'04 AT TL MPG? Any tips/tricks for improved MPG?
Old 07-12-2012, 10:33 AM
  #41
losiglow's Avatar
Originally Posted by kdybread
Thanks for the feedback folks, I guess it's all the conventional options, no real secrets revealed, but that A/F ratio debate was informative and entertaining especially with the troll vs troll stand-off lol.. thanks folks...
Yeah, there really aren't any secrets. And the few that exist are only going to provide a very minimal gain. Driving style is the biggest by far. I got 28 mpg on my very first tank straight out of the dealer. But I drove like a total grandma. After 500+ lbs of weight loss, a CAI, exhaust mods, synthetic oil and all the new maintenance items (spark plugs, air filter, etc.) you can bet the car is much more efficient. But I still get about 30-31mpg which isn't a significant difference. The difference is, I drive much more agressive than before. So all that stuff I did pretty much went down the crapper because I refuse to drive like a grandma all the time. If you do decide to drive like a grandma, you can get much better mileage. But then you're just not enjoying the car . For me, I drive like a banshee when I feel like it, and like a grandma all the other times. It's about a 50/50 mix
Old 07-12-2012, 10:35 AM
  #42
Received 16,260 Likes on 11,971 Posts
let me know when you're out on the road...
so i can avoid you.
Old 07-12-2012, 10:48 AM
  #43
Where Did My Garage Go?!!
lucnex's Avatar
king kong douche I am tired of reading your pointless contributions to this forum...go be a douche somewhere else....like acura world or something
Old 07-12-2012, 11:24 AM
  #44
Chapter Leader (San Antonio)
TheChamp531's Avatar
Tires, weight, and driving style play the biggest roles. When I had 17's I averaged 34 MPG straight highway and 20 City. When I had my heavy 19's, it dropped to 29-32 MPG straight highway and like 16 city. Now with lightweight 19's my mpg jumped back to 32-33 mpg and 19-20 mpg city.
De-accelerate before stops, when you can in traffic, etc
Lose the spare tire and excess weight.
Don't know how to figure out on the tire but touring/all season tires for me usually are better
Old 07-12-2012, 11:40 AM
  #45
losiglow's Avatar
so i can avoid you.
Don't worry, I'm safe. At least toward other drivers .
Utah drivers can be pricks so I try my hardest not to fall in that stereotype.
Old 07-12-2012, 11:44 AM
  #46
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
OP as thechamp mentioned running a 20weight oil or putting a new air filter or whatever, wont help you much....yes it a good idea to keep the filter clean but dont go on replacing it every 5K miles....
the suggestions i have for you are:
1> DRIVING STYLE: I cant stress on how important this is....easy on the throttle, early shifts, coast to stop lights....drive like a fucking grandma....I use the Sport Shift mode and shift early when i care about the mpg
2> WEIGHT OF THE CAR: This affects a lot in the MPG as well...the less the weight the better the acceleration and MPG...
3> COOLING MODS: One this which determines the power is timing...if the engine pulls the timing, the car looses power and you press more on the gas pedal and hence low MPG...do some cooling mods, keep the underhood temps as low as possible and you will see an increase in MPG
Old 07-12-2012, 12:05 PM
  #47
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Same with Texas
Old 07-12-2012, 12:14 PM
  #48
lucnex's Avatar
a long with NJ, NY, CT, MA.....northeast
Old 07-12-2012, 03:29 PM
  #49
pohljm's Avatar
Just back from Boston and there is a reason they call them Massholes!
justnspace (07-12-2012)
Old 09-07-2012, 09:43 PM
  #50
Thunderrr's Avatar
Maybe someone said this already this but Synthetic oil makes a difference.. When I switched for the first time I got an extra 40km to a full tank. Now I cant complain about my TL shes perfect..
Old 09-07-2012, 10:00 PM
  #51
Bruce Banner's Avatar
Exhaust mods supposedly help with MPG gains
  #52
Did you see any MPG gains after the Jpipe and HFPC?
Old 09-12-2012, 12:44 PM
  #53
6th Gear
blackout52's Avatar
well off a personal answer id invest in a throttle body spacer. i have one in my 05 tl and legit saw a difference. easy install which just comes down to changing bolts any john doe who knows how to use a wrench can do it. its increases fuel economy especially if your on cruise i can get up to 430 miles on a tank. but also increases hp which you can feel a difference so take it east on the lead foot
Old 09-12-2012, 01:29 PM
  #54
swoosh's Avatar
^^^ i doubt it....
Old 09-12-2012, 01:43 PM
  #55
6th Gear
blackout52's Avatar
@ swoosh
well i this is after i was already drove for about 10 miles while on cruise control then stopped to get gas. Filled up and started driving again, changed to see my miles to empty and so more than symbol 360 which was cool after the more than symbol went up thats when my miles to empty went up ...i legit thought my display was broken
Old 09-12-2012, 02:11 PM
  #56
swoosh's Avatar
dude go thro the tank....just 10 miles doesnt tell anything
Old 09-12-2012, 02:28 PM
  #57
6th Gear
blackout52's Avatar
http://imageshack.us/photo/my-images...702191021.jpg/
^^^ THAT SHOULD PROVE IT
Old 09-12-2012, 02:31 PM
  #58
swoosh's Avatar
^^^ that doesnt prove anything....I have gotten 500+ miles on a tank on couple occasion when am doing all highway....
RANGE DOES NOT PROVE ANYTHING
you are saving your mpg increased after installing TBS, by how much??? do you know what the TBS does ? how much was your AVG MPG before you got the TBS???
Old 09-12-2012, 04:03 PM
  #59
losiglow's Avatar
No, nothing noticeable. Maybe 1mpg if that. Probably because those mods shine when a lot of air is being pushed through the exhaust (higher RPM's). Most of the time I'm just cruising below 2K or so which doesn't really take advantage of the increased capacity of the exhaust system.
And I'm gonna have to be skeptical on the TBS as well. I've installed a TBS and have noticed no improvements in mileage, power or air intake temps. I did it for kicks and giggles and because it was included with the IM spacer from Outlaw Engineering. I don't think it can hurt but I've never really believed in it's usefulness.
Old 09-20-2012, 10:55 PM
  #60
sag
sag's Avatar
the one thing to always remember when seeking tricks for beter fuel economy is if it were that easy, simple, or cheap, they would have put it in there to begin with! the millions manufacturers pay for not meeting fuel economy averages would certainly motivate them to just add that throttle body spacer, or add that "vortex" generator or any of that BS if it actually worked. two small tips that certainly wont hurt things but would be minimal at best, buckle your seatbelt/adjust stereo and whatnot before you turn the car on everytime, and if the engine is warm and you catch a light you know is long just turn the engine off.
Old 09-27-2012, 11:09 PM
  #61
italiancip14's Avatar
doesn't seamfoam help w MPG>?
Old 09-28-2012, 06:22 AM
  #62
HE>i
05_NBP_TL's Avatar
^Not really
If you have HIGH mileage, then maybe, but most people here that have taken apart engines say there really is no carbon builup in newer engines running 91+ octane.
Seafoam can help clean out the motor but doubt you notice any significant change in gas mileage. I used it before on my 99TL that has 190k miles but that was because my i pulled my manifold to clean the EGR port and i figured it wouldnt hurt to use seafoam.
Pour a bottle of seafoam or fuel injector cleaner in the gas tank and call it a day. Repeat this process again if neccesary.
ps. I averaged 32 mpg on my trip yesterday to work (70% hwy/30%city and about 45 miles)
Old 09-28-2012, 01:09 PM
  #63
i have a 04 with 63K, but I'm averaging about 20MPG, I wanted to see if somehow I could squeeze a little more out thought seafoam would do the trick
Old 09-28-2012, 01:59 PM
  #64
losiglow's Avatar
Seafoam has never helped me much with the TL. I used for the first time at 60K and I barely saw any smoke. Tried again at about 80K and still, no noticeable difference. Unlike the Accord where I was blowing it out something crazy.
The more I use Seafoam the less I'm convinced it works all that well. Especially with the TL.
justnspace (09-28-2012)
Old 09-28-2012, 02:11 PM
  #65
swoosh's Avatar
^^^ i used to use seafoam when i used mobil1 or some like that....every 5K miles....
1/2 can in gas tank, 1/2 can in vac port and 1 can in engine crank case....saw a lot of smoke most of the times....i tried it after redline and no smoke....hence i quit using it
Old 09-28-2012, 02:24 PM
  #66
^ so basically a waste?
Old 09-28-2012, 02:32 PM
  #67
swoosh's Avatar
^^^ I would say it depends on what oil you use....
if you use some cheap oil, do it....its worth it....if you use quality oil, you prolly dont need it....
every 15-20K miles i would still do it, just for that extra 0.000000001% of protection and cleaning....I have spend $20 on worse things
Old 09-28-2012, 03:21 PM
  #68
^ i have acura do the oil changes for me so i would assume its good. . . i heard that if you do it if you don't need it it can possibly cause damage
Old 09-28-2012, 04:09 PM
  #69
swoosh's Avatar
^^^ I doubt it will damage anything....
but yeah the dealerships use dino oil....thats why i do all the maintenance myself
Old 09-28-2012, 05:20 PM
  #70
Yvuru's Avatar
with premium gas coming close to $5 a gallon here in nyc i decided to start using fuel treatment additives again. used the techron chevron fuel system cleaner about a week ago and noticed that my fuel gauge would go down slower. this was on the tank of gas after i added the techron and i drive the same route back and forth 5 days out of the week
dont have numbers to post up because i havent reset the average mpg/mph counter. its at 9500 miles at 17mpg/21mph average
gonna use lucas fuel treatment next because i heard it quiets down the engine noise
Old 09-28-2012, 07:00 PM
  #71
Anthony3's Avatar
setting cruise on the high way at 68 i get 33 mpgs . i run 40 psi , mid muffler delete , a cone air filter on the stock intake tube , also i have bypassed the throttle body coolant line. 93 and up octane fuel.
Old 10-05-2012, 01:28 AM
  #72
4drviper's Avatar
is this valid, you be the judge but this is how i got into the 30's (pure hwy)
(because apparently shot pulley or valve adjustment wouldn't do that,,)
hard reset ecu (battery disconnect)
drive around on nice pavements with a cup of water and do not spill it
(unless you've done it you'll realize gas pedal is REALLY responsive off the line lol or i just suck at right foot)
never exceed 2k rpm
whenever cruising, cith 35mph, hwy 60, try to let off gas as much as possible to the point where you are losing speed 1mph/minute
do that for a tank or two then MPG soars up.
now, if you even WOT ONCE, it'll go back down.
damn artificial intelligence.
Old 03-05-2015, 08:04 PM
  #73
Jacobjamz's Avatar
Mpg
Originally Posted by ep3kid914
i dont think anyone has it worst then me
average mpg 19
average mph 25
but sometimes i drops to 14 &15 depending were im driving
I get a consistent 16-17 overall, I got 21 one tank and I was stoked. I don't know if there is something wrong with the car or my foot
TypeS860
09-03-2021 06:42 PM
mlody
12-04-2019 02:11 PM
DerrickW
11-15-2015 05:52 PM
Froid
09-27-2015 06:16 PM
TL14
09-24-2015 04:37 PM
Quick Reply: '04 AT TL MPG? Any tips/tricks for improved MPG?
