2016 ILX 8spd DCT Transmission Issues
#81
2016 Acura ILX Tech Plus A-Spec
I have owned my ILX for a year now while putting a solid 16,238 miles on it. I commute 23 miles one way every morning in Atlanta stop-go traffic and have not noticed any issues. I do experience some of the examples that you have mentioned, but on a much much lower scale from what it sounds like. If I'm in D, I treat the car as if it had 50HP and anything over 3k RPM will blow up the engine. When in S, let's just say there is no lagging or slow throttle response. It will use the engine to slow down, but only when in S. Is there any way you can take video of the car while experiencing issues? I had a GoPro mounted in my car for awhile to video, I don't know, everything? Please let us know of any updates. It is most appreciated!
Best Regards,
D. Masters
Best Regards,
D. Masters
#82
It is a computer controlled manual transmission so there are forks moving around in there unlike hydraulic valving in most automatics. Also the hard shifts are caused if you reduce throttle slightly while it is preparing an upshift. The only oddity that bothers me is the pause with a quick stop and go in D.
#84
8th Gear
My new 2017 ILX only 800km mileage has the same problem when it stop in cold engine, the transmission is making noise and sometime you can feel it too. The problem not happening every start and not sure will dealer can do something about it.
#86
This is more or less the ILX version of a thread being run in the TLX forums regarding the lurching/jumping/lagging transmission issues that seem to be plaguing the 2015 TLX 4 cylinder (same engine that is now in the 2016 ILX).
I am confirming that indeed, the exact same problems are showing up in my 1-week-old 2016 ILX.
Here are the problems I've noticed (which mirror the TLX problems):
It's important for 2016 owners to document this problem in our own thread, so that Acura sees that this is not just a TSX problem, but has the potential to affect its newest baby in the lineup.
Other than this issue, I would like to state for the record that I LOVE THIS CAR.
- Lurching into 1st gear when coming to a stop - hard
- Delay when shifting from REVERSE to DRIVE
- Random loss of power when trying to accelerate from a slow roll or standstill
including replacing the transmission, still the same issures. Is there going to be a recall, has anyone lemon law this problem?
#87
ILX Transmission
Me too, have 2016 ILX and have 3 attempts by dealer to fix these issues, including a new transmission installation. No change! Has anyone tried to Lemon Law this, and in what State?
#89
2016 ilx
I recently had a 2016 Acura ILX Ceritfied pre owned 4700 miles on it. Its been good for 3 days and I started observing a lag in gear shift from R to D
2. lag in braking, Even if I hit the brake, the car pulls ahead with a delay and then applies brakes. I did see this behavior in MDX but not ILX.
3. RPM jumps up at low speeds.
4. Delay in initializing Infotainment screens and dead slow operation.
5. Hesitates to give the power when I hit gas pedal.
PS: I did not experience these issues at the time of test drive nor on first day. and my Software is at ver ST0030200 and Ver 1002803
Any idea what to do. I 've scheduled a service this week.
#90
'14 ILX 5 speed 61000ish miles. I've had none of the problems here. Shifts fine, doesn't lurch, and I occasionally in sports mode I'll drive like a retard on bath salts.
#91
#92
Have you guys noticed the transmission slipping when it's really cold during winters?
My 2017 slips within the first 5 minutes of driving. What I mean is that when you try to accelerate, the rpm jumps up and stays at say 2500 rpm while the car is accelerating, as if it's a CVT. My car does this every time it's really cold outside and then the shifts become more crisp after around 5 minutes of driving.
#94
#95
I found this thread via Google. I was having some similar issues with my 2016 ILX, mainly the hard shifting into 1st when coming to a complete stop and hesitation of shifting in lower gears when in stop-and-go traffic. I was also experiencing a hard shift into reverse after starting it up first thing in the morning. I took it to the dealer and they actually performed a software update that appears to have fixed it. I haven't noticed any issues in the past few days since the update. Just wanted to pass along this bit of info in case anyone else stumbles across this thread like I did.
#96
#97
I feel like when I put it in reverse then back up I hear a click sometimes. When I am coasting and tap the gas it sounds like someone is flicking the side of my car,etc. Just a lot of weird noises. I mean, I drive my girlfriends 2015 rav-4 and it is like butter. No sounds, jerking forward, weird pops and whatnot. I just know if I take it to the dealer I will get raped. And that is the whole reason I pony'd up and bought a newer car, because I was getting robbed by every mechanic in the state and never got anything fixed.
#98
I realize th Rav4 isn't an 8DCT but I just cannot imagine that all of the clunks, pops, and sounds as if you are running over something are "normal" but I am sure I will be told by Acura, oh well, that is a DCT and it is normal" .I am so disappointed and feel like I was sold a lemon, now I am stuck with a 16k loan for a car that no one will ever admit dosn't operate right. Never used the paddles to shift but do not feel as if I should have to. Just frustrated and the fact that a big RECALL thing was on my carfax report but nothing comes up when I enter my VIN so I am sure whatever needs fixed will cost me an arm and a leg and probably won't be covered by warranty.
#99
#100
The DCT8 is not a normal automatic transmission. It is a computer controlled manual transmission.
The electronic controls click, pop, whir, and buzz. Rapid changes in throttle cause gear clunk like a manual.
The lockup torque converter exacerbates the clunk when locked.
schen72 (07-18-2019)
#101
I also just got a 2016 ILX with 23k miles. NEver had a DCT but it just doesn't feel right. When you come to a stop, I can hear things "popping down" and I know everyone says "the dct makes sounds" but I have never been in a car where I have heard clicks, pops. Just doesn't seem smooth at all. Kind of bummed about it, not to mention after I got gas yesterday, the "check fuel gauge" orange light came on, gas thing dropped to E then it went away. I am just upset that I now feel like I have a new car that will need money put into it faster then I can put miles on it.
#102
This is probably not what anyone wants to hear for a first post, but I just wanted to say that I'm rooting for you guys and I hope that Acura resolves this issue for everyone impacted. I was strongly considering purchasing the 2016 ILX until I saw all of these issues with the 8-speed DCT. It was honestly enough to scare me away from this car and the brand. Just bought a different car today...
#104
The only thing that's the same between the ILX and Cherokee transmissions is that they have a torque converter. Otherwise, they're completely different technologies, with the Jeep being a conventional 9-speed automatic versus the 8-speed dual-clutch automated manual in the ILX/TLX.
#105
https://www.thecarconnection.com/new...-cherokee-suvs
#106
the 9 speed in the jeep is the same 9 speed in the acura tlx, this is common knowledge, they all failed. Honda failed everyone by not designing their own trans
#107
TLX has two different transmission options. You can get a 9-speed conventional automatic, which is shared with many other makes of cars, including Jeep. There is also an 8-speed DCT option that is Honda developed and manufactured. This is the same 8-speed DCT in the 2016+ ILX.
#108
I test drove the TLX v6 with the 9 speed NON HONDA GARBAGE trans. The car accelerated fine but when I took my foot off the gas there was a bump almost like the cruise control was on and kicking in. This was a 2020 model. I yelled what was that and the salesman took the car out of sport mode. Well after poking around the net I find out that lots of people have this problem and that Acura will can not fix the problem without admitting to the severity of the problem. At this point I would buy a Kia before an acura, it's literally junk from the start. Also this is why only a retarded company would make the shifter buttons that a dog can step on and activate.
https://www.youtube.com/watch?v=010-Id-d1VY
Also, you talk about shifter buttons that a dog can step on, but the video you embedded is of a Mercury Sable from the 90s, which does NOT have shifters buttons.
#109
#110
2016 ILX - loss of power on acceleration
Seeing that others have posted the same transmission issue: loss of engine power on acceleration from low speeds.
Has anyone had any resolution to this problem? my dealer is telling me they have to replace the entire valve hub and is quoting me nearly $5Gs. Seems nuts to me, as I barely have 90k on the vehicle and have babied it.
any insight / guidance anyone can shoot my way wood b greatly appreciated
