is zapped by the blower before it ever gets measured at the crank or wheels. If it makes 300hp at the crank, you need enough fuel to support 360hp to be safe. A 60lb injector would give a nice large safety margin at an estimated 400hp.
Old 02-26-2011, 01:16 AM
No low end... Boost builds with rpm and continues to climb until the revs stop rising. My personal opinion is they're better suited for large engines that already have a lot of low end but not as good at making a small V6 perform like a V8 down low. If your turbo TL and the centrifugal TL make the same peak numbers, your turbo TL will still walk it, not to mention the fueling requirements are higher at the same power level.
Their peak numbers usually look really good but they have very little under the curve.
Old 02-26-2011, 02:03 AM
myron's Avatar
I hate car - check and mate haha
Old 02-26-2011, 09:10 AM
347hp/300tq @ 4psi
04accordcpe's Avatar
this thread is going no where fast... not only is the OP as vague as that worthless website =/ but he says hes "currently" putting in a rotrex supercharger, but is totally clueless as to where to buy injectors, referring PCD's as "headers", asking what are the best mods, yada yada yada... not to mention its his very first thread/post and hes yet to answer any questions thus far throw us a bone over here... pics? where you bought? how much? etc etc...
personally, ive never took a good look underneath a hood of a MDX, but its just too tight of a package to fit a centrifugal supercharger in any year TL.
Originally Posted by I hate cars
Probably the best sounding and intimidating of all superchargers except for a cogged drive..
this is the biggest drawback to this type of supercharger IMO. the sound at idle is LOUD on certain applications and ruins the element of surprise.
Old 02-26-2011, 06:11 PM
Mom why is there two?
ethenol's Avatar
^ agreed.................. These are pretty good little chargers mustang guys use them alot around here and they sound very good and perform well....... But like everyone has said above me, it sounds like you haven't even researched and bought any supporting pieces to say.................... BUILD.......................
Old 03-23-2011, 05:54 AM
Rev High; Drive Happy
o4Komodo's Avatar
bumpy.
Old 03-23-2011, 12:54 PM
greco9885's Avatar
lol hook line and sinker!
a month and guy hasnt been back
Old 03-31-2011, 01:35 AM
Former Sponsor
AckTL05's Avatar
I went on youtube and it seems like a lot of s2000's have them.
Old 03-31-2011, 06:04 AM
Former Whyner
RonJonTL757's Avatar
Old 01-15-2014, 11:38 AM
gerzand's Avatar
I'll just put this here for now: http://web.stagram.com/n/gerzand/
Old 01-15-2014, 02:51 PM
AZ Track Whore
vill0169's Avatar
Me want...........
gerzand (01-15-2014)
Old 01-15-2014, 03:28 PM
KingKong_Dav
kingkong_dav's Avatar
Old 01-15-2014, 03:56 PM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
click the link gerzand posted
Old 01-15-2014, 06:28 PM
powdbyrice's Avatar
shit just got real.
Old 01-15-2014, 06:32 PM
MAS
MAS's Avatar
interesting.....you sir are a pioneer and without people like you aftermarket performance wouldnt have gotten to where it is today. Keep up the good work.
The following 2 users liked this post by MAS:
EvilVirus (03-20-2014), gerzand (01-15-2014)
Old 01-15-2014, 07:11 PM
I just looked at the 1/4 run for the first time. I saw 118mph, what was the ET?
Quick Reply: '08 TL Type S Rotrex supercharger build
