NY/NJ New Jersey & New York
Honda/Acura Mechanic in North NJ
Old 01-24-2017, 07:15 PM
  #161
acrdr's Avatar
I'm sure some of you with front brembo calipers had this happen
And after repair with Time cert kit
Attached Thumbnails Honda/Acura Mechanic in North NJ-20161026_092040.jpg   Honda/Acura Mechanic in North NJ-20161205_130618.jpg   Honda/Acura Mechanic in North NJ-20161205_130620.jpg
acrdr is offline
Old 01-24-2017, 08:14 PM
  #162
The Dark Knight's Avatar
Originally Posted by acrdr
Sometimes I'm unable to answer all questions on time
The best way to reach me is by
Sobstylp@gmail.com
Or text me @ 201-562-8576
Paul,
is this still your number?
The Dark Knight is offline
Old 02-07-2017, 11:21 PM
  #163
New Member
njmdx2002's Avatar
2002 MDX slipping transmission
Hi Paul,
I have a 2002 MDX and the transmission is starting to slip. I am local and would like you to take a look if possible. Thanks! Andrew
njmdx2002 is offline
Old 03-05-2017, 09:27 PM
  #164
hanknj's Avatar
Hi Paul, how much would it be to change the timing belt on an 06 TSX? idk if it's the cold weather but, when i first turn on my car it makes a little ticking noise but wont do it after the car warms up... would that be timing belt?
hanknj is offline
Old 03-11-2017, 06:25 PM
  #165
3rd Gear
Billfromnj05's Avatar
Hi Paul. Can you change the opds sensor/unit for me? Have the damn srs light on. And maybe a motor mount of two? 2003 TL
Billfromnj05 is offline
Old 03-11-2017, 09:42 PM
  #166
3rd Gear
Originally Posted by Billfromnj05
Hi Paul. Can you change the opds sensor/unit for me? Have the damn srs light on. Also can u do springs and struts?? And maybe a motor mount of two? Please let me know 2003 TL
Old 04-16-2017, 01:44 PM
  #167
Registered Member
The Machine's Avatar
Hey everyone, I just wanted to give a review of the recent service that Paul did to my 07 TL-S. I initially contacted him to discuss everything that I would like done as well as pricing. Paul was very prompt in his response time and I was more than happy with his prices for both parts and labor. When it got closer to my scheduled appointment, I gave Paul an initial deposit through PayPal before dropping the car off to so he could order any parts needed for the service. I dropped my car off on Saturday 4/8 and picked it back up on Sunday 4/16. I was going away on vacation for a week so it worked out well for both of us since he would have ample time to complete everything and I could pick it up after I got back from my trip. When dropping the car off Paul showed me around his garage and we re-discussed everything that I wanted to have serviced on the car just to make sure nothing was overlooked. I even asked Paul if he could save all the parts taken off the car for me and also take some pictures along the way to which he gladly did. Overall I had a wonderful experience and I'm very happy with how everything turned out. So if you're thinking of having any type of service done to your car, rest assure you're in good hands.
Here is what I had done and some pictures:
Timing belt/water pump (105k service)
Valve Adjustment
Spark Plugs
Pressure Switches
3x3 Trans fluid change
Oil Change
Fix oil leak coming from the oil pump seal
The Machine is offline
Old 04-24-2017, 06:40 AM
  #168
Honda / Acura Fanboy
ReMiXeDg's Avatar
Hey paul I will be giving you a shout later today, My name is Greg I am in New York and want to do 105k service , clutch and a bunch of other work I see you are very well worth it looking forward in having my car worked on by you be on the look out for my call thanks!
ReMiXeDg is offline
Old 06-05-2017, 09:12 AM
  #169
Relentless84's Avatar
Shout to Paul again for his legendary service, got my 105k service finally done amongst a few other things, definitely will be back soon! And definitely worth the commute from Queens lol. Thank you!!
Relentless84 is offline
pilozm (03-24-2018)
Old 08-29-2017, 06:43 PM
  #170
BillMFD3's Avatar
Another glowing recommendation for Paul. My passenger half shaft broke in half lots of rust and broke right by the vibration damper. Towed the car over from my office in Clifton to his garage. He knew exact what to do and at the same time he replaced my lca torn bushings swapping out both lca with all new bushings. Will not mention the price but it was great. As others have mentioned he's very knowledgeable has tons of experience and a nice guy to boot. 110 % highly recommend
BillMFD3 is offline
DMZ (02-26-2019)
Old 09-21-2017, 09:11 AM
  #171
'03 ABP YA4-S 6MT
rp_guy's Avatar
sent you a text
rp_guy is offline
Old 11-22-2017, 10:13 AM
  #172
acrdr's Avatar
08 TL-S leather replacement
Attached Thumbnails Honda/Acura Mechanic in North NJ-20170907_153504.jpg   Honda/Acura Mechanic in North NJ-20170908_142226.jpg   Honda/Acura Mechanic in North NJ-20170908_122454.jpg   Honda/Acura Mechanic in North NJ-20170908_140713.jpg
acrdr is offline
Old 11-22-2017, 10:38 AM
  #173
acrdr's Avatar
More pics
Attached Thumbnails Honda/Acura Mechanic in North NJ-20170907_125206.jpg   Honda/Acura Mechanic in North NJ-20170907_125202.jpg
acrdr is offline
Old 06-23-2018, 06:36 AM
  #174
6th Gear
Aaron Schmidt's Avatar
Paul, are you still active
Trying to get in touch, have read a lot of great things. Lost the tranny in my ‘06 TL. Bought from my neighbor about 2 years ago. 119K miles. I’m in Westchester, hoping to be able to communicate with you. Also sent you a text. Thanks.
Aaron Schmidt is offline
Old 08-06-2018, 01:43 PM
  #175
New Member
Danny Kaplan's Avatar
Just had Paul do some work on my 05 MDX, could not be more pleased with the experience.
Danny Kaplan is offline
DMZ (02-26-2019)
Old 08-29-2018, 07:25 AM
  #176
6th Gear
OfficialNikeJG's Avatar
Hi everyone
my name is Paul and i have been working for Honda and Acura as a mechanic for over 10 years
I am located in Clifton NJ
If anyone here needs any work done to their Honda/Acura .
I will be more than happy to help you out
I have a nice size garage at home that i work out of
Anything from Maintenance to Upgrades.
And if i cant do the work i will try to point you in thr right direction.
Hey Paul,
Is there any chance you could do an AV6 swap for a 03 Acura TL?
OfficialNikeJG is offline
Old 08-30-2018, 12:57 PM
  #177
6th Gear
how did you get in touch with him?
Old 09-25-2018, 10:30 AM
  #178
TVL65's Avatar
My 07' TLS has 152,000 miles and the front end was worn and loose. I honestly thought about selling it. Paul replaced the upper/lower control arms, ball joints, tie rods, numerous bushings, motor mounts and installed 4 new A-spec struts, etc. The car rides & feels like new again! I'm beyond happy. Paul is a real nice guy & an excellent Tech, he knows these cars inside & out and very experienced. His has a wealth of knowledge and I will also have him do work on our CRV's too. THANKS PAUL.
TVL65 is offline
Old 11-07-2018, 09:17 AM
  #179
Shout out to Paul once again; got my lower control arms, ball joints, sway bar end links, axles and seals, and a valve adjustment done this weekend. Always worth the trip from Queens, this guy knows his stuff! Will be back most likely once I figure out what suspension combination to go.
Old 11-08-2018, 10:31 PM
  #180
bg6203's Avatar
timing belt and engine mounts
Hi how are you? I have a 2004 acura tl 6 speed and I get this intermittent episode where the car just feels like it looses power and engine brakes a little more than usual. The it will just regain power and coast with no issues. Ive replaced the IAT sensor, PCV, cleaned throttle body and map sensor and changed the app sensor as well. Also changed battery and cleaned the egr valve ( just the valve). I still feel this intermittent hesitation. The two things the car needs are the timing belt service and new engine mounts. Any ideas about the hesitation? Could it be that the timing belt has slipped a tooth. Also, what do you charge for the timing bet service and the engine mounts? Really appreciate it
bg6203 is offline
Old 11-09-2018, 05:56 PM
  #181
bg6203's Avatar
Will do. Thanks for the heads up. Appreciate it
bg6203 is offline
Old 02-13-2019, 04:04 PM
  #182
mhtut83's Avatar
Why was he "Banned" from the forum? Just curious...
mhtut83 is offline
Old 04-23-2019, 09:01 PM
  #183
MarcDavidoff's Avatar
Adding to this original post here-- I know Paul is banned from here but figured another positive review couldn't hurt
I just had Paul do quite a few things on my 07 TL-S 6MT. About 3 years ago he did the AV6 trans swap in my old 02 TL-S and did a great job. My 07 has almost 185k and was about due for its 2nd TB/WP. My clutch was original and not slipping, but I was getting the stiff pedal a lot times after driving on the highway or after taking off spirited. So I supplied almost all the parts, all fluids, and seals for a TB/WP, Clutch/Flywheel, valve adjustment, reseal of oil pan/oil pump, and new front motor mount. As others have mentioned, he goes out of his way to point out important things he notices. Like my underhood fuse box that was cracking due to heat so he got one and replaced it for me. He is an honest and good guy and very reasonable and thorough. I am pretty anal with my cars and do almost all work myself except for the larger things like the clutch, etc. The car runs and drives great.
MarcDavidoff is offline
Old 03-14-2020, 07:48 PM
  #184
New Member
David Soria's Avatar
Hey guys, has anyone here gotten any work done by Paul recently, and can anyone provide his most recently known cellphone number so I can text him?
Need some work done on my 03 TL ASAP and would really appreciate being put in touch with Paul.
David Soria is offline
knight rider
03-04-2016 08:59 AM
Avenger411
10-11-2015 03:53 PM
iesu3423
09-29-2015 08:04 AM
4drviper
09-23-2015 09:00 PM
Quick Reply: Honda/Acura Mechanic in North NJ
