2015 Civic Si Sway bar upgrade
Old 02-23-2015, 02:17 PM
quagmiree's Avatar
I been doing some research on about upgrading the sway bar on the ILX and i came across the Si's 20 mm OEM sway bar. After some time reading some threads on 9thgencivic and checking part #'s on dchautomotiveparts, i bit the bullet and bought some parts that i think will work with our car. here is the parts list i came up with.
BOLT-WASHER (10X30) this is recommended for the new bracket ill be using
93404-10030-08
BRACKET, L. RR. STABILIZER since ill be putting in a thicker RSB, these brackets are reinforced to handle the thicker bar.
52318-TR7-A01
BRACKET, R. RR. STABILIZER
52317-TR7-A01
BUSH, RR. STABILIZER HOLDER x2
52306-TR7-A51
HOLDER, STABILIZER BUSH x2
52308-TR7-A00
SPRING, RR. STABILIZER - OEM 20 mm RSB
52300-TR7-A51
once i get all the stuff shipped in, ill do an install with pics. stay tuned!
The6ix (07-08-2019)
Old 02-23-2015, 03:04 PM
le^2's Avatar
Everything OEM? Hopefully you get a good fitment! I've read that MOOG are good aftermarket bushings/brackets and endlinks. Looking forward to pics and a review.
Old 02-23-2015, 04:33 PM
quagmiree's Avatar
yep!, everything is OEM. another reason i went with the OEM stuff is because of the price. everything with shipping came out to about $83!
Old 02-23-2015, 05:04 PM
le^2's Avatar
Is that so... Would you happen to know the current year sway bar specs? I believe it's something ridiculously low like 15mm. That 20mm upgrade should provide some additional stability and reduce body roll. I like, I like!
Old 02-23-2015, 05:40 PM
quagmiree's Avatar
the 2014 ILX comes with a 14mm sway bar. the 2016's come with the 15mm.
Old 02-24-2015, 11:25 AM
le^2's Avatar
Let me know if you encounter any squeaking from the new sway after install. I read some of the thicker bars, if not supported correctly with proper bushings/endlinks, you can hear it rattle and squeak. Definitely don't want that :p
Old 02-24-2015, 12:23 PM
quagmiree's Avatar
sure thing! i doubt they will though since our car is basically a civic chassis and the parts are from a civic. I'm impatiently waiting for the parts to be shipped in!
Old 03-02-2015, 08:03 PM
quagmiree's Avatar
some stuff came in today!!
Old 03-02-2015, 09:14 PM
aomechmarine's Avatar
Yep, that looks familiar
Old 03-05-2015, 07:12 PM
quagmiree's Avatar
got all the parts installed. here are some pics of the under carriage before and after.
to make it easy on yourself, you should take out that middle brace to take out the old sway bar.
the difference between the stock and the 2015 Civic Si sway bar. 14mm vs 20mm
old and new brackets. you can see the difference that the new one has better reinforcement
old and new bolts that hold the bracket in
The6ix (07-08-2019)
Old 03-13-2015, 09:17 PM
trexter's Avatar
looking forward to your review on running this Si sway bar vs stock
Old 03-17-2015, 06:18 PM
quagmiree's Avatar
the RSB is well worth the upgrade! especially for a total of $85. theres a bit less sway, the rear end feels stiffer, and less understeer.
Old 03-18-2015, 11:32 AM
trexter's Avatar
^^^good to know, thanks for the update. Check out this thread from a year ago. He talks about improving the handling by adding front camber bolts to run a little negative camber since the car tends to run positive camber. If I ever upgrade my suspension, I may consider both (rsb and camber bolts up front)
https://acurazine.com/forums/acura-i...ations-912614/
Old 06-06-2016, 08:59 PM
richard gunman's Avatar
Sounds like something id consider...any warranty issues with this mod.
Old 07-10-2016, 10:34 PM
9th Gear
got23hops's Avatar
how has the sway bar been over the last year? Any issues? Did you do the install yourself? Any chance you have a DIY guide or walk through?Looking to do this myself on my 16 ilx.
Old 07-30-2016, 03:00 PM
h_dawg's Avatar
I had did a similar upgrade in the past using an Acura RSX Type R swaybar and put it on my EM2 civic. Having a larger rear swaybar on a fwd car was one of the best mods to have (I also had lowering springs and tokico shocks). Definitely would recommend this mod
Old 08-02-2016, 05:03 PM
idelgado782's Avatar
quagmire what store did you make the purchase from?
Old 08-02-2016, 06:00 PM
usdmJON's Avatar
Pretty sure he got it all from a honda distributer. Search oem honda parts or call a dealer.
Ill be taking this route one day. Sway bar os so far down my list of mods. Form>Function lol
Old 08-04-2016, 03:44 PM
Yea I've found the cheapest place is Honda parts superstore online. Before shipping everything comes out to around $87. $16 shipping ground total comes out to $104.11. I know what you mean form>function. I'm trying to decide how I want to do my mods. Least Inexpensive first, or what I really want first, or visual.... I don't know lol. But I do drive the car a lot so I think I would personally enjoy this upgrade more because I'm in the car for anywhere 2-4 hours a day depending on what my work day looks like and what the traffic is like in NYC. I've also been considering a splitter for the front lip though... Decisions decisions...
Old 11-16-2016, 11:17 AM
aafdiablo's Avatar
hey guys, looking to get a hold of this crazy body roll and looking at that 22mm progress sway bar, anyone tried this one yet?
Old 11-16-2016, 11:25 AM
aafdiablo's Avatar
also looking to get some springs at the same time, just not sure which ones if anyone has any tips on what direction to go on that, h&r,eibach sportline/pro? other?
Old 12-11-2016, 09:47 AM
8th Gear
DMasters's Avatar
Has anyone installed the EIBACH PRO-PLUS (PRO-KIT SPRINGS & ANTI-ROLL-KIT SWAY BARS) kit on their 2016 ILX? Looks like a good deal, just wanted to make sure no one had any issues with the install.
Old 01-19-2017, 12:01 AM
lkn415's Avatar
Thanks for posting p/n #'s!
Old 02-16-2017, 11:09 PM
5th Gear
kiwigummy's Avatar
How many of the bolt washers do you need for the install?
Old 03-05-2017, 12:09 PM
Hey Im about to do this mod...can you please verify how many of the bigger bolts you will need and edit the thread accordingly...I really appreciate this thread...just not sure how many bolts we will require. From the pic it looks like only 2 packages. Please confirm or correct me. Thanks
Old 06-24-2017, 09:17 AM
Mprotege92's Avatar
Thanks OP for posting this. I purchased what you had suggested and had this installed. Great, low cost upgrade.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Brandle34
09-23-2015 07:20 PM
scionxb3003
09-22-2015 05:28 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
Quick Reply: 2015 Civic Si Sway bar upgrade
