Home Automation
#81
I like the looks of this smartthings stuff. I am thinking about doing a quasi home monitoring system with it. My only gripe is that these accessories are DC voltage... this is annoying because who wants to have to hide transformer packs?
Is there one place that is better than the others to buy stuff? Seems like the best prices come direct from Smartthings because they have a coupon.
Here's a question about the programming. If I had an arrival sensor and some light switches, could I program it to turn the outside lights on when we arrive home? Could I go a step further to program it to only do that during night hours?
#82
Also, I'm pretty sure most of the things are battery powered and not plug ins.
#83
Needs more Lemon Pledge
OK, my head is going to explode...
I currently have the ST monitoring the ZWave Yale lock. I also somehow managed to set it up so that I get an SMS when the secondary code is used. I think...
Here is where I am having trouble. I have a DLink DCS-934L currently set up with the DLink app to email me a picture every time it sees motion. Unfortunately, this is happening any time I move around inside the office. I don't want to over-complicate this with proximity sensors, etc. so what I want is to have an old cell phone near the door to the office with a button that I can use to enable/disable the motion capture on the camera. I will leave the cell/table turned on and stick it to the wall.
Anyone know if a way to do this? Do I need to use a better (supported) camera that the ST can access the motion sensor of the camera or is there some work around?
#84
#86
#87
B. I need some way to know if someone kicks the door open, picks the tumbler, etc.
#88
Stage 1 Audi S5
We want pics ha
So you want to disable the motion activation when you're there, correct? You need to set your phone up to disable that when you arrive, just not sure how off the top of my head...
#89
Correct, and truthfully it doesn't need to be a fancy automated thing like with bluetooth, etc... I am happy to have a tablet/cellphone at the doorway with the ST app/tiles running constantly and simply activate/deactivate it by pressing a button on the screen.
#91
#92
Received 3,664 Likes
You can use one of those remotes and program it to control anything you want inside smart things. You could setup a virtual switch within smart things that disables the motion detection on the camera when you activate the switch. Then link the switch to the one of the buttons on the remote. If you can't control the motion sensor in the camera you could have it turn the camera on and off via the remote button.
EDIT: Another way I thought of you might be able to do without messing with the motion sensor is to only have it send you pictures of motion when SmartThings is set to away and not home. You could use one button on that remote to set SmartThings to know you are home and another button to push to set it to away when you leave.
#93
I can't seem to figure out how to have ST turn a device on or off... That would be fine, and is a great solution.
Honestly, the web interface and app are kind of confusing. I cna access any one connected item from five different screens, and each different way to access the item shows me something different.
#94
Stage 1 Audi S5
I haven't done much with this but I was suggesting you use your current, everyday cell phone as a presence sensor so when you walk in, it turns the cam off. To do the off part, you would need to enable your phone as a presence sensor and you would need a Smartapp, something like 'Turn It On' maybe? I haven't used it but in the app click marketplace, smart apps, presence & modes, then try that one.
Hate to suggest researching because it has sucked hours out of my life (like AZ) but the ST community has a TON of answers.
#95
I'm not familiar with D-Link cameras but if there isn't a way to shut the camera off or disable notifications remotely I'm not sure that you'd be able to get it to work with smartthings. I could see you having the camera hooked up to a zwave/zibee outlet that powers on/off depending on what happens with the lock or is disabled with a proximity device/cell phone location. But if you are going to that effort maybe looking into a camera that has that stuff would be worth looking into?
We have a few Nest cameras and can set it up so we are only notified when our cellphones are out of the house. I'd love to see someone come out with facial recognition to only alert on unknown faces. That is what I'm hoping to see with the Nest eventually. When they came out with the outdoor Nest Cameras they also updated their software to recognize people vs plain ole movement. Of course Google owns Nest and also has great facial recognition with google photos, hopefully we'll see something like this in the future.
#96
Thanks tons for getting me pointed in the right direction!
#97
it will take some playing to get it to work right, but I am sure I will get it eventually.
#98
Stage 1 Audi S5
I MUCH appreciate YOUR info, I am trying to "learn-up" on the system but am finding, like you, that it take a while to figure this all out. I kind of wish it were a bit simpler (device actions, vs hub actions, vs. action initiators vs. device handlers, etc.) but I will figure it out eventually.
stogie1020 (12-19-2016)
#99
There might be a way to disable motion sensor remotely with that camera. If so you might be able to set it up to disable when your cell phone is present. Here's a thread that might have some useful info.
https://community.smartthings.com/t/...etype/25592/26
I set up a window sensor on the garage door today with a 2x4 and a piece of aluminum flat bar. Works really well and triggers pretty fast. I have it set up to notifiy me if it opens during certain times, or if I leave the garage door open after a certain amount of time. I still am waiting on a good deal for some more sensors :-)
Everbilt 1/2 in. x 36 in. Aluminum Flat Bar-800217 - The Home Depot
#101
I thought these looked pretty slick
https://www.amazon.com/gp/aw/d/B01LW...236_SY340_QL65
#102
Might have to get a pair of those for the two gates to my backyard. Would be nice to know they are always shut when not home.
#103
Great thread, gentleman. I have plans for this technology in the future.
And if you have any questions about electric, like tying things into switches or whatever, let me know. I used to be a full-time Electrician and still do it on the side.
The following 3 users liked this post by Scottman111:
#104
Stage 1 Audi S5
@atomlinks - I have not used these but the slickdeals reviews are pretty good but you might want to search ST as well; $15 open/close, $20 liquid sensors, and a few more I believe Click Me
Strips look awesome, I drilled a recessed sensor into my gate and siliconed it in. While that was cheaper, those strips are pretty clean and Z Wave plus for extra battery life and range is a major plus.
atomlinks (12-19-2016)
#105
Those PEQ sensors appear to be zigabee is that correct? So far everything I have done is ZWave and what I have installed is fairly spread out over my entire first floor which means I should have a good Zwave network. I assume that starts all over if I switch to items using Zigbee means I need to build my entire network again for that.
#106
#107
#108
Stage 1 Audi S5
Yes, sorry, I forgot to mention that and I've mixed a bit, due to great sales. To me, ZB has better range but that's just me.
As for the mesh, if you have a great Z wave, I would keep going!
#109
My GE ZWave appliance plug showed up last night. I had read that they work better for Christmas lights than the dimmers do so went with it. Now my Christmas tree and mantle lights are automated. So much better than climbing behind the tree to plug them in.
#110
Just found this explanation of both. ZigBee vs. Z-Wave Review: What?s the Best Option for You? - SafeWise I didn't really know much about Zigbee before honestly. Now I am wondering if I should start going with it instead of Zwave based on what is in that article. Sounds like in the long term you may be able to do more with it.
https://community.smartthings.com/t/...future/51235/3 This forum post talks a bit though about how Zigbee also is not as universal even though it is open source.
stogie1020 (12-20-2016)
#112
#113
On the side? Like, when you're not working as a Driving Instructor?
#114
#116
Our work is done here.... Twas a good outlet for the puns, no?
Now I feel grounded.
#118
Wow guys...
I don't have the capacity to continue on here...
#119
Go Giants
Powerful stuff
#120
Well that automated off task quickly
