brake torque specs
Thank you Justnspace. the 80 lb. torque on lug nuts seem right, but caliper frame bolts seem high for a little car. my F150 is 136 ft. lbs. But thank you for your feed back.
I dont know about pre mmc ilx but for 2016 model..
Front caliper: mounting bolts (80 ft-lbs) and guide pin bolts (37 ft-lbs)
Rear caliper: mounting bolts (55 ft-lbs) and guide pin bolts (17 ft-lbs)
rear caliper should be the same but the 2016 ilx has a bigger front caliper. So around 75 - 77 ft-lbs should work
MrHeeltoe
03-15-2011 04:42 PM
MrHeeltoe
2G TSX Performance Parts & Modifications
03-15-2011 04:33 PM
